hellenikboy 32 Posted January 16, 2017 Hey guys, Got a few questions regarding the vacumn hoses coming out of the dash to the old 250. When I chuck in the 351 I want to make sure that all my heating and a/c is working correct. I have one set of vacumn hose from inside the car that connect to this red tree in the picture and I have another vacumn hose that connects to this solenoid. Does anyone know what should I do with these when the 351 goes in? Plus where does everyone connect their carbon canister on the 351? Is it worth connecting straight into the carby? or just removing completely. The car is the Victorian car, Auto with A/C from factory if that makes a difference. Thanks Anthony Share this post Link to post Share on other sites
CHESTNUTXE 7,310 Posted January 16, 2017 just reconnect them to the 351 or block em all off Share this post Link to post Share on other sites
hellenikboy 32 Posted January 17, 2017 Would blocking them off effect anything in the dash though? Share this post Link to post Share on other sites
XFtoXE 14 Posted January 17, 2017 Hey Hellenikboy If you block them off you won't heater controls. One goes to the heater tap on the inlet hose and one to vaccum manifold swap them around till you get heater controls With the carbon cannister it all depends on how much respect the environment Cheers Share this post Link to post Share on other sites
hellenikboy 32 Posted January 25, 2017 Thanks. I will have to have a play around when the engine is in. Share this post Link to post Share on other sites
Banno 479 Posted January 25, 2017 the red one is for air con and works inconjunction with the electrical soleniod. When Air con turned on it powers up soleniod valve to open manifold vacuum metered to the distributor to up the timing to prevent over heating and bad idle. If your not running air con dont bother with it. As for the other I think it is for vacuum on webber carby as is temperature operated to act at various temps. think to richen. Not sure if required on V8 depends on carby. 1 dex reacted to this Share this post Link to post Share on other sites
bear351c 10,270 Posted January 25, 2017 carbon cannister is legal in some states, so you have to fit them. Shove a ball bearing down the hose........jobs done. Share this post Link to post Share on other sites
