gerg 10,871 Posted March 26, 2018 Or conversely, #6 rockers should be rocking (ie exhaust closing, inlet opening) while #1 is on compression.Sent from my CPH1607 using Tapatalk Share this post Link to post Share on other sites
Outback Jack 6,352 Posted March 26, 2018 So this is how I had it set up but, as I say, had to turn the dizzy as far clockwise as I could and vacuum ended up at 7 o'clock ish. If I am understanding you right, I need to lift the dizzy out enough to rotate it (anti-clockwise?) and line the two sets of spiky wheels up then set the new position of the rotor arm to no.1 plug lead and the rest to follow?I dunno whats taking so long.Rocker cover off.... only way to do it properly.Compression on fingers is bollocks, can do that 180 degrees out, easy to make a mistake.Listen to Bear..... everything else is fapp and confusing the issue.Bear is good.Jack.Sent from my GT-S7583T using Tapatalk Share this post Link to post Share on other sites
``` 54 Posted March 26, 2018 2 hours ago, Outback Jack said: I dunno whats taking so long. work and other stuff! 1 Outback Jack reacted to this Share this post Link to post Share on other sites
Jeffb5.8 102 Posted April 9, 2018 It also helps to have two people when doing the finger over the spark plug hole, Soon as you feel the pressure put a tiny white liquid paper mark the balancer and the when it stops mark it again, TDC will be in the middle, do it a again to confirm. Once up and running mark TDC on the balancer at the pointer. Then set the dissy in with the rotor where number one lead will be and the vacuum advance should be pretty much straight giving you almost equal distance of advance and retardation. The movement will allow you to get the two spikey internal gears to line up correctly if you not 1 tooth out. If not you will most likley be one tooth out on the bottom gear, lift the inch and rotate it just a little and then slide back in. My brother who lives in Perth just rang his RACV / NRMA roadside and told them it wouldnt start, when the mech arrived he told him the truth and thet got it fixed and the mech scored a carton of Beer and wrote it down as electrical fault. Win Win. Share this post Link to post Share on other sites
``` 54 Posted April 16, 2018 Delay in getting this sorted was also due to stripping and repainting the original rocker covers and air cleaner Before: After: And a short video of it running..seems to be running pretty good..no backfires or spluttering..just need to take it for a little spin to see how it goes out on the road. 2018-04-16 17.49.05 Share this post Link to post Share on other sites
deankxf 20,231 Posted April 16, 2018 video not working, but the stock engine bay looks better to Me! Share this post Link to post Share on other sites
``` 54 Posted April 16, 2018 34 minutes ago, deankdx said: video not working, but the stock engine bay looks better to Me! try this 2018-04-16 17.49.05 2 deankxf and bear351c reacted to this Share this post Link to post Share on other sites
deankxf 20,231 Posted April 16, 2018 sounds like it's running ok now Share this post Link to post Share on other sites
``` 54 Posted April 16, 2018 seems to be..will see when I get it out on the road! 2 deankxf and Outback Jack reacted to this Share this post Link to post Share on other sites
deankxf 20,231 Posted April 16, 2018 11 minutes ago, ``` said: seems to be..will see when I get it out on the road! much like My gemini.. seemed ok revving in neutral before the last time i took it out, but i barely got round the block .. test drive for Me tomorrow hopefully also Share this post Link to post Share on other sites
bear351c 10,260 Posted April 17, 2018 Cool ! Glad to see you got the timing sorted. Managed to get the vacuum can pointing to the front, too. Well done.! 1 Outback Jack reacted to this Share this post Link to post Share on other sites
