muzzgas 0 Posted June 26, 2017 Hey Guys, I got a bf ute dedicated lpg, have a bit of trouble starting when cold, sometimes gives a splutter or even a backfire, drives good, runs well. After 30/45 mins driving & motor is hot, I turn the car off go into shop for a few mins then go to restart the ute and nothing, turn the key & not even a crank this can happen 4/6/10 times then eventually it will start to crank then start! So Far! So I need some help/advice/suggestions plz? Muzz . Share this post Link to post Share on other sites
Drew442 67 Posted June 26, 2017 Step one is always put the scanner on and check for codes.The idle/start fuel circuit is essentially a slow leak from the mixer too. Check your vapor lines for leaks using your nose. Energise the lock off for a few seconds with a jumper wire to make it flow.Make sure the plugs are good.Sent from my MI 5 using Tapatalk Share this post Link to post Share on other sites
