xhadyboy 491 Posted June 6, 2017 I have been offered a set of 18 " El GT-P Wheel's and tyres (5000 km old) Will they go on a XE with super lows king springs? Will the offset be ok ? Share this post Link to post Share on other sites
gerg 10,871 Posted June 6, 2017 Offset is right, centre bore not sure, width might be a drama, especially if running a bit of castor (scrubs at the front of the guard lip).Sent from my CPH1607 using Tapatalk Share this post Link to post Share on other sites
xhadyboy 491 Posted June 6, 2017 The tyres are 235 x 40 x 18 So compared to the 215 x /14 with a overall O.D of =635 mm And the 18's being = 653 mm O.D 18 MM bigger That's gunna upset the speedo ? Share this post Link to post Share on other sites
gerg 10,871 Posted June 6, 2017 http://www.tyresizecalculator.com/tyre-wheel-calculators/tire-size-calculator-tire-dimensionsSent from my CPH1607 using Tapatalk Share this post Link to post Share on other sites
BGDAV 1,871 Posted June 6, 2017 will fit easy - im running 19x 8 no dramas at all - cheap buy them Share this post Link to post Share on other sites
deankxf 20,231 Posted June 6, 2017 2 hours ago, xhadyboy said: The tyres are 235 x 40 x 18 So compared to the 215 x /14 with a overall O.D of =635 mm And the 18's being = 653 mm O.D 18 MM bigger That's gunna upset the speedo ? bugger all difference Share this post Link to post Share on other sites
dex 2,065 Posted June 6, 2017 They'd need spacers yeah ,? Share this post Link to post Share on other sites
Defective 1,692 Posted June 6, 2017 They're not el gt wheels, they're ba gt wheels. Wrong offset if factory so you would need bolt on adapters. If the offset is right then they're aftermarket copies. Share this post Link to post Share on other sites
xhadyboy 491 Posted June 6, 2017 So are Ba and Nl the same stud pattern ? I thought XA to EL had the same stud pattern? Share this post Link to post Share on other sites
Valvebouncer 2,389 Posted June 6, 2017 So are Ba and Nl the same stud pattern ? I thought XA to EL had the same stud pattern?They all have the same stud pattern right up to fgx.The difference is in the size of the centre hub and au onwards switched the offset from rwd to fwd 1 Defective reacted to this Share this post Link to post Share on other sites
Defective 1,692 Posted June 6, 2017 Falcon wheels are generally referred to as being pre-au fitment and post-au fitment. pre au is 0- +6, so the mounting face of the wheel is basically in the centre of the rims width. Post-au is +36, so the mounting face is 36mm closer to the outside edge of the rim. All five stud Falcons are 5x114.3 pcd. 3 xhadyboy, Valvebouncer and gerg reacted to this Share this post Link to post Share on other sites
SirkWhyXF 1,533 Posted June 6, 2017 As stated already they are BA gtp wheels, but being they came off an EL they are most likely aftermarket copies in the correct offset for pre AU vehicles. If not they are the original ford wheels in the wrong offset for falcons befor AU's an the EL was running spacers in which case if you grab the spacers and use them on the xe you will have no issues. Stud pattern is the same on all falcons (excepts for the xp's back i think?) just the offset changed with the au. Basically if they fit on an el they'll fit the xe. I've had dark argent typoon copies in pre au offset on my xf and ed. 1 xhadyboy reacted to this Share this post Link to post Share on other sites
SirkWhyXF 1,533 Posted June 7, 2017 And here's my brothers ed running 35mm spacers and ba offset wheels. Edit: I just noticed in this pic it doesn't look like he's got the spacers on the rear, so they sit in and look kinda tubbed but still work, but you get the idea. Share this post Link to post Share on other sites
xhadyboy 491 Posted June 7, 2017 All good info lads thanks. He asking $650 for the set.So probably copies for that coin ?Sent from my SM-G900I using Tapatalk Share this post Link to post Share on other sites
SirkWhyXF 1,533 Posted June 7, 2017 Probably, but your better off with the copies in the right offset anyway, then you don't need the spacers. Share this post Link to post Share on other sites
xhadyboy 491 Posted June 7, 2017 Are the spacers no good ?Or just more shit to deal with?Sent from my SM-G900I using Tapatalk Share this post Link to post Share on other sites
SLO247 1,713 Posted June 7, 2017 Genuine ones were 19" and didn't come in E series offset, so yes copies. If they are clean and the tyres are near new its not far off. 1 SirkWhyXF reacted to this Share this post Link to post Share on other sites
SirkWhyXF 1,533 Posted June 7, 2017 23 hours ago, xhadyboy said: The tyres are 235 x 40 x 18 So compared to the 215 x /14 with a overall O.D of =635 mm And the 18's being = 653 mm O.D 18 MM bigger That's gunna upset the speedo ? Didn't make any noticeable difference on either car for me. 10 minutes ago, xhadyboy said: Are the spacers no good ? Or just more shit to deal with? Sent from my SM-G900I using Tapatalk Spacers are fine in my opinion (some hate them for various reasons, each to their own), however they may possibly void your insurance if you have an accident, and yes just more shit to deal with and another cost to add, unless you got them free with the wheels. Share this post Link to post Share on other sites
xhadyboy 491 Posted June 7, 2017 Insurance companies they are like snakes .F**kin wriggle out from anything.I reckon they will say the spacers are a non factory fitment .So i will ask hkm the question. But as Slo said O.E.M came in 19 inch.Sent from my SM-G900I using Tapatalk Share this post Link to post Share on other sites
SirkWhyXF 1,533 Posted June 7, 2017 Yeah that was a good point slo made, should be sweet then. Share this post Link to post Share on other sites
dex 2,065 Posted June 7, 2017 Sorry to hijack the thread ,, but who makes the copys like these To suit the pre au series i should add think this looks cool as 1 SirkWhyXF reacted to this Share this post Link to post Share on other sites
Thom 6,641 Posted June 7, 2017 Falcon wheels are generally referred to as being pre-au fitment and post-au fitment. pre au is 0- +6, so the mounting face of the wheel is basically in the centre of the rims width. Post-au is +36, so the mounting face is 36mm closer to the outside edge of the rim. All five stud Falcons are 5x114.3 pcd.And early falcon (xk-xp) are 4x114.3 3 Defective, SirkWhyXF and Lott reacted to this Share this post Link to post Share on other sites
dex 2,065 Posted June 8, 2017 Found some ,, 3 sets left wheelworx in sa " $2400 but " Share this post Link to post Share on other sites
