Outback Jack 6,352 Posted June 25, 2018 Hey guys... After looking at a few options to satisfy my mod bug...Decided to try N2O..... Have purchased these....Look at this on eBay http://www.ebay.com.au/itm/192245872217 Look at this on eBay http://www.ebay.com.au/itm/142306329222 That should be a complete wet 75-125hp NOS 10lb bottle set up and an NX purge valve....Oh.... and got my NOS kit from rocket ind for $650...not price on a that link. I got last one. I wanted power but when I want it. Nitrous Oxide is the perfect solution.If only triggered at WOT.... and over 2500rpm... with enough high octane 98 juice.....she's apples.Being a 'wet' system means in injects a ratio of fuel and N2O at one point decided by changable jets. Now I went a V8 kit from Rocket Ind.the reason being.... I want to start at 75hp kick and get a safe tune there.I can go to over 125hp shot... but motor would need mods.. The kit I have is made for a 43psi V8 system..... but there is a chart to help work out nitrous to fuel ratios.250kpa=36psiAt 40psi jets are....Nos... 38 Fuel.....26-28@ 36 psi would be too rich.So I reduce jetting to suit psi and getNos.... 36 Fuel.....24Should be spot on and both jet sizes are the smallest size pairing.Be good for 75hp easy.Then I'll play with it and see where we go from there.75hp is probably 1/2 what it has any how.... bit less but hey..... more later. I don't need a chip.... advanced timing... bad for NOS.... in fact... may have to drop 2 degrees timing to get it to go great at 75hp and 5 degrees at 100hp shot. So pretty much if I can get this all in and filled... we can have some fun... Im going to trigger the NOS at WOT ( wide open throttle ) via a micro switch and run thru an arming switch in cab.... bottle mounted in the rear somewhere.... few ideas... New to NOS so will be learning as I go...... also got to find somewhere that fills NOS bottles......hahaha. Jack. Sent from my GT-S7583T using Tapatalk 5 Valvebouncer, Ando81, bear351c and 2 others reacted to this Share this post Link to post Share on other sites
deankxf 20,266 Posted June 26, 2018 interested in this.. it would be the cheap option for more power (stealthy if mounted under the manifold also) would be nice on the gemini what's the ring gap rule? don't you need wider gaps? 2 CHESTNUTXE and Outback Jack reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,300 Posted June 26, 2018 usualy around 20thou gap Share this post Link to post Share on other sites
Outback Jack 6,352 Posted June 26, 2018 interested in this.. it would be the cheap option for more power (stealthy if mounted under the manifold also) would be nice on the gemini what's the ring gap rule? don't you need wider gaps?Dont know. ...lol usualy around 20thou gapDont know.... lolPlug gap goes to.30-.35I do know timing is retarded 2 degrees for every 50hp of nos.Colder set of plugs may be needed and will take a bit of testing to get right. Right ....after a lot of research and looking around had to grab an MSD 8969 ... RPM activated switch.Cost me $260... but cheap insurance against badly timed N2O bursts. Means I can floor it and as long as Im in my preset rpm 3000-5500... I can operate it by manual switch or WOT micro switch on throttle body.Just creates fail safes against detonation thru leaning etc.Makes using it more controlled and fun. Jets will have to be revised..... looks like its more likely to be aroundN2O.... 38 Fuel......28.Will keep looking at it till I have it spot on. Time for sleep..... been reading ALL day... hehe Jack. Sent from my GT-S7583T using Tapatalk 2 Valvebouncer and deankxf reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,300 Posted June 26, 2018 outback gassa 1 Outback Jack reacted to this Share this post Link to post Share on other sites
Outback Jack 6,352 Posted June 26, 2018 No this is on a seperate red sohc xg falcon I have.... unlicensed and for drags and off road use only as nitrous is not allowed at all in WA and QLD on road cars..... that was forum talk...but I'm pretty sure WA it's not allowed. You can't even have a system in your car with the gas turned off.No system... full stop.Voids Insurance etc etc etc...I just want to play with NItrous.I'm low shotting it until I can build a purpose built nitrous motor.Just balanced well..... nice pistons, rings, mls gasket etc... good valves/springs etc. Will ask Thom, and the 4L sohc brainstrust to help with that one later. For now got my list down to a few parts I need to get started.....- Low fuel pressure cutout switch- Guage to monitor bottle pressure in boot.That will do for now.Will also need later.....-Bottle heater and cover.- N2O and Fuel pressure guages under bonnet.-Fill bottle and run tests on a piece of the old hwy or an airstrip.Back to part hunting....Damn it....but even the more expensive kits you need to buy all the extras.Budget..... what were looking at....$2000 inc all parts,gas and dyno test.That can do up to 100hp shot of NOS safely on standard ecu etc.Mine already has intake and exhaust mods done.Power @ 75hp starter shot.... maybe 200-225rwhp if lucky at WOT.Nitrous motor.. Mates rates+parts.$1500But that will huff a 150hp+ shot all day long..maybe more at high rpm.... making the xg hopefully around 300rwhp+ at WOT.So at $3.5K, thats some serious on tap mojo.JackSent from my GT-S7583T using Tapatalk 3 bear351c, Valvebouncer and Ando81 reacted to this Share this post Link to post Share on other sites
bear351c 10,270 Posted June 26, 2018 3 SlowXh, Outback Jack and CHESTNUTXE reacted to this Share this post Link to post Share on other sites
Outback Jack 6,352 Posted June 26, 2018 Haha Bear..... thats classic! Rocket Ind rang me this morning because I cancelled the 'fly by wire' controller. I will get a refund for it. Nice.So In return for good service.... I ordered ALL my bits off them.Coming are...NOS Bottle guage and 4an adapter...To keep tabs on pressure , 950psi is where its sweet.NOS 30psi fuel pressure switch.....So lowest fuel pressure is 30psi at idle.....will wire to shut whole N2O system if rail pressure drops too low to supply everything... preventing lean out.MSD 8969 RPM controller.This thing rocks. ... will work on anything from Harley to a V10 Dodge Viper. This one stops engagement of N2O at wrong rev ranges.Out of clams now.....and some....Thats all I need now besides bottle warmer and gas for a safe system so I don't break motor....Jack.Sent from my GT-S7583T using Tapatalk 1 Valvebouncer reacted to this Share this post Link to post Share on other sites
Outback Jack 6,352 Posted June 26, 2018 Explains how the system works....I hope... 3 CHESTNUTXE, bear351c and Valvebouncer reacted to this Share this post Link to post Share on other sites
Outback Jack 6,352 Posted June 26, 2018 Wiring for Nos system.... will work out the triggering for RPM window next..... brain fade...... tomorrow.... My custom wiring for wet NOS system.......still needs purge line wiring in there.. but is seperate. At a later stage I may need timing retard control for when the nitrous is boosted up, but over 125hp shot. For now can run a 100hp shot of nitrous with no timing change... as mine is 10btdc standard.Run N2O from 2,500rpm to 5,500rpm.... almost like a cam on tap. Hehe.... nice. Motor is also 8.5 to 1 compression, and I run 95-98 octane unleaded.So that gives me a nice buffer detonation wise. Requirements were 92 octane, less than 15:1 comp and decent condition motor.Also the motors that they are talking about 'pulling timing out of'are like 36 degree advanced V8's.There I can see 2 degrees being taken out every 50hp of NOS there. WOT on the EFI 6 richens the mix AND I'm running a Wet N2O system.I can't see too many problems to be honest..... Jack. 1 CHESTNUTXE reacted to this Share this post Link to post Share on other sites
Ando81 2,949 Posted June 27, 2018 Is that pic taken from “Eleanor” from gone in 60 seconds movie? 3 Valvebouncer, CHESTNUTXE and Outback Jack reacted to this Share this post Link to post Share on other sites
vanJack 43 Posted June 27, 2018 Hey Jack.. am I missing something.. I can't find your Kookabarra thread..? 1 Outback Jack reacted to this Share this post Link to post Share on other sites
bear351c 10,270 Posted June 27, 2018 20 hours ago, Ando81 said: Is that pic taken from “Eleanor” from gone in 60 seconds movie? yes, Mate. (the 2nd one) 2 Ando81 and Outback Jack reacted to this Share this post Link to post Share on other sites
Outback Jack 6,352 Posted June 27, 2018 Hey Jack.. am I missing something.. I can't find your Kookabarra thread..? Heya Van, Nah the Barra requires so many mods that it will ruin a nice Original Outback. So I canned it + $$$. I can play with NOS on another car and have some fun... relatively cheaply... compared to good turbo set up or supercharger. .. going to N2O a 4L falcon with a 100 shot of nos on a budget. Straight into a factory motor. Using a wet system this is easily achievable. Sorry for your Barra loss.... thr one that got away..... hehe. I also did research into bottle filling of NOS.Cryogenic pump system... 2.3K. ..... putting the delivery bottle lower and in hot water and freezing the NOS bottle overnight to be filled.....weigh transfer with scales.... freeebbbiiiieeee..... Now just gotta convince BOC to order me a large bottle of n2o.......... and take it home...... mwahaha..Or they will want to fill there for a premium. Jack. Share this post Link to post Share on other sites
bear351c 10,270 Posted June 27, 2018 Just use and old fire extinguisher........she'll be right. 1 Outback Jack reacted to this Share this post Link to post Share on other sites
Outback Jack 6,352 Posted June 28, 2018 Just use and old fire extinguisher........she'll be right. I was thinking more plastic coke bottle...... she'll hold..... hehe.Might need a fire extinguisher though.... Need some more bits for n2o system but will wait for next pay.Just need fuel pressure guage, teflon paste, fittings and rolls of wire. Starting to plan out where everything is going..... ordered a new soldering iron..... mine must be 20 years old.... 60w temp adjustable. Sweet.Come on Posty!!!Jack.Sent from my GT-S7583T using Tapatalk 2 bear351c and Ando81 reacted to this Share this post Link to post Share on other sites
vanJack 43 Posted June 30, 2018 Right.. ok.. yeah a lot of work.. 1 Outback Jack reacted to this Share this post Link to post Share on other sites
Outback Jack 6,352 Posted July 1, 2018 I have been thinking lately of getting a second car.... rego will suck but just something to drive round if I want to do something to the Outback, like give it a Birthday.I was asked if I wanted a ute from Albany a while back.. will see if its still up for grabs..... think its a BA tray back...had a couple easy fixed probs... coil pack and intake suckin air.Bit ratty but regoed I think.If engine is ok may be new nos toy.I have the option of buying a cheap e series xr8 ( 2.5K) but the barra 6 does it for me and I can get better economy and probably more power for same price. Also seen a few ba/bf xr6 models I might like as a daily.Nos barra?I just have the nasty feeling that I might accidently lunch the outback motor. ... and its all matching numbers. Not that I havent taken precautions set up wise.... but one bad mistake.... bye bye motor.I'll ring about the ute today.Jack.Sent from my GT-S7583T using Tapatalk 1 Valvebouncer reacted to this Share this post Link to post Share on other sites
deankxf 20,266 Posted July 1, 2018 what's the "parts ute" condition? paint it red, stick on some outback stickers? AU engine ? no rego required perhaps(for testing obviously) Share this post Link to post Share on other sites
Outback Jack 6,352 Posted July 1, 2018 what's the "parts ute" condition? paint it red, stick on some outback stickers? AU engine ? no rego required perhaps(for testing obviously)Parts ute is just that... parts for Outback.I reakon I could snavel a nice barra motor to get firewood and go to town.... a hack... so to speak.Just cost me oil, filter, rego, tyres.Dont like to hassle peeps on a Monday......more a Tuesday thing....Hehe.Sent from my GT-S7583T using Tapatalk 1 Valvebouncer reacted to this Share this post Link to post Share on other sites
bear351c 10,270 Posted July 1, 2018 Buy an older XB or XD 351 on Gas, stick it on club reg, cheap as, drive it up to 90 days a year. 1 Outback Jack reacted to this Share this post Link to post Share on other sites
Outback Jack 6,352 Posted July 2, 2018 Buy an older XB or XD 351 on Gas, stick it on club reg, cheap as, drive it up to 90 days a year.Tell ya thr truth Bear... saw a sweet as xd ute with 351 and twin tanks.. just wish I had the cash... 94,000km.Motor fresh. Looks tidy as. 8K.Is what I REALLY want but just wrong timing. I'd part with the Outback to get that.... as long as the numbers matched. Shits me..... lol Sent from my GT-S7583T using Tapatalk Share this post Link to post Share on other sites
bear351c 10,270 Posted July 2, 2018 Yeah, always the way..........When you have the cash and look, there's fark all, when you got no cash......they're everywhere..! 1 Outback Jack reacted to this Share this post Link to post Share on other sites
Outback Jack 6,352 Posted July 2, 2018 Murphys Law of car lovers. ....Bloody things...And... no matter how much you pamper your car.... there will always be some arsehole that sees fit to damage it..... and take NO responsibility. ....even take offence at your suggestion they be more careful.... If ya catch em... pricks...Sent from my GT-S7583T using Tapatalk Share this post Link to post Share on other sites
Outback Jack 6,352 Posted July 2, 2018 The first of the parts arrive.....NX Purge System. I think this thread sealant is teflon for fittings.... not the AN ones... they go in dry.... hehe... for naughty gas. Oh... going to seal this up a bit..... think you'll agree... it's a lovely spot for a spot of NOS.... 1 Valvebouncer reacted to this Share this post Link to post Share on other sites
