bear351c 10,270 Posted March 15, 2018 Cant find the rebuild kit for this little fukka...... Looks like a 4150 body. 600cfm, vac sec, squarebore. Any ideas...?? Share this post Link to post Share on other sites
bear351c 10,270 Posted March 15, 2018 Never mind, the Yanks have it sussed...... Share this post Link to post Share on other sites
gerg 10,871 Posted March 15, 2018 Cant find the rebuild kit for this little fukka...... Looks like a 4150 body. 600cfm, vac sec, squarebore. Any ideas...??It's a ford part number, D8PE means it's probably off a 78 Bronco or F-series. I bought a shitter like that with similar part numbers. Let me check in my junk storage unit (I mean "work"shop).Sent from my CPH1607 using Tapatalk 1 bear351c reacted to this Share this post Link to post Share on other sites
gerg 10,871 Posted March 15, 2018 I can tell you a bit about it if yours is like mine. Any pics of the idle screws? Sent from my CPH1607 using Tapatalk 1 CHESTNUTXE reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,300 Posted March 25, 2018 i had a similar carb 2 barrel factory ford replacement for 375 cfm,or 289 windsor,it had a rare throttle plate shaft which hi po factory engines had,a bloke fully reconditioned it for free as long as he could have the shaft and put a std one in there. Share this post Link to post Share on other sites
gerg 10,871 Posted March 25, 2018 i had a similar carb 2 barrel factory ford replacement for 375 cfm,or 289 windsor,it had a rare throttle plate shaft which hi po factory engines had,a bloke fully reconditioned it for free as long as he could have the shaft and put a std one in there.That would've been an Autolite 2100 (half of a 4-barrel). Great standard carby.These are Holley-built Ford replacement carbs with specially-drilled bodies for reverse idle (winding in the mixture screw makes it richer).Sent from my CPH1607 using Tapatalk 1 CHESTNUTXE reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,300 Posted March 25, 2018 Yeah it was a 375 holley Share this post Link to post Share on other sites
gerg 10,871 Posted March 25, 2018 Yeah it was a 375 holleyOh ok, got it. Not factory fitted, but service replacement.Sent from my CPH1607 using Tapatalk Share this post Link to post Share on other sites
CHESTNUTXE 7,300 Posted March 26, 2018 yep,pretty rare. Share this post Link to post Share on other sites
