Sign in to follow this
slydog
Do XY small bearing 9" axles fit BW housings.
I have a issue where I need to shorten my BW diff about 50mm each side.Now a mate has 2 small bearing XY axles he will give me if needed but I'll only take em if they fit my needs.So basically do the backing plates and all that stuff fit and can I keep my current disc brake set-up as is?
I ll go ahead and shorten the diff to suit the new XY axles instead if there gunna fit in there no mods as it would save me having to get my current axles cut and resplined to suit?
i do the shortening at the hub end cut turn up and refit into the hub its strong im running a set in a corty thats running 11.0 so there working
i have a few that ive done less 40mm ill messure them tomorrow if you want?
send you case i can do that to $300 might do it cheaper if you want mates rates :)
