xwroo
Xw trans cooler
Is it necessary to have the pipes from the trans going into the bottom of the radiator never though it has a trans cooler, or are they there for a different reason?
No mate, if you have an external cooler they don't need to be hooked up to the radiator at all, although you can run them through both if you want to.
If you aren't running the cooler lines through the radiator, you will not need to block off the holes in the rediator where the cooler lines used to go, nothing will leak.
Thanks Xd helpful as always
