CHESTNUTXE 7,304 Posted February 4, 2018 I just got home from picking up this cortina engine but i reckon its a bit of a jigsaw engine,lets sus it out.from what i can first see its a 84da block with c2 head,but has xe dizzy stlye,or could possibly be a leaded 84 xf engine,it also has 82da manifold,or this could be the year the first cast numbers were done ,and a very large or bigger than mine water pump pulley,it also has a jg23 engine code,mounts could be f100 ?? not sure but chime on in with what they are ,so lets put it on the stand and start to ripp it down. Share this post Link to post Share on other sites
deankxf 20,279 Posted February 4, 2018 Engine mount rubber looks like xr falcon... not sure about the bracket. .. @Thom would probably know more as he would have had to mix n match for the xp 1 CHESTNUTXE reacted to this Share this post Link to post Share on other sites
Thom 6,650 Posted February 4, 2018 Engine mount rubber looks like xr falcon... not sure about the bracket. .. [mention=43]Thom[/mention] would probably know more as he would have had to mix n match for the xpYour right on the engine mounts they are xr/xt, was this engine In an early falcon? Having those mounts and the early water pump make me think so as the clutch fan water pump will hit the radiator in an early bird, and the bigger pulley makes sense for a car with 3.5s (most early falcon sedans had 3.5s with xp Fairmont having 3.2s and utes having 4.11s) and no overdrive you want to slow the water pump down at cruise speeds to stop it from cavitating the water, you may find the water pump pulley is from a pre xflow (that's where I got mine from an xa pre xflow 250) to help keep it cool on the highway 2 CHESTNUTXE and gerg reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,304 Posted February 4, 2018 Your right on the engine mounts they are xr/xt, was this engine In an early falcon? Having those mounts and the early water pump make me think so as the clutch fan water pump will hit the radiator in an early bird, and the bigger pulley makes sense for a car with 3.5s (most early falcon sedans had 3.5s with xp Fairmont having 3.2s and utes having 4.11s) and no overdrive you want to slow the water pump down at cruise speeds to stop it from cavitating the water, you may find the water pump pulley is from a pre xflow (that's where I got mine from an xa pre xflow 250) to help keep it cool on the highway Ok an hour into stripdown sees a hf7 head in good cond too even coolant was green and no rusted bolts check out the support bars on the sump ? Olm8 i bought it off said it had a c4 on the ass of it when he got itSent from my SM-G570Y using Tapatalk Share this post Link to post Share on other sites
CHESTNUTXE 7,304 Posted February 4, 2018 Ok an hour into stripdown sees a hf7 head in good cond too even coolant was green and no rusted bolts check out the support bars on the sump ? Olm8 i bought it off said it had a c4 on the ass of it when he got itSent from my SM-G570Y using TapatalkPicturesSent from my SM-G570Y using Tapatalk Share this post Link to post Share on other sites
CHESTNUTXE 7,304 Posted February 4, 2018 PicturesSent from my SM-G570Y using TapatalkBy the black forest in the chambers i would say this thing had the holley treatment as manifold ports are blocked off too she is also a 020 and no lip on the bore Sent from my SM-G570Y using Tapatalk Share this post Link to post Share on other sites
CHESTNUTXE 7,304 Posted February 4, 2018 By the black forest in the chambers i would say this thing had the holley treatment as manifold ports are blocked off too she is also a 020 and no lip on the bore Sent from my SM-G570Y using TapatalkHaha rollmaster double chain this thing might have a cam in it Sent from my SM-G570Y using Tapatalk Share this post Link to post Share on other sites
deankxf 20,279 Posted February 4, 2018 manifold throat looks ported(for adaptor plate?) looks like a good engine, may even have a decent cam in it? take the oil slinger off and see if it has adjustable keyway on the lower timing gear Share this post Link to post Share on other sites
Thom 6,650 Posted February 4, 2018 By the black forest in the chambers i would say this thing had the holley treatment as manifold ports are blocked off too she is also a 020 and no lip on the bore Sent from my SM-G570Y using TapatalkThose look like early falcon support bars bit they I have seen them as late as xb 1 CHESTNUTXE reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,304 Posted February 4, 2018 manifold throat looks ported(for adaptor plate?) looks like a good engine, may even have a decent cam in it? take the oil slinger off and see if it has adjustable keyway on the lower timing gearAlso note on end of rod its been balanced compard to left stocker,@lso 3 bolt balancer and 2 piece rear main seal mystery engine,bearings look ok also crank looks goodSent from my SM-G570Y using Tapatalk Share this post Link to post Share on other sites
CHESTNUTXE 7,304 Posted February 4, 2018 unsure on cam Share this post Link to post Share on other sites
CHESTNUTXE 7,304 Posted February 4, 2018 unsure on camHas some print but stocker i think also dipstick was bent slightly but done perfect to fit in snug placeSent from my SM-G570Y using Tapatalk Share this post Link to post Share on other sites
CHESTNUTXE 7,304 Posted February 4, 2018 pistons are the 29 cc variety Share this post Link to post Share on other sites
deankxf 20,279 Posted February 4, 2018 cam spec might be in here, edit.. reading further? no idea 1 CHESTNUTXE reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,304 Posted February 4, 2018 also chamber is c2 high swirl i have read somewhere,i just cleaned this one up a tad so we can look ,all looks pretty good,id say maybe 50/100,000km maybe ? maybe less,im gunna measure the cc of the c2 unless someone knows off the bat but im guessing 48cc Share this post Link to post Share on other sites
deankxf 20,279 Posted February 4, 2018 head chamber looks different to i remember around the exhaust valve 1 CHESTNUTXE reacted to this Share this post Link to post Share on other sites
deankxf 20,279 Posted February 4, 2018 is that a crack between the valves? 2 CHESTNUTXE and Valvebouncer reacted to this Share this post Link to post Share on other sites
deankxf 20,279 Posted February 4, 2018 cracked? 2 Valvebouncer and CHESTNUTXE reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,304 Posted February 4, 2018 nah i just checked on a dirty one,its the same its like a small ported line that goes from chamber to chamber ? Share this post Link to post Share on other sites
Ando81 2,949 Posted February 4, 2018 I’ve been told it’s pretty common to see them crack through there as there isn’t much meat to hold it all together. Share this post Link to post Share on other sites
CHESTNUTXE 7,304 Posted February 4, 2018 it aint cracked all six are identical Share this post Link to post Share on other sites
CHESTNUTXE 7,304 Posted February 4, 2018 i will check the main size tomorrow ,then see if the crank needs a linish/polish ol,m8 does it for $50,also buy some kero and degreaser,then start my cleaning process. Share this post Link to post Share on other sites
ando76 4,354 Posted February 4, 2018 It is a crack. Very common to have them crack there. It's not an issue tho and will work fine. If it is an unmachined c2 it should cc at 42cc, but could be less if it's had a hair cut. No evidence of anyone laying the chamber walls back so I'd say it will be 42cc or less. 3 matt_lamb_160, gerg and Valvebouncer reacted to this Share this post Link to post Share on other sites
gerg 10,871 Posted February 4, 2018 Cam comes up as a stocker Dynotec from Precision International. Pretty standard engine reco shop fitmenthttp://www.precisionintl.com.au/StockSearch.aspx?Search=CM250&Cat=29Sent from my CPH1607 using Tapatalk 1 steve mcqueen reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,304 Posted February 4, 2018 thanks for that gerg it looks in good cond,im gunna get the magnifying glass on the camera and show yuz that (crack) is like a transfer slot . Share this post Link to post Share on other sites
