CHESTNUTXE 7,305 Posted December 27, 2016 Hey i was out at wagoons this morning and he told me he had this 4 speed box if i wanted it,so yeah i will take it with me,a bit of research b4 i went out there by the pic's he sent me says its a 3.3 crossy 5 speed ,82 model too,alloy bellhousing you can lift the whole thing up with 1 hand practicly,it says this box was put behind bluebirds,corona's ,ect,,,,but when i try and find 5th it aint going anywhere ,does the box have to be moving to engauge the overdrive or wtf ?see pictures with the 5 on the casting just like it says on the internet about these boxes,even says 1 guy put 1 behind a 302w and if driven sensibly worked out ok. Share this post Link to post Share on other sites
CHESTNUTXE 7,305 Posted December 27, 2016 casting 5 Share this post Link to post Share on other sites
CHESTNUTXE 7,305 Posted December 27, 2016 single rail shifter fits Share this post Link to post Share on other sites
CHESTNUTXE 7,305 Posted December 27, 2016 This box had a factory 2.92 behind it. Share this post Link to post Share on other sites
slydog 7,873 Posted December 27, 2016 Same as Sigma box...and yes found on 200 cube units. 2 XTREME KARTS XF and CHESTNUTXE reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,305 Posted December 27, 2016 but where is 5th ? it dont want to enguage,wagoon said he only used 4 gears and never new it had a 5th Share this post Link to post Share on other sites
CHESTNUTXE 7,305 Posted December 27, 2016 i just did some research and it say's there is a 505,506 4 speed ,and 507 5 speed,and a jap box version as well,wait until i clean it and see what it is,could just be a 4 speed with no overdrive fitted which is the 506. Share this post Link to post Share on other sites
CHESTNUTXE 7,305 Posted December 27, 2016 yep she is a 506 Share this post Link to post Share on other sites
dex 2,065 Posted December 27, 2016 Where is reverse If its up near first its a mitzu l200 one ,, i think Sigma / 200 cube falcon was below 5th 1 CHESTNUTXE reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,305 Posted December 27, 2016 yeah i think she is a 4 speed model 506 reverse is like the single rail. Share this post Link to post Share on other sites
deankxf 20,279 Posted December 27, 2016 i've seen a 4 speed one, drove about 200kms to buy a 5 speed(seller says it has a 5 on the side, must be a 5 speed.. included reverse in his story) he was selling it as a T5 too which i wasn't impressed with, and naturally said keep it, wouldnt want it for $20, uses a different tailshaft too(which he didn't have... i am fairly sure i bought a borg warner yoke to fit in to keep the oil in on the way home) 1 CHESTNUTXE reacted to this Share this post Link to post Share on other sites
SPArKy_Dave 8,869 Posted December 27, 2016 Mike Vine also privately imported a stronger version of the 5spd Borg Warners, which he fitted to his Crossy turbo conversions. I have an article which talks about it. 1 CHESTNUTXE reacted to this Share this post Link to post Share on other sites
Gav 616 Posted December 27, 2016 The "5" cast into the side suggests it's a five speed. I had one of those behind a 4.1 in the late eighties as T5's were way too expensive back then. Dellow converted Celica boxes were the only other feasible overdrive gearbox options available and seemed fiddly to my 17 year old brain. These were the only option I gave myself - lasted a while then broke. I feel they only came behind 3.3's for a reason...... 1 CHESTNUTXE reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,305 Posted December 27, 2016 Plastic coated gears as others have suggested lol,there was a 4 speed version made it just doesnt have the overdrive fitted ,the case is the same as the 5 speed,others have fitted the 5th out of a sigma box and quite easy they said to do,also the car had a 2,92 diff as standard so i thought it was 5 speed straight away as the 5 speeds were either 2.92 or 3.23. Share this post Link to post Share on other sites
winton 399 Posted December 28, 2016 Didn't waste anytime to make a quick buck Look at this on eBay http://www.ebay.com.au/itm/322371458725 1 CHESTNUTXE reacted to this Share this post Link to post Share on other sites
Lord_fahrquhar 2,580 Posted December 28, 2016 Plastic coated gears? In the name of science this need to be put behind a 351 stat 1 CHESTNUTXE reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,305 Posted December 28, 2016 i wonder will a borgy v8 bellhousing fit it. Share this post Link to post Share on other sites
CHESTNUTXE 7,305 Posted December 29, 2016 dave tell us about the mike vine 5 speed Share this post Link to post Share on other sites
SPArKy_Dave 8,869 Posted December 29, 2016 dave tell us about the mike vine 5 speed The article just says that MV was privately importing a Borg Warner 5spd trans from the USA, with stronger internals, for fitment to his XE and XF turbo conversions. The turbo conversions were carby or EFI, with a power output between 150kw - 257kw, at between 7lb and 15lb of boost. His base offering, was 7lb of boost. Customers had a choice of the standard 4spd, the imported 5spd, or the factory 3spd auto, re-engineered with up-rated internals. 2 CHESTNUTXE and SirkWhyXF reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,305 Posted December 29, 2016 interesting also that DJ was using a moded internal rail box with top loader guts inside the box in the greens tuff era,ford in america gave him 2 boxes so the rumor has it,very big weight saving over the std top loader box. Share this post Link to post Share on other sites
gerg 10,871 Posted December 29, 2016 Probably based on the alloy case SROD box which evolved from the top loader Share this post Link to post Share on other sites
CHESTNUTXE 7,305 Posted December 29, 2016 tell us info hungry ford folk more gerg Share this post Link to post Share on other sites
gerg 10,871 Posted December 30, 2016 SROD = single rail overdrive. Found on American cars before the T5 was used. Cars got the alloy case, trucks had iron. Third was direct just as fourth was in the old box, but fourth in a SROD is where third used to be and is an overdrive ratio, not a reduction. Some claim that they wore out prematurely because top gear was indirect and required the gears to be under stress all the time. http://www.5speeds.com/toploader.html Share this post Link to post Share on other sites
wagoon 2,429 Posted December 30, 2016 Didn't waste anytime to make a quick buck Look at this on eBay http://www.ebay.com.au/itm/322371458725 Hmmmmmm. I supplied parts in good faith to be used as spares to help out. To find out they are being sold to make money, in the same week they are taken away for free.........Just decided that the rest of my stuff is going to the dump!! Was trying to help out but guess that's not every ones cup of tea. PS I'M OUT 4 winton, Mr Polson, ESPSIX and 1 other reacted to this Share this post Link to post Share on other sites
