Sweet Cream 8 Posted April 8, 2018 (edited) Hi all, My XC was fitted with a slightly modified efi engine some years ago and the I have two inline fuel pumps between the fuel tank and the fuel rail. The guy that put the system together has fitted a fuel pressure regulator in the fuel line after the front pump and before the fuel rail. There's also the standard regulator bolted on to the exit line of fuel rail. I'm spinning my wheels doing upgrades on everything for the first time and feeling my way. I have a new fuel pump regulator (with Gauge) ready to be connected. Question is, do I really need another fuel pump regulator down in the line before the fuel rail? Seems like overkill and complicated. Anybody there with suggestions? Edited April 8, 2018 by Sweet Cream typo Share this post Link to post Share on other sites
Outback Jack 6,352 Posted April 8, 2018 Only need the reg he fitted to suit system.... sure its a regulator inline and not a fuel filter?If theres no return line from it to the fuel tank its not a regulator.Why would you run 2 return lines?Not needed.If both are hooked up then all your fancy stuff and extra pressure means shit because it's all behind a stock regulator at the fuel rail.Sent from my GT-S7583T using Tapatalk Share this post Link to post Share on other sites
Sweet Cream 8 Posted April 8, 2018 Hi Outback Jack, Thanks for the response. It's a funny little bell shaped connector in the line. No return to tank, but it has an adjusting screw on the top, just like a reg, so have no idea what it is. Can't find anyone who knows. I'm connecting another reg in place of the original so thought I'd take the bell out, run the line straight into the rail and connect my new reg in place of the original. Thanks for the assist. Cheers! . Share this post Link to post Share on other sites
xd4.1efisc 34 Posted April 8, 2018 It sounds like a fuel damper, VK/VL Commodores had them. Share this post Link to post Share on other sites
Sweet Cream 8 Posted April 20, 2018 On 4/8/2018 at 3:17 PM, Outback Jack said: Only need the reg he fitted to suit system.... sure its a regulator inline and not a fuel filter? If theres no return line from it to the fuel tank its not a regulator. Why would you run 2 return lines? Not needed. If both are hooked up then all your fancy stuff and extra pressure means shit because it's all behind a stock regulator at the fuel rail. Sent from my GT-S7583T using Tapatalk Thanks Jack, Fixed the problem. It was a faulty Fuel Pressure Regulator. Ripped the old one out and fitted a new Fuel Pressure Regulator with Gauge and adjusted the pressure. The bell shaped thing that was fitted into the fuel line was a Damper and was overkill, so that's also gone. Now she's running as smooth as a sewing machine. The farm next to ours has a cute Kelpie and it goes crazy when the XC bellows up to our mail box, a kilometer away. He must have been missing it - when I test drove the XC to the front gate today for the first time in 6 weeks, the neighbour thought it was great and called me - his dog is going crazy again. Thanks for your comments. Cheers! 3 Outback Jack, bear351c and Valvebouncer reacted to this Share this post Link to post Share on other sites
Sweet Cream 8 Posted April 20, 2018 On 4/9/2018 at 9:51 AM, xd4.1efisc said: It sounds like a fuel damper, VK/VL Commodores had them. Hi, you were right, its damper. I pulled it out as the XF efi engine doesn't really need it. New regulator fitted and all good. Thanks, Cheers! 2 Outback Jack and deankxf reacted to this Share this post Link to post Share on other sites
