bear351c 10,270 Posted November 7, 2016 Nice project.! Loving the work done so far. Mate, got some wear marks in them bores...... Did you drop the T5 in from the top.?? Looks like it fall thru that hole in the floor. Share this post Link to post Share on other sites
Crazy2287 1,886 Posted November 8, 2016 Subscribed! Share this post Link to post Share on other sites
XFH00N 37 Posted November 8, 2016 The block had been honed and was nice and clean. Narr the hole isnt big enough for the bellhousing lol. But i have ordered my valves so hopefully will get the head sorted and on next break Share this post Link to post Share on other sites
XFH00N 37 Posted November 16, 2016 well ive done some more. cleaned up the head and ports Lapping the valve valves and seals installed. Head and manifold on for mock up and the turbo I'm waiting for my valve springs to turn up so I can install them then bolt the head down and its onto making the dump pipe 3 Panko, SirkWhyXF and Crazy2287 reacted to this Share this post Link to post Share on other sites
XFH00N 37 Posted November 29, 2016 I really need to update this. I have since got both guards and the drivers door straight and into hi-fill primer, left door will be done tonight. Have fitted up drivers side panels for alignment. Valve springs are all fitted to the head and have started on the dump pipe which will be done tonight. Im on break tomorrow which shall see the left door into hi-fill and the timing chain and head fitted along with the exhaust manifold, turbo and dump pipe. Will upload pics when i get time 4 2redrovers, SirkWhyXF, scottly and 1 other reacted to this Share this post Link to post Share on other sites
SirkWhyXF 1,533 Posted November 30, 2016 Never happened with out pics 2 thorne and 2redrovers reacted to this Share this post Link to post Share on other sites
XFH00N 37 Posted December 4, 2016 ok time for the pics Colour preview Half of the loom. More on the other side of the bay Door prep Door in epoxy Headlining before Starting to trim it and ready for install Trims for headlining painted black from the original yellow Inside of cab painted Before on the left After on the right 2 scottly and SirkWhyXF reacted to this Share this post Link to post Share on other sites
XFH00N 37 Posted December 4, 2016 Headlining installed Preping guards Then both were epoxy primed Then the hi fill Rear sway bar Drivers door in hi fill 4 2redrovers, Panko, SirkWhyXF and 1 other reacted to this Share this post Link to post Share on other sites
bear351c 10,270 Posted December 4, 2016 Damn...... Nice update.! Loads of work happening here. Coming together nicely. 1 XFH00N reacted to this Share this post Link to post Share on other sites
SirkWhyXF 1,533 Posted December 5, 2016 Before on the left After on the right Can't believe you ditched that classic trim pattern on the sun visors!! Share this post Link to post Share on other sites
Panko 2,480 Posted June 30, 2017 any updates on this? Share this post Link to post Share on other sites
