car10001
lpg converter
3 posts in this topic
hi
wish to make the au coolant tank fit a ef and while it looks like it can be made to fit the gas converter is in the way.
how would you be able to move it to make room
could do whats in first picture but itd be in way if you ever took the engine out and probably wouldnt quite clear the upper manifold for a possible v8 conversion
so was wondering if you could modify a ef/el lpg converter bracket and mount it somewhere in front of the coolant tank where the au abs pump would normally be like these pictures. would it be a problem with standards.
any help would be really good
thanks
Eb to au coolant tanks (v8 and 6 cyl) are all interchangeable without any modification (they are all almost identical) the first one you have pictured is a ba and newer tank they are different
