Mr Polson 10,214 Posted October 30, 2017 Noticed Bunnings had a caramel Wheel the other day so I grabbed it, always wanted to remove the old cracked pinstripe off the wagon. Any hints or suggestions before using it? Sent from my Pixel using Tapatalk Share this post Link to post Share on other sites
2redrovers 22,375 Posted October 30, 2017 Be VERY careful with how much pressure you put on the surface and keep it moving. It will burn paint easily if you go too hard at it or sit in a spot too long. Spinning the wheel too fast can make the bad things happen quicker. I'd suggest trying it on a spare panel to get a feel for it before using it on your car 1 Mr Polson reacted to this Share this post Link to post Share on other sites
Mr Polson 10,214 Posted October 30, 2017 What sort of speed would you recommend? Packaging for wheel say max 4,000rpm but my drill only goes to 3,000 anyway.Sent from my Pixel using Tapatalk Share this post Link to post Share on other sites
2redrovers 22,375 Posted October 30, 2017 Yeah under 1500 -3000 should be ok. Used to run one in either an old drill or a proper air tool which ran at 3k max. I didn't run the drill at full speed, just jogged the trigger on and off to keep the speed down. 1 Mr Polson reacted to this Share this post Link to post Share on other sites
