jca25 1,034 Posted January 9, 2018 Hi guys i'm help a mate with building a street stock for racing at speedway, its a au but with the class he can not run the au ecu as not aloud the vct, was going to us the wiring harness from the car and strip off what we don't need but need to know what ecu will mate up to it i was thing ef ?? Was hoping someone who has put a barra in a xf could shed so light on it for me Cheers Jason Share this post Link to post Share on other sites
Thom 6,642 Posted January 9, 2018 Can you use an au non vct ecu? If not you would need to swap all the sensors and wiring loom to ef to run an ef ecu Share this post Link to post Share on other sites
jca25 1,034 Posted January 9, 2018 I done a bit more looking into the class rules and you need to run a ea or eb ecu so i take it i will need the harness to suit it or being i am making it full stand alone can i use the au harness Share this post Link to post Share on other sites
Thom 6,642 Posted January 9, 2018 You will have to swap to an eb or ed harness as the ecu plug for an au only fits an au harness 1 Valvebouncer reacted to this Share this post Link to post Share on other sites
jca25 1,034 Posted January 9, 2018 Ok cool can do then i thought i had read somewhere one of the ecu can be swapped but two wires need swapping Sent from my SM-G950F using Tapatalk Share this post Link to post Share on other sites
Thom 6,642 Posted January 9, 2018 Ok cool can do then i thought i had read somewhere one of the ecu can be swapped but two wires need swapping Sent from my SM-G950F using TapatalkThe problem with the au and ef ecu is they have an extra row of pins due to running coil packs also ef and au use different plugs from each other as the ecu aren't compatible Share this post Link to post Share on other sites
jca25 1,034 Posted January 9, 2018 Ok so how would u go with the au motor having coil packs but the eb running a dizzy still Sent from my SM-G950F using Tapatalk Share this post Link to post Share on other sites
Thom 6,642 Posted January 9, 2018 Au still has the dizzy hole, it just has a plug that drives the oil pump, pull it out and an e series dizzy goes straight in 2 Valvebouncer and jca25 reacted to this Share this post Link to post Share on other sites
jca25 1,034 Posted January 9, 2018 Nice didn't know that will have to do a bit more looking into on this motor Sent from my SM-G950F using Tapatalk Share this post Link to post Share on other sites
Valvebouncer 2,389 Posted January 9, 2018 As Thom said. The only other difference is the block, the bolt holes for the reinforcement brackets that run from the side of the block down to the bottom of the trans bellhousing have been filled and it’s different around the top where the p/s pump go. Nothing that can’t be fixed though. I’d keep the AU sump if you can. 1 jca25 reacted to this Share this post Link to post Share on other sites
jca25 1,034 Posted January 9, 2018 I'll be keeping the whole au motor as its going in a au car, the street strocks are just a cheap class to run not aloud any real work as they go both ways on the track but to run the later models cars u have to have the ecu locked and sealed using a ea or eb ecu which i have just found out, its been enough fun building the excel 1 Valvebouncer reacted to this Share this post Link to post Share on other sites
jca25 1,034 Posted January 10, 2018 Ok guys hit the wreckers up can get a ecu off them but they cut the harnesses up when they pull the motors, next question is do any of yous guys have a harness out of a ea/eb u don't want?? Share this post Link to post Share on other sites
Thom 6,642 Posted January 10, 2018 You'll also want all the sensors and dizzy to match the ecu Share this post Link to post Share on other sites
jca25 1,034 Posted January 10, 2018 Oh joy this is going to be a bundle of joy to get running Sent from my SM-G950F using Tapatalk Share this post Link to post Share on other sites
Thom 6,642 Posted January 10, 2018 Its not too bad to swap the loom and all the sensors if you pull the intake off and there is enough room in the log manifold wiring to re arrange it to suit bbm 1 jca25 reacted to this Share this post Link to post Share on other sites
jca25 1,034 Posted January 10, 2018 Its not too bad to swap the loom and all the sensors if you pull the intake off and there is enough room in the log manifold wiring to re arrange it to suit bbmOk cool from what i have read we can use the early model intake plus being a dirt track car we dont need all the sensors just the bear minimum Sent from my SM-G950F using Tapatalk Share this post Link to post Share on other sites
Valvebouncer 2,389 Posted January 10, 2018 You might find it easier getting a whole car. There are plenty of flogged out ea/ebs you could pick up cheaper than buying all the individual bits from wreckers 1 jca25 reacted to this Share this post Link to post Share on other sites
jca25 1,034 Posted January 10, 2018 You might find it easier getting a whole car. There are plenty of flogged out ea/ebs you could pick up cheaper than buying all the individual bits from wreckers Yea I'm going to look around for one but the local wrecker here is good if u are a racer and put his name on the car he gives u the parts or at one really good price so far for my daughter's car we haven't paid for the parts for it which has been good Sent from my SM-G950F using Tapatalk Share this post Link to post Share on other sites
