Stu5766 394 Posted June 10, 2017 I have finished the install of the F246. Finished up taking 25 thou off the heads with chambers of 53cc. 40 thou head gaskets with the slugs 39 thou down the bore. Comp ratio works out about 10.8:1. Cam is degreed in & with .5 of a degree. Hoping for some decent numbers out of the old girl. 2 Valvebouncer and Outback Jack reacted to this Share this post Link to post Share on other sites
Jestr75 41 Posted June 10, 2017 Are you going to dyno it?? I am interested to see how much power it makes. They seem like pretty small chambers now. What volume are the closed chambers standard? I think I have a set in the shed that are around 63cc, Share this post Link to post Share on other sites
Stu5766 394 Posted June 10, 2017 18 minutes ago, Jestr75 said: Are you going to dyno it?? I am interested to see how much power it makes. They seem like pretty small chambers now. What volume are the closed chambers standard? I think I have a set in the shed that are around 63cc, It will go on the dyno when I regroup some coin. Chambers started out at 57-58cc. I cc'd them once my engine bloke shaved them & they are 53cc. Pretty much what we were aiming for. Instead of the standard 50tjoy head gaskets, I got the felpro steel o ring type which are 39-40thou. Last time it was on the dyno it had a XE274 cam & about 10:1 compression, it had 272RWHP. 1 Jestr75 reacted to this Share this post Link to post Share on other sites
Jestr75 41 Posted June 10, 2017 I am running a similar grind from Comp Cams and have ported open chamber 2v's. Trying to get enough coin together to dyno it in the car as well. 1 Stu5766 reacted to this Share this post Link to post Share on other sites
Stu5766 394 Posted June 10, 2017 1 minute ago, Jestr75 said: I am running a similar grind from Comp Cams and have ported open chamber 2v's. Trying to get enough coin together to dyno it in the car as well. Where are you located mate? I use Jamie Waterhouse in Penrith NSW. Reasonably priced & he is very knowlagable without being a dick. He tuned mine last time & it pulled 13.3 down the 1/4. He also tuned a mates 393 XC & it just did an 11.5 last week. 1 Jestr75 reacted to this Share this post Link to post Share on other sites
Jestr75 41 Posted June 10, 2017 I am up in Hervey Bay, QLD. There is a guy up here who is pretty good, just a matter of time and money. Cheers anyway 1 Stu5766 reacted to this Share this post Link to post Share on other sites
Jestr75 41 Posted December 20, 2017 Finally did the dyno run on Saturday. Car performed well and ended up with 335 hp at the wheels! Pretty happy with that. Done yours yet Stu?? 3 SPArKy_Dave, Valvebouncer and bear351c reacted to this Share this post Link to post Share on other sites
