Jkmacxf 24 Posted July 31, 2018 Hi ozfalconners does anyone know if any other seats or from e, a or b series will bolt straight into the xf. Share this post Link to post Share on other sites
Defective 1,692 Posted July 31, 2018 If it's late xf ea/b/d seats will bolt in. Early xf nothing just bolts in. 1 Jkmacxf reacted to this Share this post Link to post Share on other sites
Jkmacxf 24 Posted July 31, 2018 If it's late xf ea/b/d seats will bolt in. Early xf nothing just bolts in.Nah 3/86 so nearly in the middle. Sent from my iPhone using Tapatalk Share this post Link to post Share on other sites
Valvebouncer 2,389 Posted August 1, 2018 Do the bolts go in from the interior and thread into the floor or pass straight through and have a nut on the end you undo from underneath?? Share this post Link to post Share on other sites
Jkmacxf 24 Posted August 1, 2018 Do the bolts go in from the interior and thread into the floor or pass straight through and have a nut on the end you undo from underneath??Hi valvebouncer they are threaded into the floor Sent from my iPhone using Tapatalk Share this post Link to post Share on other sites
CHESTNUTXE 7,299 Posted August 1, 2018 or take the rails off and buy some autobarn sports seats quite easy to fit just drill a few new holes in the rail and straight in. 1 Jkmacxf reacted to this Share this post Link to post Share on other sites
deankxf 20,266 Posted August 1, 2018 13 hours ago, Jkmacxf said: Hi valvebouncer they are threaded into the floor Sent from my iPhone using Tapatalk is it a ute? the late utes often have E series seat mountings, but i think 1988 was the first model for that but a sedan/wagon i'd say the nuts to undo the seat rails would be under the car you may find the later seats can be bolted to the XF seat rails without too much modification? but i haven't seen one for so long i can't remember if they are even close 1 Jkmacxf reacted to this Share this post Link to post Share on other sites
Jkmacxf 24 Posted August 18, 2018 All good the seat mechanism that rocks the whole seat back was beyond repair. Nothing a little spot weld could not fix 2 SPArKy_Dave and deankxf reacted to this Share this post Link to post Share on other sites
SPArKy_Dave 8,863 Posted August 18, 2018 A common problem... and an easy fix! Nice work dude! Share this post Link to post Share on other sites
SPArKy_Dave 8,863 Posted August 18, 2018 You can get reproduction seat rails from memory. Share this post Link to post Share on other sites
Jkmacxf 24 Posted August 21, 2018 You can get reproduction seat rails from memory.Awesome I will get them once it is has a rwc and sort it out properly. Sent from my iPhone using Tapatalk Share this post Link to post Share on other sites
