SPArKy_Dave 8,863 Posted September 29, 2017 Hmmm, I want to try this. Seems like Jaycar Dust cans (not to be confused as Dustpans ) are R134a! https://www.jaycar.com.au/dust-remover-spray-can/p/NA1018 http://www.ebay.com/itm/ATD-3-In-1-Side-Mount-Can-Tap-Valve-3526/132193936650?rt=nc&_trkparms=aid%3D222007%26algo%3DSIM.MBE%26ao%3D2%26asc%3D47507%26meid%3Db3b62163e3cd4efeb0acaf948d4b9373%26pid%3D100005%26rk%3D5%26rkt%3D6%26sd%3D152676436470&_trksid=p2047675.c100005.m1851 http://www.ebay.com/itm/JB-Industries-Can-Tap-R134a-R12-Clamp-On-w-Small-Can-Adapter-/400940298636?epid=1123664882&hash=item5d59e7718c:g:bugAAOSw6LBVBC6t&vxp=mtr https://www.ebay.com/p/Robinair-10102-Side-Can-Tap/1111862475?iid=401212947552&_trkparms=aid%3D222007%26algo%3DSIM.MBE%26ao%3D2%26asc%3D47507%26meid%3Db3b62163e3cd4efeb0acaf948d4b9373%26pid%3D100005%26rk%3D1%26rkt%3D6%26sd%3D152676436470&_trksid=p2047675.c100005.m1851 2 Outback Jack and gerg reacted to this Share this post Link to post Share on other sites
deankxf 20,266 Posted September 30, 2017 kar air, are across the road from Jaycar in FTG.. will charge $50 to check for leaks.. (same as what the air can and clamp fitting tool cost) then again, you could wind down the left window if you got another mech and fitted it , even cheaper Share this post Link to post Share on other sites
