Mixalis 266 Posted April 30, 2018 Hi guys, firstly apologies this is not a falcon or a corty, it's my 2012 Ford Focus, but I would much prefer ask you blokes here as I'm not a fan of the crowds that jump on the forums for 'newer cars' lol. In a nutshell, just a povo pack with 18,000km (prev owners bought new and never drove it, picked it up very cheap). As in the title, it cranks over fine but will just turn the motor, occasionally cough and fart, eventually it will start after a few attempts. Once started tho cars 100% fine. Will be fine if you turn off and jump back in car later on in the day. But next day, same issue. I have tried priming pump a few times before starting, no difference. It may be fuel as it only started occurring with the most recent tank, put 95 in it from reputable brand. Problem is I also barely drive it so very slow going thru tank. Previous owners older couple drove 12,000km in 5 years, still serviced it every bloody year ! Thanks in advance! Sent from my iPhone using Tapatalk Share this post Link to post Share on other sites
Valvebouncer 2,389 Posted April 30, 2018 Replace the battery if it hasn’t already been done. 2 Mixalis and gerg reacted to this Share this post Link to post Share on other sites
bear351c 10,270 Posted April 30, 2018 Yep. Been sitting a while between drives, might have a slow earth leakage. try starting her with a jump, first thing in the morning. 2 gerg and Mixalis reacted to this Share this post Link to post Share on other sites
gerg 10,871 Posted April 30, 2018 Yeah simple things first. Modern alternators are soft-start, meaning they don't cut straight in, but slowly ramp up after 5 seconds or so. I've seen it many times trying to jump a Ranger at work, having to be a bit naughty and (briefly) flick the jump cart over to 24 while cranking. The engine fires, then as I quickly flick the jump pack off, it dies again. The alternator hadn't cut in yet so the computer quit with not enough battery volts to run off.This might be what's happening here, as the battery might have enough to crank and fire, but once running, the volts might be too low for the computer to run properly until the alternator cuts in.Sent from my CPH1607 using Tapatalk 2 Mixalis and roKWiz reacted to this Share this post Link to post Share on other sites
Mixalis 266 Posted April 30, 2018 Thank you guys all three of you, that's why I come to this forum first lol. I'll chuck it on the jumpstarter next time I use it, will probably be Wednesday, and get back to you all.You're probably right as the battery hasn't been changed since factory 2012, and cheers Greg for the info on soft start had no idea.Ps Greg corty seems all fixed now, sent you a text it looks like it's the dumbest issue. It seems to be the 9pin to USB cable being plugged in Sent from my iPhone using Tapatalk 3 gerg, Valvebouncer and Outback Jack reacted to this Share this post Link to post Share on other sites
Mixalis 266 Posted May 13, 2018 Thanks for the help guys only got around to this today, threw it on the battery booster and started first go, so going to pick up a new battery. Ford battery did alright, a bit over 6 years in this thing 3 Valvebouncer, gerg and Outback Jack reacted to this Share this post Link to post Share on other sites
bear351c 10,270 Posted May 13, 2018 Aaaaah, 6 years.! Should've have said so earlier.... Lucky if you get 3 years out of a battery these days. 1 gerg reacted to this Share this post Link to post Share on other sites
