deankxf 20,266 Posted June 19, 2017 i never check spark plugs if its running properly.. whats it run like? have you checked the fuel line hoses aren't cracked? i had leaks under the passenger door area where the rubber hose joins 2 metal sections due to age cracks in the rubber.. also same at petrol tank to metal linesĀ and between fuel pump and metal hose.. the newest XE is 33yrs old.. 1 XTREME KARTS XF reacted to this Share this post Link to post Share on other sites
Mr Polson 10,214 Posted June 19, 2017 Mate water in exhaust is normal - cold air turns to moisture and is expelled from the exhaust with the exhaust gases. It's black because the inside of your exhaust will be black from natural carbon build up - carbon being a natural byproduct of the internal combustion engine.It's a ute yeah? Have you checked the fuel pickup in the tank is sealing properly? That can contribute to fuel smells, especially in utes.Sent from my Pixel using Tapatalk 1 XTREME KARTS XF reacted to this Share this post Link to post Share on other sites
