Slow250XC 1,561 Posted August 20, 2017 The amount of workshop discussions over the years of how to make a switched blower setup is beyond count. Some ideas have even had a slight chance of working. Still good movies. Might have to put them on later. 1 CHESTNUTXE reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,739 Posted August 20, 2017 The thing is that a early 1930's mercedes actualy had this ,it was foot activated and only came on at w.o.t.,supercharged foot activated you can probly google it,i might be wrong on year model bit its real,im sure thats where kenedy/miller idea came from. 1 Valvebouncer reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,739 Posted August 23, 2017 my clutch bearing came i will sus it out tomorrow with pic's. 1 deankxf reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,739 Posted August 23, 2017 Here it is just opend it,looks correct,amazing a 47 year old part is still around to buy. Share this post Link to post Share on other sites
CHESTNUTXE 7,739 Posted August 23, 2017 anyone looking for this bearing suit top loader or single rail 6 cyl here is the part number. 2 Slow250XC and deankxf reacted to this Share this post Link to post Share on other sites
Slow250XC 1,561 Posted August 25, 2017 From a ford dealer? I gave the local guys the number and they said obsolete in nz and oz cant get any. Guess i should try one of my out of smalltown syndrome dealers. 1 CHESTNUTXE reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,739 Posted August 25, 2017 i got it off e bay,just search ,its only the carrier i wanted the bearings are still available new for $25 Share this post Link to post Share on other sites
CHESTNUTXE 7,739 Posted August 25, 2017 i also bought a new roll pin for the rail connection,nos too. Share this post Link to post Share on other sites
CHESTNUTXE 7,739 Posted August 25, 2017 Here is the 6cyl hyd replacement bearing,suit top loader or single rail. Share this post Link to post Share on other sites
Slow250XC 1,561 Posted August 28, 2017 Sweet. Manage to score another clutch fork n release setup from an xb for cheap. Should be right looking from the pics. 1 CHESTNUTXE reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,739 Posted August 28, 2017 they are a bit hard to find these days,good score. 1 Slow250XC reacted to this Share this post Link to post Share on other sites
hucklburry 25 Posted October 25, 2018 On 7/12/2017 at 8:46 PM, CHESTNUTXE said: i have the clarko's alloy sandwich plate and a normal bottom one if its needed.  I am in St. Louis, MO - I have that bellhousing and a Crossflow 250 I am putting in an old Bronco (keeping mechanical linkage for clutch). I was wondering if you had a part # for that clutch fork and the sandwich plate for that bell, as its the bell I have. I have the dimension on the clutch fork and researching what over here would work, not having much luck finding those 2 parts on Ebay AU or anywhere. Thank you! --Jim 1 CHESTNUTXE reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,739 Posted October 25, 2018 getting hard to find jim but i can get you one,i have about 4 of them,bell is same as top loader or borgwarner single rail,circa 1973 in australia ,google clarkos performance in australia he sells them very cheap. Share this post Link to post Share on other sites
CHESTNUTXE 7,739 Posted October 25, 2018 i am not sure if early mustang 200 was a 4 speed top loader ? fork should be the same,here we had the top loader behind our vintage 250 engines but will still fit crossflow ,bolt pattern is the same,3 speed is different,and you will need the correct thrust bearing Share this post Link to post Share on other sites
hucklburry 25 Posted October 25, 2018 11 hours ago, CHESTNUTXE said: getting hard to find jim but i can get you one,i have about 4 of them,bell is same as top loader or borgwarner single rail,circa 1973 in australia ,google clarkos performance in australia he sells them very cheap. I had checked out Clarkos based on this thread, its just the top of the sandwich plate, I need both pieces. I know a guy that I can pay to water jet one, may end up doing that, or getting the clarkos top and waterjet the bottom. 1 CHESTNUTXE reacted to this Share this post Link to post Share on other sites
hucklburry 25 Posted October 25, 2018 11 hours ago, CHESTNUTXE said: i am not sure if early mustang 200 was a 4 speed top loader ? fork should be the same,here we had the top loader behind our vintage 250 engines but will still fit crossflow ,bolt pattern is the same,3 speed is different,and you will need the correct thrust bearing I am waiting on someone I emailed to tell me dimensions on an early 60s Ford clutch fork like a Falcon or Mustang - looks like I need 3-5/8" from the "crease" for the pivot to the end of the forks. My stock 66 Bronco with a 170 six was 4-1/2" for that dimension, but it was a 144 tooth ring gear - it pushed the thrust bearing way off center. - I put a new 157 tooth zero balance on the Crossflow. 1 CHESTNUTXE reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,739 Posted October 25, 2018 jim clarko only does the top bit,and if you ask me its not really nessercary just use the factory one,i only bought it because i didnt have a factory one but it might save a tiny bit of weight,here is the australian part number ford thrust bearing you will need,usa should be similar ? 1 hucklburry reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,739 Posted October 25, 2018 i found that bearing new old stock ,very hard to find the carrier but not the bearing they are easy to find Share this post Link to post Share on other sites
hucklburry 25 Posted October 25, 2018 My LUK clutch kit came with a similar bearing, I think I'll be good to go with it, but I wont be sure until I get the correct fork. What vehicle would have the correct fork/bell/sandwich plate, I have a 76DA block (84 aluminum head) and I've been trying to figure out your vehicles, like an XD Falcon? 1 CHESTNUTXE reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,739 Posted October 25, 2018 nah they were all cable clutch,thats why hyd set up is rare to find these days,but any 6cyl falcon fitted with a 4 speed up to 1974 or possibly 75,Will have the correct fork,its much shorter than the v8 one,if you can wait i will go look for a part number on my spare ones. 1 hucklburry reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,739 Posted October 25, 2018 the rubber boot on the bell is the same as 200 mustang i no that much cause i bought it from a mustang place in brisbane australia. 1 hucklburry reacted to this Share this post Link to post Share on other sites
hucklburry 25 Posted October 25, 2018 11 hours ago, CHESTNUTXE said: nah they were all cable clutch,thats why hyd set up is rare to find these days,but any 6cyl falcon fitted with a 4 speed up to 1974 or possibly 75,Will have the correct fork,its much shorter than the v8 one,if you can wait i will go look for a part number on my spare ones. That sorta explains some of my frustrations in finding what I want . Thank you 1 CHESTNUTXE reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,739 Posted October 25, 2018 that hyd set up cost me around $1000 aus,i havent seen a complete kit for sale for years. 1 hucklburry reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,739 Posted October 25, 2018 i will shoot some pictures for you tomorrow as i need to go to work now,hey maybe you could send me a set of boss 302 heads 1 hucklburry reacted to this Share this post Link to post Share on other sites
hucklburry 25 Posted October 25, 2018 11 hours ago, CHESTNUTXE said: i will shoot some pictures for you tomorrow as i need to go to work now,hey maybe you could send me a set of boss 302 heads LOL, I'll send you a pic of the tracking # for them Share this post Link to post Share on other sites
