CHESTNUTXE 7,299 Posted July 17, 2018 I got them ok i get it,action man can do this,on the way to work i will buy the lapping paste and suction toolSent from my SM-G570Y using Tapatalk 1 deankxf reacted to this Share this post Link to post Share on other sites
Valvebouncer 2,389 Posted July 17, 2018 I got them Sent from my SM-G570Y using Tapatalk The lapping sticks you have are great but that paste is absolute rubbish, I have a full container of it, tried it on one valve and put it back on the shelf. It dries too quickly and is way too coarse for my liking ( I know it has coarse and fine paste ). Try and get ARBO brand, it stays wet for a long time and you can see how well the valve and seat are mating together while using it- kind of like bearing blue - once you start lapping valves this will make more sense as you get a feel for it. It leave a nice finish too. By all means give it a go but you may find it frustrating to use. Mix it up well with a screwdriver before trying to use. Another thing you should buy is a straight edge if your going to do more of these engines. You need to make sure the heads are flat. Any more than 2 thou dip or warp and you should look at getting skimmed at the machine shop. I usually check them 5 ways , front to back on the exhaust side of the chambers, again on the inlet side then again straight down the middle. Then diagonal from front left to back right then front right to back left. Buy a nice long proper straight edge, mine is around 1200mm long and don’t drop it! 3 CHESTNUTXE, Outback Jack and gerg reacted to this Share this post Link to post Share on other sites
Valvebouncer 2,389 Posted July 17, 2018 Here you go, my bad, the brand is ABROhttps://rover.ebay.com/rover/0/0/0?mpre=https%3A%2F%2Fwww.ebay.com.au%2Fulk%2Fitm%2F263335424901 1 Outback Jack reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,299 Posted July 18, 2018 The parts cleaned up well and a shot of wd on emHere you go, my bad, the brand is ABROhttps://rover.ebay.com/rover/0/0/0?mpre=https%3A%2F%2Fwww.ebay.com.au%2Fulk%2Fitm%2F263335424901Sent from my SM-G570Y using Tapatalk 2 Outback Jack and Valvebouncer reacted to this Share this post Link to post Share on other sites
Valvebouncer 2,389 Posted July 18, 2018 The parts cleaned up well and a shot of wd on emSent from my SM-G570Y using TapatalkThose parts are coming up well. You should try to keep all the pushrods and rockers in the same order as they have worn together. It’s not absolutely necessary but it’s good practice.I’d crack open the oil pump to clean and lube everything up especially the relief valve. Learn from my mistake of not checking it then blowing off an oil filter then having to rebuild another pump and install it with the engine in the car. 3 gerg, CHESTNUTXE and ando76 reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,299 Posted July 18, 2018 Plugs came so i will try this new stuffThose parts are coming up well. You should try to keep all the pushrods and rockers in the same order as they have worn together. It’s not absolutely necessary but it’s good practice.I’d crack open the oil pump to clean and lube everything up especially the relief valve. Learn from my mistake of not checking it then blowing off an oil filter then having to rebuild another pump and install it with the engine in the car.Sent from my SM-G570Y using Tapatalk Share this post Link to post Share on other sites
CHESTNUTXE 7,299 Posted July 18, 2018 Plugs came so i will try this new stuffSent from my SM-G570Y using TapatalkI also put the cam in and check my re co efi exhaust buck rodgers shield Sent from my SM-G570Y using Tapatalk Share this post Link to post Share on other sites
CHESTNUTXE 7,299 Posted July 18, 2018 I also put the cam in and check my re co efi exhaust buck rodgers shield Sent from my SM-G570Y using TapatalkYep looks awsomeSent from my SM-G570Y using Tapatalk 1 77xcfalcon reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,299 Posted July 18, 2018 Yep looks awsomeSent from my SM-G570Y using TapatalkComing along nicely also some other gaskets cameSent from my SM-G570Y using Tapatalk 1 deankxf reacted to this Share this post Link to post Share on other sites
Ando81 2,949 Posted July 18, 2018 That stag paste is some of the stickiest crap I’ve ever had to get off my fingers. It should seal well 1 CHESTNUTXE reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,299 Posted July 19, 2018 The crank looks ok nothing a quick linish wont bring up note 84da used larger bolts yet still has 1 piece rear sealThat stag paste is some of the stickiest crap I’ve ever had to get off my fingers. It should seal well Sent from my SM-G570Y using Tapatalk 1 Slow250XC reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,299 Posted July 21, 2018 The crank looks ok nothing a quick linish wont bring up note 84da used larger bolts yet still has 1 piece rear sealSent from my SM-G570Y using TapatalkI cant go any further till the main bearings and rings come Sent from my SM-G570Y using Tapatalk Share this post Link to post Share on other sites
CHESTNUTXE 7,299 Posted July 22, 2018 I cant go any further till the main bearings and rings come Sent from my SM-G570Y using Tapatalk4 more deliverys thismorn,i found this 84/87 crossy gasket set for only 30 bucks deliverd on e bay stupid thing is just to buy the pan gasket was 34 bucks alone so its a bargin also crane wolferine lifters and main bearings plus valve spring toolSent from my SM-G570Y using Tapatalk 1 Valvebouncer reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,299 Posted July 22, 2018 4 more deliverys thismorn,i found this 84/87 crossy gasket set for only 30 bucks deliverd on e bay stupid thing is just to buy the pan gasket was 34 bucks alone so its a bargin also crane wolferine lifters and main bearings plus valve spring toolSent from my SM-G570Y using TapatalkThis is the most useless tool i have ever bought its taken 1 hour to remove 1 spring and im binning itSent from my SM-G570Y using Tapatalk Share this post Link to post Share on other sites
Valvebouncer 2,389 Posted July 22, 2018 Yep they are bad. Try greasing up any part that moves or rubs on another. Mine is a different type that I’m going to modify. 1 CHESTNUTXE reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,299 Posted July 22, 2018 This re build has just blown out of budget ol m8 is fixing the sparkplug thread and taking the springs off so i can clean and lap the valves Share this post Link to post Share on other sites
Valvebouncer 2,389 Posted July 22, 2018 At least it will be done properly.Raise your price. 1 CHESTNUTXE reacted to this Share this post Link to post Share on other sites
Crazy2287 1,886 Posted July 22, 2018 17 hours ago, CHESTNUTXE said: This is the most useless tool i have ever bought its taken 1 hour to remove 1 spring and im binning it Sent from my SM-G570Y using Tapatalk I used mine to do several engines (before one of my mates burrowed it and fucked it somehow) I removed the top bit,, cut the cups off that goes over the valve spring, and welded some flat steel in there, then reattached the cups. I did it in such a way as to correct the alignment of the tool when it is clamped. Before i did this, the tool was, as you say, useless. But after the mod i used it several times on a couple different engines over the course of a few years. I'd take a pic to show what i mean but i never got it back. 1 CHESTNUTXE reacted to this Share this post Link to post Share on other sites
Crazy2287 1,886 Posted July 22, 2018 On 7/18/2018 at 8:38 AM, Valvebouncer said: The lapping sticks you have are great but that paste is absolute rubbish, I have a full container of it, tried it on one valve and put it back on the shelf. It dries too quickly and is way too coarse for my liking ( I know it has coarse and fine paste ). Try and get ARBO brand, it stays wet for a long time and you can see how well the valve and seat are mating together while using it- kind of like bearing blue - once you start lapping valves this will make more sense as you get a feel for it. It leave a nice finish too. By all means give it a go but you may find it frustrating to use. Mix it up well with a screwdriver before trying to use. I re-wet the paste with a little lubricant. water, wd40, little bit of light oil. It all works fine. 1 CHESTNUTXE reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,299 Posted July 22, 2018 yeah it says you can wet it and thin it out. Share this post Link to post Share on other sites
CHESTNUTXE 7,299 Posted July 23, 2018 yeah it says you can wet it and thin it out.I also noticed that the alt bracket is really short and probly only suits efi cause all the other ones i have seen are much longerSent from my SM-G570Y using Tapatalk Share this post Link to post Share on other sites
CHESTNUTXE 7,299 Posted July 23, 2018 End of the day i got all pistons in and balancer /cover and oil pump will re tension bolts again tomorrow I also noticed that the alt bracket is really short and probly only suits efi cause all the other ones i have seen are much longerSent from my SM-G570Y using TapatalkSent from my SM-G570Y using Tapatalk 1 deankxf reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,299 Posted July 24, 2018 End of the day i got all pistons in and balancer /cover and oil pump will re tension bolts again tomorrow Sent from my SM-G570Y using TapatalkI got the head back ol m8 did a good job on it and didnt charge me as much as i thawtSent from my SM-G570Y using Tapatalk Share this post Link to post Share on other sites
deankxf 20,266 Posted July 24, 2018 can see the pitting in the valve seats from sitting for ages.. (remembers the drop in and run description..) My gemini head from the 20yr old barn storage ran ok, but the head dude is going to re cut all the seats and valves, did old mate say how bad yours were? Share this post Link to post Share on other sites
