gerg 10,871 Posted February 4, 2020 Is that with opens ? Sent from my SM-G570Y using Tapatalk Nah 58cc, 60 down the hole, 28cc dish, 40 head gasket. Sent from my CPH1903 using Tapatalk 2 bear351c and CHESTNUTXE reacted to this Share this post Link to post Share on other sites
Boingk 862 Posted February 5, 2020 With 58cc / .060 deck / 20cc dish you're looking at 9.35:1 ratio, or 9.45:1 at .030 overbore. You really need to get measurements, but either way I'd be using the 58cc closed chamber head or you might drop into the 7's for compression. 1 CHESTNUTXE reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,307 Posted February 5, 2020 With 58cc / .060 deck / 20cc dish you're looking at 9.35:1 ratio, or 9.45:1 at .030 overbore. You really need to get measurements, but either way I'd be using the 58cc closed chamber head or you might drop into the 7's for compression. Sorted fan out have 3 different spacers and an electric uma thermo if neededSent from my SM-G570Y using Tapatalk Share this post Link to post Share on other sites
gerg 10,871 Posted February 5, 2020 Lol... Watch out for the 5 finger exploding oil pump trickSent from my CPH1903 using Tapatalk 1 CHESTNUTXE reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,307 Posted February 5, 2020 serious gerg Pai Mei owns the house here,and he is related to the thai royal family,he also drives the EB 1 ,and tells me storys about a supercharged 76 corvette he won in a poker game in bangkok when a smart ass thru the keys into the big pot on the table and he drove the sucker home after winning the hand,true story. 1 gerg reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,307 Posted February 5, 2020 He has the Hattori Hanzo sword if any m/f wants to start trouble 1 gerg reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,307 Posted February 6, 2020 He has the Hattori Hanzo sword if any m/f wants to start trouble I found a 20 tooth drive out of an fmx at the wreckers and i reckon its gunna be near enough gregaus was saying 19 or 20 but it fits like a finger in the bum,plus got it complete for $15Sent from my SM-G570Y using Tapatalk 2 gregaust and Boingk reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,307 Posted February 6, 2020 I found a 20 tooth drive out of an fmx at the wreckers and i reckon its gunna be near enough gregaus was saying 19 or 20 but it fits like a finger in the bum,plus got it complete for $15Sent from my SM-G570Y using TapatalkAlso this dipstick does not fit very tight what would be the go ? Just a dab of sealer ?Sent from my SM-G570Y using Tapatalk Share this post Link to post Share on other sites
bear351c 10,270 Posted February 6, 2020 I'd try thicker o-rings before sealer. 1 CHESTNUTXE reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,307 Posted February 6, 2020 I'd try thicker o-rings before sealer. It has 2 o rings i suppose once its bolted to the firewall it wont be flip flopping around as muchSent from my SM-G570Y using Tapatalk Share this post Link to post Share on other sites
CHESTNUTXE 7,307 Posted February 6, 2020 It has 2 o rings i suppose once its bolted to the firewall it wont be flip flopping around as muchSent from my SM-G570Y using TapatalkAir cleaner cameSent from my SM-G570Y using Tapatalk Share this post Link to post Share on other sites
FORD_MAN 1,026 Posted February 8, 2020 using UEM(KB) pistons calc 58cc, 20cc, 0.060", 4.1x0.041", 4.030x4" 9.41:1 or 9.68:1 with 4.1x0.027" MLS Cometic C5871-027 standard rockers can handle upto .550", manifolds reversed (LH to RH/RH to LH) for turbo header, https://uempistons.com/p-27-compression-ratio-calculator.html https://www.ebay.com.au/itm/Cometic-Gasket-C5871-027-027-Mls-Head-Gasket-Ford-351-Cleveland-4-100-Bore/233431488377?hash=item365999d779:g:Io8AAOSwGshd8cmA 1 CHESTNUTXE reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,307 Posted February 11, 2020 using UEM(KB) pistons calc 58cc, 20cc, 0.060", 4.1x0.041", 4.030x4" 9.41:1 or 9.68:1 with 4.1x0.027" MLS Cometic C5871-027 standard rockers can handle upto .550", manifolds reversed (LH to RH/RH to LH) for turbo header,https://uempistons.com/p-27-compression-ratio-calculator.htmlhttps://www.ebay.com.au/itm/Cometic-Gasket-C5871-027-027-Mls-Head-Gasket-Ford-351-Cleveland-4-100-Bore/233431488377?hash=item365999d779:g:Io8AAOSwGshd8cmACleveland correct water pump acc bolt configuration it aint easy ,took quite a while to work it out plus alt bracket and p/s Sent from my SM-G570Y using Tapatalk Share this post Link to post Share on other sites
Free.51 2,717 Posted February 24, 2020 On 2/5/2020 at 1:46 PM, CHESTNUTXE said: Sorted fan out have 3 different spacers and an electric uma thermo if needed Sent from my SM-G570Y using Tapatalk Hmmmmm nice wakazashi 1 CHESTNUTXE reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,307 Posted February 24, 2020 often i get on the number plate website and i thought of doing a yellow ford with the number plate KILBIL 2 1 gerg, Fingers and Free.51 reacted to this Share this post Link to post Share on other sites
Free.51 2,717 Posted February 24, 2020 If i were to make a custom plate for my car it would be JH71FD or just JH71 1 CHESTNUTXE reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,307 Posted February 24, 2020 29 minutes ago, Free.51 said: If i were to make a custom plate for my car it would be JH71FD or just JH71 im ordering a few 400 engines you should grab one 1 Free.51 reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,307 Posted February 25, 2020 16 hours ago, CHESTNUTXE said: im ordering a few 400 engines you should grab one I just found another 400 short motor and bought it WTF how do i find this shit ,it just appears in the most crazy times,it has broken piston and action man has the std bore pistons out of the other 400 to fix it this cant be conincidence its like a light shinning down from above that it was made to be ? Sent from my SM-G570Y using Tapatalk 2 1 Boingk, gerg and 2redrovers reacted to this Share this post Link to post Share on other sites
gerg 10,871 Posted February 25, 2020 Maybe this?Sent from my CPH1903 using Tapatalk 3 Boingk, 2redrovers and CHESTNUTXE reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,307 Posted February 25, 2020 Maybe this?Sent from my CPH1903 using TapatalkCome on gerg i will give this short motor to you on a plate for 300 buxSent from my SM-G570Y using Tapatalk 1 gerg reacted to this Share this post Link to post Share on other sites
gerg 10,871 Posted February 25, 2020 Come on gerg i will give this short motor to you on a plate for 300 buxSent from my SM-G570Y using TapatalkDamn you Action ManSent from my CPH1903 using Tapatalk 1 CHESTNUTXE reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,307 Posted February 25, 2020 i haven't picked it up yet,has big block bell,im keen to see what vintage it is,just from a quick look seemed good,its ok,will need reco thats forshore,but your in sydney right,freight might be a bit silly,i am getting others from usa,if and when pm,shit thats good poetry 1 gerg reacted to this Share this post Link to post Share on other sites
gerg 10,871 Posted February 25, 2020 Nick (my brother) can come down from Brissy and grab it in his ute, should I pull the trigger on one. So tempting but... So unecessarySent from my CPH1903 using Tapatalk 1 CHESTNUTXE reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,307 Posted February 25, 2020 Nick (my brother) can come down from Brissy and grab it in his ute, should I pull the trigger on one. So tempting but... So unecessarySent from my CPH1903 using TapatalkI couldn't sleep i went and grabbed it and the thing still turns and engine number is nearly same as mine could this be the blues bros?Sent from my SM-G570Y using Tapatalk Share this post Link to post Share on other sites
gerg 10,871 Posted February 26, 2020 Fucken hell, was it the power unit in a bitumen road plant or something Sent from my CPH1903 using Tapatalk 2 Boingk and CHESTNUTXE reacted to this Share this post Link to post Share on other sites
