SLO247 1,713 Posted September 20, 2016 Anybody used this combination? I've just fitted this today and the passenger side cable is too short to reach. Would like to know if anybody has done it before I have another look. Share this post Link to post Share on other sites
Banno 479 Posted September 20, 2016 Did you use the XG counter lever under car that pulls cable in or the original xf one cause they are different. I had to change over the whole lot when I put a e-series diff in cause same problem. From memory I used the original lever and wouldn't work so used e-series and no problem. Long ago when I did that and memory is really fading. 1 SLO247 reacted to this Share this post Link to post Share on other sites
SLO247 1,713 Posted September 20, 2016 I did use the XG one yes. Noticed it still has the three position holes too, one of them marked "drum". Only XF bits are the handle and front cable. Share this post Link to post Share on other sites
deankxf 20,266 Posted September 20, 2016 i used EB wagon diff and handbrake cable in XF ute using the full cable with possibly the lever doover thingy.. cant remember there being any issues.i would have assumed the XG cable would be the same as the EB wagon..the front cable changed lenth at some point possily.. XD\XE to XF maybe or to E series.. might be part of the remedy 1 SLO247 reacted to this Share this post Link to post Share on other sites
SLO247 1,713 Posted September 22, 2016 I've crawled under and had another look. First thing is the XG arm looks identical to the XF one. I've used the XG one anyway, I can't separate it from the cable. It has what looks like a dome bolt head on it. Looks to be a separate piece but I can't see a thread. If I can get it off I'll try the cable in one of the other holes which looks like it might give enough length. Any help? The XF one just has a nut. Share this post Link to post Share on other sites
SLO247 1,713 Posted September 22, 2016 Otherwise I'll cut the xg one off and use the xf adjuster bolt. May give more adjustment too. Share this post Link to post Share on other sites
Banno 479 Posted September 22, 2016 Sorry dude I couldn't much help. There was something different about it or the way it comes together cause they in three pieces, that for the life of me I can't remember. How short is it? Share this post Link to post Share on other sites
SLO247 1,713 Posted September 22, 2016 It's a few inches away from joining the left to the right cable in the centre. I'm pulling the handbrake on trying to join it though. Share this post Link to post Share on other sites
SirkWhyXF 1,533 Posted September 22, 2016 It's not the right way, and i still have to fix mine as i doubt it will hold on a steep hill, but i had the same issue with my sedan and i've at the moment got the adjustment part from the xf on the system too to get the extra length. It's a bit too long though, as the umbrella is very light. Still holds, though as i said i haven't tested it on any sort of substantial slope.... 1 SLO247 reacted to this Share this post Link to post Share on other sites
SLO247 1,713 Posted September 23, 2016 I did the same thing today. Fitted the extra adjuster and moved it over one hole. Works well now, plenty of adjustment left to tighten it up more if needed. Remember there's still the other adjuster on the driver's side if you need it shorter. The handle did feel light but it seems good. 1 SirkWhyXF reacted to this Share this post Link to post Share on other sites
SirkWhyXF 1,533 Posted September 23, 2016 Yeah I've got both the adjusters all the way tight from memory. Glad that got you out of trouble for now anyway Share this post Link to post Share on other sites
ando76 4,354 Posted October 5, 2018 Just a bit of an update as to why the xg passenger side cable doesn't fit up nicely to the xf when doing this conversion. The very forward most cable mounting bracket on the passenger side is 45mm further forward on the xf compared to xg. This means the cable has to travel further to clamp into the mount. If you mount the xg cable in the xf clamp you will see that the cable doesn't runs on an angle over to the primary lever - not straight like the xg. Next difference is the mounting pivot point for the primary lever. Yes the lever is very similar lever for xf and xg but the mounting point for the pivot is further out on the xg than xf. Again this means that the cable has further to travel to hook up. Nkw you could stuff around and move the mounting clamp further back and also weld in the xg pivot bracket, but really it's way easier just to install the xf primary lever and longer adjuster as the others have done above. 2 bear351c and Valvebouncer reacted to this Share this post Link to post Share on other sites
