TUFZJ 5 Posted November 7, 2017 Hi guys. I am fixing up a ZJ fairlane, disc brake rear. One of the wheel studs was broken when I got the car (REAR). I am having trouble finding a replacement. All the ones I can find are for the drum rear end. Can anyone help with a part number or supplier? It is the LSD rear end, I believe 2.92 if that makes a difference. Thanks Share this post Link to post Share on other sites
Mr Polson 10,214 Posted November 7, 2017 Check the Nice Products website and see what they listSent from my Pixel using Tapatalk 1 bear351c reacted to this Share this post Link to post Share on other sites
deankxf 20,287 Posted November 8, 2017 11 hours ago, TUFZJ said: Hi guys. I am fixing up a ZJ fairlane, disc brake rear. One of the wheel studs was broken when I got the car (REAR). I am having trouble finding a replacement. All the ones I can find are for the drum rear end. Can anyone help with a part number or supplier? It is the LSD rear end, I believe 2.92 if that makes a difference. Thanks ZJ all had LSD and disc rear.. if that helps. could measure the length, ring a diff joint up and ask if they have any laying around in spare axels.. i would assume XE XF disc rear would be the same stud if that helps you find a part number. Share this post Link to post Share on other sites
bear351c 10,270 Posted November 9, 2017 Could buy an extra long one, the right thread size, and cut it down with a grinder. Usually get mine from the Nice Products cattledog. Share this post Link to post Share on other sites
