Unlucky8Ball
C4 to single rail conversion on 302w
Hi all,
Got a C4 behind a 302 Windsor in an XP that's playing up, and want to swap it out for a single rail 4spd.
I've heard that that the Clevo bellhousing fits a Windsor, can I use the whole lot from a donor car including the flywheel and everything? Do I need a different trans crossmember, and did any single rails for V8 come with a cable clutch?
Cheers
Thanks for the help and the correction about the cable clutch.
It looks like some people have fitted a later Falcon clutch master cylinder to XPs, so will look into that.
Any idea about gearbox crossmember location and tailshaft length?
The cross member location & tailshaft will be identical to that of the C4.
6 bolt clevo/Windsor bellhousing are interchangeable. 164 tooth flywheel this 28oz balance.
if your good at fabrication, mounting a clutch master won't be hard, but I would reinforce the firewall in that area to eliminate flex cracking.
