SPACK 68 Posted May 17, 2018 I really want to keep the car original, True there are Mods which will make the car, BETTER, but then it wont be what it was..Going to try the 95/98 fuel first then get the Mechanic to check the timing , maybe change the spark plugs again after they were all sooted up.. 1 Outback Jack reacted to this Share this post Link to post Share on other sites
SPACK 68 Posted May 17, 2018 When the car came out in 87 the engine was set up to run on 95 Ron, I dont know if 98 was available back then... Share this post Link to post Share on other sites
SPACK 68 Posted May 18, 2018 Neither the MECHANIC or the AUTO ELECTRICIAN, know where the WIRES from the KNOCK SENSOR goes...ANYONE KNOW or and have a photo..IT ,might solve a lot of problems here...OR is there a section here I can refer too...cheers.. Share this post Link to post Share on other sites
deankxf 20,284 Posted May 18, 2018 1 hour ago, SPACK said: Neither the MECHANIC or the AUTO ELECTRICIAN, know where the WIRES from the KNOCK SENSOR goes...ANYONE KNOW or and have a photo..IT ,might solve a lot of problems here...OR is there a section here I can refer too...cheers.. i think Mr POLSON has the book @Mr Polson 1 SPACK reacted to this Share this post Link to post Share on other sites
Panko 2,480 Posted May 18, 2018 2 hours ago, SPACK said: Neither the MECHANIC or the AUTO ELECTRICIAN, know where the WIRES from the KNOCK SENSOR goes...ANYONE KNOW or and have a photo..IT ,might solve a lot of problems here...OR is there a section here I can refer too...cheers.. so they know where the knock sensor is right? on the front left corner of the head (exhaust side) those wires should go back to the ECU. 1 SPACK reacted to this Share this post Link to post Share on other sites
SPACK 68 Posted May 18, 2018 PANKO..BUT WHERE ON THE ECU...? Any photos?? Share this post Link to post Share on other sites
Mr Polson 10,214 Posted May 18, 2018 i think Mr POLSON has the book [mention=21]Mr Polson[/mention]I sure do, I'll have a look when I get home from workSent from my Pixel using Tapatalk Share this post Link to post Share on other sites
SPACK 68 Posted May 18, 2018 Thank you.....Hopefully this will explain why the engine is IDLING so high, as well... Share this post Link to post Share on other sites
Panko 2,480 Posted May 18, 2018 THE knock sensor wont affect idle. The idle speed screw on the front of the throttle body, and the air/fuel ratio screw on the vane meter is how its tuned. Very fiddly at times. 1 Valvebouncer reacted to this Share this post Link to post Share on other sites
SPACK 68 Posted May 18, 2018 GOT the one on the throttle body screwed right in at the Mo... Share this post Link to post Share on other sites
deankxf 20,284 Posted May 18, 2018 55 minutes ago, Panko said: THE knock sensor wont affect idle. The idle speed screw on the front of the throttle body, and the air/fuel ratio screw on the vane meter is how its tuned. Very fiddly at times. isn't the IAC the thing that sets idle speed? 2 SPACK and Outback Jack reacted to this Share this post Link to post Share on other sites
Mr Polson 10,214 Posted May 18, 2018 isn't the IAC the thing that sets idle speed?The ISC (Idle Speed Control) governs the idle by allowing certain amounts of air to bypass the throttle butterfly - like when AC is engaged or for fast idle on cold starts, but base idle is still set by winding a screw on the throttle body.Sent from my Pixel using Tapatalk 3 Outback Jack, Valvebouncer and Panko reacted to this Share this post Link to post Share on other sites
Crazy2287 1,886 Posted May 18, 2018 There are 2 screws on throttle body. One sets the butterfly so it never closes completely and this is to stop the butterfly "sticking" in the closed position. Aka it improves pedal feel. The other is an air bypass. For tuning idle both the pip wire and the iac should be disconnected as both will alter the idle speed. And the eng should be fully warmed up. If eng is fully warmed up and the iac is still altering idle speed, (and ac is off) then that leads me back to the clt sensor as possibly faulty. A wideband sniffer can be used for adjusting the afm. And why are they playing with the knock sensor? Just unplug it if you think it's an issue and it will stop interfearing with the tune. I have never had the knock sensor cause any issues (and I've had a lot of issues) and tbh i don't know if they even worked from factory. I know what does work. An aftermarket ecu. And all future eng issues can usually be diagnosed by plugging in a laptop and "oh, the ECU isn't getting 'x'. So I'll fix that" You can also enjoy better fuel economy and can fuck off the pesky afm and say hello to a couple extra ponies. All without changing the appearance at all if you are tricky and gut the afm and leave it installed. I think they make plug in megasquirts now that use the factory harness and connector. Just add EGO and a MAP line. 4 Outback Jack, SPACK, Thom and 1 other reacted to this Share this post Link to post Share on other sites
SPACK 68 Posted May 18, 2018 Thanks for that bit of info CRAZY 2287, For all I know, the KNOCK SENSOR was never hooked up. I only saw 1 SCREW on the throttle body, did not know there were 2.I will have another look. These after market COMPUTER,S...Whom sells them and are they up here in QUEENSLAND/BRISBANE? Share this post Link to post Share on other sites
SPACK 68 Posted May 19, 2018 Ok, went and had a look at the accelerator STOP, near the throttle body and there is a ADJUSTMENT SCREW there, wound that back a bit, opened the AIR screw on the throttle body and its at around the 1000 rpm mark, went and put 25 dollars in of 98 ron...took it for a 15 min drive and it seems ok...however when I " GET UP IT"...there is a definite miss, so something is still not right...However ITS A LOT BETTER.... Share this post Link to post Share on other sites
Crazy2287 1,886 Posted May 19, 2018 A google got me here:https://www.diyautotune.com/support/tech/install/ford/ford-eec-iv/ But i thought i saw another mod had done one that was even more "Plug n play" and i'm pretty sure the XF used Ford EEC-IV ECU but get someone to confirm. Also here:https://www.diyautotune.com/support/tech/hardware/diypnp/available-models/ Which leads Here:https://www.diyautotune.com/product/diypnp-ford-60-pin-eec-iv-unassembled-kit-no-connector/ 1 SPACK reacted to this Share this post Link to post Share on other sites
SPACK 68 Posted May 19, 2018 Wow, that does not look too bad at all..something to look into....especially as it hooks up to the original computer,, Share this post Link to post Share on other sites
bear351c 10,270 Posted May 20, 2018 Fuel pump and regulator OK? My ZL used to get up and go on 98. Ran shit on 95. 2 Outback Jack and SPACK reacted to this Share this post Link to post Share on other sites
SPACK 68 Posted May 20, 2018 I put another $25.00 in 98 ron in the old girl and took her for another run, the missing seems to be gone, and the idling is at about 900 rpm. So maybe it needs a good long run for the COMPUTER to LEARN..tell you what, I HAVE NOT DRIVEN THE OTHER 2 FORDS since I got this back..lol..By the way guys, I need to CLEAN my headlights...heard about tooth paste and 1200 sand paper..or is there a better way of doing this?? Share this post Link to post Share on other sites
SPACK 68 Posted May 20, 2018 On 5/16/2018 at 7:03 PM, Mr Polson said: Good to hear it's sorted mate! Added the photo you shared on Facebook to your post for you Sent from my Pixel using Tapatalk THANK YOU.................. Share this post Link to post Share on other sites
Mr Polson 10,214 Posted May 20, 2018 I put another $25.00 in 98 ron in the old girl and took her for another run, the missing seems to be gone, and the idling is at about 900 rpm. So maybe it needs a good long run for the COMPUTER to LEARN..tell you what, I HAVE NOT DRIVEN THE OTHER 2 FORDS since I got this back..lol..By the way guys, I need to CLEAN my headlights...heard about tooth paste and 1200 sand paper..or is there a better way of doing this??You've got glass headlights, so the toothpaste or sanding won't work, that's for more modern cars with the plastic headlight lensesSent from my Pixel using Tapatalk 3 SPACK, Outback Jack and Valvebouncer reacted to this Share this post Link to post Share on other sites
Crazy2287 1,886 Posted May 20, 2018 You'll have to pull then out and pop the glass off the front. Clean the glass using normal glass cleaning techniques. Be careful cleaning the reflector. Use a soft cloth as it will mark easily. 4 bear351c, SPACK, Valvebouncer and 1 other reacted to this Share this post Link to post Share on other sites
Panko 2,480 Posted May 20, 2018 @Crazy2287 mate one day id love to have a lengthy chat with you about running aftermarket ECU with my XF. I have bookmarked the links you posted above so i can do some reading etc. they seem a cheaper option than the way i was going to go. I was going go with a Stinger Performance Plug and Play ECU (for US EECIV Fords), which was going to set me back over $1000AUD by the time i got it here. but only 2 pins would have to be changed, and internally its a Megasquirt. the beauty was it would literally plug in and work. 1 SPACK reacted to this Share this post Link to post Share on other sites
