CHESTNUTXE 7,308 Posted January 15, 2018 Hey what is the difference between a std falcon crossflow and a cortina engine,is it the dipstick location ? i heard somewhere the sump and main caps are different as well ? can anyone shed some light on this and can it be put back to a falcon engine. Share this post Link to post Share on other sites
Mr Polson 10,214 Posted January 15, 2018 Sump design is reversed - drops down at the back rather than front. Pickup is different to suit.Most blocks have two casts for dipstick, one drilled for Falcons if used in Falcon, other used for Cortina.Sent from my Pixel using Tapatalk 3 Stumps, CHESTNUTXE and Valvebouncer reacted to this Share this post Link to post Share on other sites
ESPSIX 143 Posted January 15, 2018 And one of the main caps have a threaded hole for the oil pump pick up support, in cortina. 1 CHESTNUTXE reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,308 Posted January 15, 2018 ok so if i just put a falcon sump on it and used the falcon pick up it can be changed back yeah ? Share this post Link to post Share on other sites
CHESTNUTXE 7,308 Posted January 15, 2018 also can the later xf est style dizzys be put in a earlier crossflow block eg,, 82 or 80 da ? Share this post Link to post Share on other sites
gerg 10,871 Posted January 15, 2018 Sump design is reversed - drops down at the back rather than front. Pickup is different to suit.Most blocks have two casts for dipstick, one drilled for Falcons if used in Falcon, other used for Cortina.Sent from my Pixel using TapatalkYes correct, the blocks have two pads cast into them, Falcons only have the front one drilled, Cortinas have both drilled with the front one plugged by a ball bearing And one of the main caps have a threaded hole for the oil pump pick up support, in cortina.The main cap itself is the same but the bolts are special ones with 5/16" studs sticking out of the heads for the pickup. I remember this from having to remove the main cap bolts upside down with the engine on a hoist out in a paddock. I think it's #5 cap from memory (sorry it's been 20 years since i saw it) ok so if i just put a falcon sump on it and used the falcon pick up it can be changed back yeah ?I did this in reverse: a Falcon block into my Corty. Only differences are dipstick tube drillings.I just used a banjo fitting on the sump plug as a dipstick tube. You should take the main bolts out and put the normal bolts back in just to keep all the Cortina bits together. That way, any engine can be converted with those bits.Sent from my CPH1607 using Tapatalk Share this post Link to post Share on other sites
ESPSIX 143 Posted January 16, 2018 I knew it was something like that with the pick up tube, but it's been 30 years since I owned a Corty. but I'll disagree with you on the dipstick tube hole in the block. ive got a XD sitting here at the moment with a ball bearing in the rear hole, and it's a numbers matching car. 1 gerg reacted to this Share this post Link to post Share on other sites
gerg 10,871 Posted January 16, 2018 I knew it was something like that with the pick up tube, but it's been 30 years since I owned a Corty. but I'll disagree with you on the dipstick tube hole in the block. ive got a XD sitting here at the moment with a ball bearing in the rear hole, and it's a numbers matching car.Forgot to mention mine was an XF block, which obviously didn't need the rear drilling as by then they'd stopped making Cortys. So you're saying that up to the end of the TF & XD, all blocks were drilled the same for both cars? Makes sense now (I stand corrected) Sent from my CPH1607 using Tapatalk Share this post Link to post Share on other sites
CHESTNUTXE 7,308 Posted January 16, 2018 so dipstick is the same on both ? Share this post Link to post Share on other sites
Stumps 311 Posted January 16, 2018 No cortina's dipstick is further back and iirc the est dizzy has a different shaft size to the earlier block, i recently fitted an early xf dizzy to my cortina with an msd 6al, works a treat compared to the old points piece of crap. 1 CHESTNUTXE reacted to this Share this post Link to post Share on other sites
Valvebouncer 2,389 Posted January 16, 2018 Not a physical difference but helps to figure out where the block came from, cortina engine numbers start with CG whereas falcons were JG or JH. 1 CHESTNUTXE reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,308 Posted January 16, 2018 Im just looking at buying one but it has cortina mounts jg23 number and falcon sump so umm err Share this post Link to post Share on other sites
Mr Polson 10,214 Posted January 16, 2018 Not a physical difference but helps to figure out where the block came from, cortina engine numbers start with CG whereas falcons were JG or JH.Or JL - utes/vans on the secondary line got that.Sent from my Pixel using Tapatalk 2 CHESTNUTXE and Valvebouncer reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,308 Posted January 16, 2018 it has c2 head Share this post Link to post Share on other sites
77xcfalcon 177 Posted January 17, 2018 I’m thinking of buying the same one I think just for the head. Sent from my iPad using Tapatalk 1 CHESTNUTXE reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,308 Posted January 17, 2018 I reckon $90 is fair 1 77xcfalcon reacted to this Share this post Link to post Share on other sites
77xcfalcon 177 Posted January 17, 2018 He did pretty much say it’s rooted, I was thinking 75Sent from my iPad using Tapatalk 1 CHESTNUTXE reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,308 Posted January 17, 2018 Its yours 1 Slow250XC reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,308 Posted January 30, 2018 lol i bought it,mainly for the head ,got it for $100 ,will give me something to play with ,will strip it down and see if its been corty converted. Share this post Link to post Share on other sites
77xcfalcon 177 Posted January 30, 2018 Nice one, he wanted 130 when I offered him 75, but I’m in no rush for engine parts yet, still got to finish panel work. Saying that if you want to swap the c2 head for a c1 let me know.Sent from my iPad using Tapatalk Share this post Link to post Share on other sites
CHESTNUTXE 7,308 Posted January 30, 2018 i offerd 80 and he wanted 100 Share this post Link to post Share on other sites
