bear351c 10,270 Posted January 5, 2018 Anyone got a measurement of where the hole in the trans tunnel is for an Automatic with a floor shift in an XA, XB, XC?? I need to cut the tunnel and fit an FMX with a T-bar and console. Obviously need to cut the carpet, is there a "hole" pressed into the steel? I haven't pulled the carpet up to have a look. Will need the width and length of the hole, and distance from dash or firewall. Also need to know where the mounting plates go for the console to bolt to. Where to bolt this bit....... ....and these two. Cheers Bear. Share this post Link to post Share on other sites
gregaust 319 Posted January 5, 2018 PM your email I can send a template 1 bear351c reacted to this Share this post Link to post Share on other sites
hendrixhc 10,920 Posted January 5, 2018 Trial and error Dave. Get the angle grinder out and just start chopping. Share this post Link to post Share on other sites
77xcfalcon 177 Posted January 5, 2018 Hi bear, I hope these help. Mine is a 6 cyl c4 xc. The top of the console mount is 20 mm off the top of the tunnel. I’ll get some specific measurements if you like.Sent from my iPad using Tapatalk 2 bear351c and BGDAV reacted to this Share this post Link to post Share on other sites
77xcfalcon 177 Posted January 5, 2018 Mine only has one console mount, am I missing one ?Sent from my iPad using Tapatalk Share this post Link to post Share on other sites
bear351c 10,270 Posted January 5, 2018 8 hours ago, 77xcfalcon said: Hi bear, I hope these help. Mine is a 6 cyl c4 xc. The top of the console mount is 20 mm off the top of the tunnel. I’ll get some specific measurements if you like. Thanks for that, much appreciated. Share this post Link to post Share on other sites
gregaust 319 Posted January 6, 2018 That combined with template I just emailed should get you there 1 bear351c reacted to this Share this post Link to post Share on other sites
bear351c 10,270 Posted January 6, 2018 Got it. Thanks guys. Share this post Link to post Share on other sites
FORD XC12 0 Posted August 12, 2019 Hey guys. Is this the same cut out for the gxl v8? Share this post Link to post Share on other sites
bear351c 10,270 Posted August 13, 2019 Should be. Not 110% certain, but, a driveline from an XA will drop straight in an XB, XC, XD, XE. EG: Clevo, FMX, 9 inch etc..so the floor pan should be the same, or very similar. Share this post Link to post Share on other sites
Gmskippy 1 Posted November 19, 2019 On 8/13/2019 at 10:00 AM, bear351c said: Should be. Not 110% certain, but, a driveline from an XA will drop straight in an XB, XC, XD, XE. EG: Clevo, FMX, 9 inch etc..so the floor pan should be the same, or very similar. Hi guys I just read the post for the XA floor mod. I am do the same on an XY does anybody know if these measurment will be the same? Thanks in advance. Share this post Link to post Share on other sites
bear351c 10,270 Posted November 20, 2019 Sorry, don't know for sure. XY are slightly different floor pan. Would be very close, you could cut a hole about 20-30 mm shorter all round, then trial fit. Share this post Link to post Share on other sites
Gmskippy 1 Posted November 20, 2019 Thanks Bear appreciated. Share this post Link to post Share on other sites
