X-F250 182 Posted January 23, 2018 Hey fellas I've had a problem with my NC. Been driving fine since I got it, although the dash lights flicker a little sometimes (probaby due for a new alternator). Last night, I parked in the driveway and locked up the car. When I went to leave for work this afternoon the car simply wouldn't start. Figuring the battery had run low I swapped it out for my spare, but there was no difference. Right now, the only things that seem to work are the interior lights, boot release and the smartlock light on the dash. When I turn the key over there's no dash lights, power windows, etc. Checked the engine earth and it seems fine. Thanks in advance,John Sent from my SM-G930F using Tapatalk Share this post Link to post Share on other sites
deankxf 20,287 Posted January 23, 2018 could be ign switch even. try it a heap of times, if it comes good, its likely the switch. 2 X-F250 and user272 reacted to this Share this post Link to post Share on other sites
X-F250 182 Posted January 23, 2018 could be ign switch even. try it a heap of times, if it comes good, its likely the switch. Cheers, Dean. No luck with it coming good but I swapped the ignition relay out for one I know works and it didn't help so it looks like I'll be looking at a new ignition switch.Sent from my SM-G930F using Tapatalk Share this post Link to post Share on other sites
Outback Jack 6,352 Posted January 23, 2018 Might just be battery, once smartlick goes under a certain voltage it wont unlock like most immobilizers.Think its about 7V.Cheap easy fix first?Sent from my GT-S7583T using Tapatalk Share this post Link to post Share on other sites
X-F250 182 Posted January 23, 2018 Might just be battery, once smartlick goes under a certain voltage it wont unlock like most immobilizers.Think its about 7V.Cheap easy fix first?Sent from my GT-S7583T using TapatalkThanks Jack, but it's definitely not the battery. I swapped the new battery out of my Brother's EA, NC still wouldn't start but the EA started fine with the battery out of the Fairlane.Sent from my SM-G930F using Tapatalk 1 Outback Jack reacted to this Share this post Link to post Share on other sites
deankxf 20,287 Posted January 23, 2018 Ign switch wouldn't be my first thing to change because they are a prick to do. .. What else can cause the symptoms Share this post Link to post Share on other sites
Thom 6,650 Posted January 24, 2018 Sometimes the body control module let's go, if you hit the dash just above the handbrake handle you can sometime shock them into working, if that works I suggest you start hunting for a new one 1 bear351c reacted to this Share this post Link to post Share on other sites
X-F250 182 Posted January 25, 2018 Sometimes the body control module let's go, if you hit the dash just above the handbrake handle you can sometime shock them into working, if that works I suggest you start hunting for a new one Gave the dash a solid belting, still no luck. I'll have a talk with the old man about borrowing some bits off my brother's wrecked EB wags, getting tired of slumming it in his EA GL.Sent from my SM-G930F using Tapatalk Share this post Link to post Share on other sites
bear351c 10,270 Posted January 26, 2018 Yeah, I'm with Thom. punch dash panel in front of left knee. My NF had similar issues, (I think) it's the Smartlock controller in the box, that gets a dry solder joint. Boxes are different colours in the NF range, depending on the options your car has, if you find that this is the problem. Mine was green, but, can get pink or purple as well, I reckon. No cranking at all..? Car definitely in Park? Bypass Neutral safety switch on trans. Bypass starter motor solenoid.? Share this post Link to post Share on other sites
SPArKy_Dave 8,870 Posted January 26, 2018 If the windows are not working, it's a Smartlock relay... Sometimes you can remove the oxidisation off the relay contacts by rapidly jiggling the Accessories and/or interior light fuse in and out. Failing that, you'll have to remove the Smartlock module and do it the hard way. Share this post Link to post Share on other sites
