LJDB 103 Posted November 22, 2017 Hi guys, im in need of a quality clutch to suit a turbo xflow in a cortina. i currently have a clutch industries HD clutch and it isnt up to the task since going turbo. Cortina is a street car thats get driven on the weekends. what have people used over the years? cheers 1 CHESTNUTXE reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,310 Posted November 22, 2017 i just fitted a xr six clutch to my crossy and single rail with hyd fork set up and EL flywheel. 1 LJDB reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,310 Posted November 23, 2017 model of clutch is an exceedy the xr six clutch is a bit beefier than the std falc one after that the turbo one is even better,you might wanna give that one a go. Share this post Link to post Share on other sites
deankxf 20,287 Posted November 23, 2017 39 minutes ago, CHESTNUTXE said: model of clutch is an exceedy the xr six clutch is a bit beefier than the std falc one after that the turbo one is even better,you might wanna give that one a go. do you need an Eseries flywheel for that? and drill the holes bigger if the corty is not a late(1986) crank shaft 1 CHESTNUTXE reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,310 Posted November 23, 2017 yes ol m8 at the machine shop drilled my late model flywheel out to suit the 84da engine 2 deankxf and LJDB reacted to this Share this post Link to post Share on other sites
