car10001 52 Posted July 4, 2018 Hi Was just wondering plan to buy a ed sedan for a project/weekend car and may drop a 5l into it or will be adding the fairmont features or both. want to ask following incase a ed fairmont full harness or ed fairmont/nc fairlane 5l full harness can’t be found. 1. can a el fairmont/nl fairlane harness be made to fit the earlier e series dash with a few mods by checking diagrams out and soldering new plugs on to get the earlier e series cluster/climate control/trip computer working. 2. Can the later e series electric cruise control be made to work with the ea-ed steering wheel and ifso what do you need to do to make it work. 3. Could the power and economy switch in the early e series be made to work in direction it would have with original early e series harness and ecu. guess if you use the el harness with ed ecu that the switch wouldn’t get reversed. 4. Could the ed climate control panel and sensors be made to work with the el harness with a few mods, the trip computer and cluster could easily be made to work by soldering new plugs and running a wire to temp sensor same with tail lights. thanks for any help Share this post Link to post Share on other sites
deankxf 20,231 Posted July 4, 2018 why not just buy an ED 5 litre fairmont? Share this post Link to post Share on other sites
hendrixhc 10,918 Posted July 5, 2018 Theres been a couple in SA for sale for some time now. Share this post Link to post Share on other sites
