Sweet Cream 8 Posted July 20, 2017 Hi everyone, Pulled my xc off the road to do a few maintenance things and also replaced the water pump. Mine has aircon and was running a three belt v-belt pulley with a solid aluminium spacer against the fan. I pulled the old one off and put it in the trash box, but didn't throw it out. I guess out of sight, out of mind. I have to have two manuals for the xc, one for the body and running gear and the other for the xf engine so when I ordered a new xf water pump I used the manual. When the pump arrived I checked it off against the xf manual. All correct. Now comes a lesson in tardiness - I fitted the new pump and forgot to physically check the new one against the old one before I did. Wouldn't you know it, the pulley fittings are different and my fan won't fit. Center hole in my fan is far too small and bolt holes closer together. I assume that the mechanic who put my engine together and into the xc must have used an xc water pump which has a small hole in the aluminium spacer and fan. The standard xf has a large threaded shaft. The question is, would there be any problems with getting an xf fan and bits from somewhere and lining everything up with the aircon, alternator and crank pulleys? or should I just simplify it by ordering another xc water pump with the holes that will match my own fan and spacer? Any advice muchly appreciated. Heath 1 CHESTNUTXE reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,310 Posted July 20, 2017 hmmmmmm is it factory a/c ? Share this post Link to post Share on other sites
deankxf 20,287 Posted July 20, 2017 i'd buy an XC pump and have it running perfect in 20mins.. otherwise, you could fit a thermo fan and free up some horse power that probably won't be noticable.. the clutch fan should be more efficient, not sure if you have the space for one? then you have the pulley issue? will they just line up, i would guess yes. 1 CHESTNUTXE reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,310 Posted July 20, 2017 i have a similar delema i want to use the 86da plastic xf clutch fan on my crossy build but am i sacrificing hp ? i also have the xe metal 7 blade clutch fan but that is much heavier than the xf one. Share this post Link to post Share on other sites
Sweet Cream 8 Posted July 20, 2017 3 minutes ago, CHESTNUTXE said: hmmmmmm is it factory a/c ? Hi Chestnutxe, yes - factory Cheers, Share this post Link to post Share on other sites
deankxf 20,287 Posted July 20, 2017 1 minute ago, CHESTNUTXE said: i have a similar delema i want to use the 86da plastic xf clutch fan on my crossy build but am i sacrificing hp ? i also have the xe metal 7 blade clutch fan but that is much heavier than the xf one. Share this post Link to post Share on other sites
Sweet Cream 8 Posted July 20, 2017 4 minutes ago, deankdx said: i'd buy an XC pump and have it running perfect in 20mins.. otherwise, you could fit a thermo fan and free up some horse power that probably won't be noticable.. the clutch fan should be more efficient, not sure if you have the space for one? then you have the pulley issue? will they just line up, i would guess yes. Hi deankdx, I'm tempted to go the XC pump way. HP not an issue. Going to fit a thermo fan end of year so I can address other issues then. My XC is farm and music transport vehicle so time is important at the moment. Thanks for input. Cheers 1 CHESTNUTXE reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,310 Posted July 20, 2017 i just watched that video ,never new they ate that much power,the shroud really only comes into play at idle in traffic i think to really suck that air out,cheers dean i really enjoyed that. Share this post Link to post Share on other sites
Thom 6,650 Posted July 20, 2017 i just watched that video ,never new they ate that much power,the shroud really only comes into play at idle in traffic i think to really suck that air out,cheers dean i really enjoyed that.Just think with more rpm it will draw even more power Share this post Link to post Share on other sites
gerg 10,871 Posted July 20, 2017 Just think with more rpm it will draw even more power With an XF you could disconnect the tailshaft and let the engine fan suck the car alongSent from my CPH1607 using Tapatalk 4 SLO247, Thom, NZXD and 1 other reacted to this Share this post Link to post Share on other sites
NZXD 2,328 Posted July 20, 2017 With an XF you could disconnect the tailshaft and let the engine fan suck the car alongSent from my CPH1607 using TapatalkI would agree, with the Ghia all I can hear is the dam fan, I was thinking about going electric. Sent from my iPhone using Tapatalk 1 Outback Jack reacted to this Share this post Link to post Share on other sites
gerg 10,871 Posted July 20, 2017 I would agree, with the Ghia all I can hear is the dam fan, I was thinking about going electric. Sent from my iPhone using TapatalkDo it! Best bang-for-buck mod you can doSent from my CPH1607 using Tapatalk 2 Outback Jack and NZXD reacted to this Share this post Link to post Share on other sites
NZXD 2,328 Posted July 21, 2017 Do it! Best bang-for-buck mod you can doSent from my CPH1607 using TapatalkI'll have a look around the engine for a spot to put a thermo switch to activate the fan. A 16 inch in the centre of the shroud should work. Sent from my iPhone using Tapatalk Share this post Link to post Share on other sites
CHESTNUTXE 7,310 Posted July 21, 2017 Me too I neeed a thermo Share this post Link to post Share on other sites
gerg 10,871 Posted July 21, 2017 I'll have a look around the engine for a spot to put a thermo switch to activate the fan. A 16 inch in the centre of the shroud should work. Sent from my iPhone using TapatalkI drilled and tapped into the thermostat housing on my EA to take a VDO switch. Was 3/8" BSP from memorySent from my CPH1607 using Tapatalk Share this post Link to post Share on other sites
NZXD 2,328 Posted July 21, 2017 I drilled and tapped into the thermostat housing on my EA to take a VDO switch. Was 3/8" BSP from memorySent from my CPH1607 using TapatalkI just put a thermo switch in the XD before it was shipped, that was a tridon brand and was 3/8 NPT GAS, so fitted in the eldebrock manifold. I'll have a look around. Sent from my iPhone using Tapatalk 1 gerg reacted to this Share this post Link to post Share on other sites
gerg 10,871 Posted July 21, 2017 Yeah NPT sounds like it, BSP will fit but is one thread out so in that case just reach for a longer spanner Sent from my CPH1607 using Tapatalk Share this post Link to post Share on other sites
Mr Polson 10,214 Posted July 21, 2017 30hp loss from a steel fan! Crazy. Never figured it'd be that high.Sent from my Pixel using Tapatalk Share this post Link to post Share on other sites
NZXD 2,328 Posted July 22, 2017 I drilled and tapped into the thermostat housing on my EA to take a VDO switch. Was 3/8" BSP from memorySent from my CPH1607 using TapatalkI found a good spot. Sent from my iPhone using Tapatalk 1 gerg reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,310 Posted July 22, 2017 21 hours ago, Mr Polson said: 30hp loss from a steel fan! Crazy. Never figured it'd be that high. Sent from my Pixel using Tapatalk yeah i thought maybe 4 or 5hp Share this post Link to post Share on other sites
Lord_fahrquhar 2,580 Posted July 25, 2017 Dunno the xf with a fucked clutch hub makes a fair racket Share this post Link to post Share on other sites
LJDB 103 Posted July 25, 2017 Don't forget the actual function of the fan. You will lose more than HP if you cook it. Fixed fan never gave any cooling issues and hassle free motoring. Share this post Link to post Share on other sites
CHESTNUTXE 7,310 Posted July 25, 2017 I'm a fan of that 1 Lord_fahrquhar reacted to this Share this post Link to post Share on other sites
Sweet Cream 8 Posted July 25, 2017 On 7/20/2017 at 11:24 PM, deankdx said: i'd buy an XC pump and have it running perfect in 20mins.. otherwise, you could fit a thermo fan and free up some horse power that probably won't be noticable.. the clutch fan should be more efficient, not sure if you have the space for one? then you have the pulley issue? will they just line up, i would guess yes. Hi Dean, Correct water pump here yesterday and fan fitted nicely. Got to get my EP mixed and up on iTunes by September, so might address electric fan later in the year when I have more minutes. My XC engine bay has nice elbow room, so a lot of options open to me. Cheers, Share this post Link to post Share on other sites
Ando81 2,949 Posted July 26, 2017 Hi Dean, Correct water pump here yesterday and fan fitted nicely. Got to get my EP mixed and up on iTunes by September, so might address electric fan later in the year when I have more minutes. My XC engine bay has nice elbow room, so a lot of options open to me. Cheers, Ep? Tell us more please mate 1 Valvebouncer reacted to this Share this post Link to post Share on other sites
