Server maintenance Read more... ×
Bullaman
Diesel xg
Recommended Posts
Guys
The u beaut ute is blowing more soot than an old 1hz cruiser....
If I pull the vac line off the fuel reg should the engine tune change, if it doesn't is it knackered
Seriously black fumes out the exhaust
Running ruff, will idle
Any thing obvious I should look for , wasted $90 on 02 sensor by the looks
Share this post
Link to post
Share on other sites
I had a vac line fall off the MAP sensor in my sister's EF, gave similar symptoms: black smoke and rough idle but went ok under load. Vac line off the fuel reg doesn't seem to make much difference to idle in my experience.
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
