Mark Bretherton 26 Posted February 12, 2018 From Mark Sent from my HUAWEI Y360-U03 using Tapatalk Share this post Link to post Share on other sites
deankxf 20,286 Posted February 12, 2018 38 minutes ago, Mark Bretherton said: From Mark Sent from my HUAWEI Y360-U03 using Tapatalk Pic worked. .post up some more. .i think people had cut a bit of the bonnet ribs out to make clearance for the barra Share this post Link to post Share on other sites
Mark Bretherton 26 Posted February 12, 2018 Thinking phase 5 scoop fitted and painted 750$Sent from my HUAWEI Y360-U03 using Tapatalk 1 deankxf reacted to this Share this post Link to post Share on other sites
Mark Bretherton 26 Posted February 12, 2018 Thinking phase 5 scoop fitted and painted 750$Sent from my HUAWEI Y360-U03 using TapatalkInside sguare edge has to be removed see fuel burn is from holley . I mite leave open no scope expose plenum and paint black and follow color theme.Sent from my HUAWEI Y360-U03 using Tapatalk 1 bear351c reacted to this Share this post Link to post Share on other sites
deankxf 20,286 Posted February 12, 2018 if you are careful removing the ribbing there's probably enough clearance to fit it under the bonnet, probably wont need to even remove the full brace, just cut in half and try it.. phase 5 scoop wide enough? or off set, i don't think you'd need a hole in the bonnet, but then i haven't seen many carby 4 litres, there has been a few though. what happened with the fire? lucky it was fairly small Share this post Link to post Share on other sites
Mark Bretherton 26 Posted February 12, 2018 if you are careful removing the ribbing there's probably enough clearance to fit it under the bonnet, probably wont need to even remove the full brace, just cut in half and try it.. phase 5 scoop wide enough? or off set, i don't think you'd need a hole in the bonnet, but then i haven't seen many carby 4 litres, there has been a few though. what happened with the fire? lucky it was fairly smallBack firers while tuning .3.2 ml expose after measuring eb manifold should of shaved before fitting and deepen bowl COST!!Sent from my HUAWEI Y360-U03 using Tapatalk Share this post Link to post Share on other sites
bear351c 10,270 Posted February 12, 2018 You thinking of cutting the whole "Y" piece in between the white parts..?? Share this post Link to post Share on other sites
Mark Bretherton 26 Posted February 13, 2018 You thinking of cutting the whole "Y" piece in between the white parts..??YesSent from my HUAWEI Y360-U03 using Tapatalk Share this post Link to post Share on other sites
Mark Bretherton 26 Posted February 13, 2018 YesSent from my HUAWEI Y360-U03 using TapatalkFound boiler maker to remove brace then trail fit bonnet and if that does not work remove more then rubber side like shaker full lengh cost NILL$ what my idea for other that want same .Sent from my HUAWEI Y360-U03 using Tapatalk Share this post Link to post Share on other sites
351XD_Fairmont 604 Posted February 14, 2018 I'd try cutting half of it out and checking clearance before removing the whole thing. By the looks of it you'll only need to remove around half and will have the clearance needed, nice setup too mate 1 bear351c reacted to this Share this post Link to post Share on other sites
bear351c 10,270 Posted February 14, 2018 Yeah, I'm a little concerned about how much rigidity you will lose, if you cut the whole thing out. The bonnet may twist or warp. Tell your boily to do it in small pieces, and try it for fit, with the minimum amount of metal removed. Share this post Link to post Share on other sites
Mark Bretherton 26 Posted February 14, 2018 Yeah, I'm a little concerned about how much rigidity you will lose, if you cut the whole thing out. The bonnet may twist or warp. Tell your boily to do it in small pieces, and try it for fit, with the minimum amount of metal removed. Cuttings between masking tape then stickaflex brace parallel to plenum for support refer to early bonnet photo.Sent from my HUAWEI Y360-U03 using Tapatalk 1 bear351c reacted to this Share this post Link to post Share on other sites
