CHESTNUTXE 7,310 Posted September 14, 2016 Guys can someone tell me does the switch have 2 functions or just 1,only my parkers seem to work when i pull the switch ? im sure my last xe you pull twice 2 get the normal lights right ?,i have never drivin the car at night and wanted to take it for a spin at night and i found only the parkers and high beam were working ? Share this post Link to post Share on other sites
bear351c 10,270 Posted September 14, 2016 Should be the same as XD, once for parkers, again for low beam. Share this post Link to post Share on other sites
SLO247 1,713 Posted September 14, 2016 Pull once for Parker's, pull again for headlights. Rotate for rheostat and rotate around until it clicks for interior light. Share this post Link to post Share on other sites
deankxf 20,287 Posted September 14, 2016 might be an issue with the blinker switch also as it dips between high and low beam, so it may pay to check there also.. not sure where the wires run from the switch, but they don't have relays to my memory Share this post Link to post Share on other sites
CHESTNUTXE 7,310 Posted September 14, 2016 YUP the high beam wont stay on i have to hold it manualy,the switch will only pull once,i took it apart to look for an easy fix but nope,i might need a new one,nealy 2 years i own this car and never drivin it at night lol. Share this post Link to post Share on other sites
bear351c 10,270 Posted September 14, 2016 You're right about the relays, deankdx, tried running 130/90W headlight globes in my FC, melted the switch we're all talking about in the dash. 1 CHESTNUTXE reacted to this Share this post Link to post Share on other sites
Banno 479 Posted September 14, 2016 Check earths first for lo- beam headlights at passengers side radiator support near radiator cap as well as earths at battery for any that have been forgotten to be hooked up if battery ever be replaced they are sensitive to earths. They dont run any relays for Lo-Hi beam in Xe except for the spot lights on Ghia lights and thats a seperate wiring loom. I ran relays for my xe ghia for Lo and high seperately and it improved the brightness. Age of the wiring etc creates resistances and lose amps and voltage. If that checks out get a mult-meter and check for power at switch. Yellow is power. Red with Black stripe is lo-beam . When switch is out it runs power to horn,turn signal,lights dip connector which also runs out to dash lights lo-beam etc There is a fuse at battery and a circuit breaker in the fuse box but if you are getting high beam then there be power. Sounds like the switch is faulty though ? Hope that make sense without photos but if not someone here should know more 2 CHESTNUTXE and bear351c reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,310 Posted September 14, 2016 Thanks for the info mate Share this post Link to post Share on other sites
Banno 479 Posted September 14, 2016 Actually which switch are you using on the dash? Left hand side or the right hand side. They both have similar pictures but one on the left is for spot light/ hi beam and that only clicks once and won't run without Li beam on but works when pull stork manually Sent from my iPhone using Tapatalk Share this post Link to post Share on other sites
CHESTNUTXE 7,310 Posted September 14, 2016 Just the one on the right banno,the pictures on the switches differ slightly ,when i put the underdash all back together im sure the spottie knob wont go on the normal light stalk they are different fittment. Share this post Link to post Share on other sites
CHESTNUTXE 7,310 Posted September 15, 2016 I checked the switch again and yeah it wont pull out that 2nd time so i will try and find a working one,because my car is a replica i put the ghia loom for the driving lights but they are not wired up yet,so is the factory way to hook them up to the left switch as well with the bosch spotties ? Share this post Link to post Share on other sites
Banno 479 Posted September 15, 2016 Correct, driving lights for the ghia are to the light switch on left in the dash. Bosch spotties /fog lamps are same type of switch used but go down next to boot release at fuse panel and wired as such that only go on with ignition on. Share this post Link to post Share on other sites
Free.51 2,717 Posted September 15, 2016 I had this prob with my ltd not long ago i cant remember exactly right now what i did but it had to do with the metal screw thingy which screws into the plastic box where u pull & push to turn on parkers/headlamps & turn off it was loose it might be the same as what your experiencing. Share this post Link to post Share on other sites
Free.51 2,717 Posted September 15, 2016 http://www.xfalcon.com/forums/index.php?/topic/38158-xe-headlight-switch/ This is the same problem i had Share this post Link to post Share on other sites
CHESTNUTXE 7,310 Posted September 15, 2016 On the weekend I might give it another look but while its all out mas as well just wack the new one in. Share this post Link to post Share on other sites
VDO 124 Posted September 15, 2016 Lots of speculation here, yet there is clearly a faulty switch. Just replace the switch and go from there... Share this post Link to post Share on other sites
CHESTNUTXE 7,310 Posted September 19, 2016 Joe (bullfrog) has found a switch to send me,i will fit next weekend,then get the ghia driving lights and spotlights wired up too. Share this post Link to post Share on other sites
Free.51 2,717 Posted September 19, 2016 How is joe? Havent seen him since AFD Share this post Link to post Share on other sites
CHESTNUTXE 7,310 Posted September 26, 2016 I have never met him but have got plenty of bits n pieces off him for my car,im expecting parts tomorrow. 1 Free.51 reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,310 Posted October 4, 2016 ok the switch is here lets swap it in Share this post Link to post Share on other sites
CHESTNUTXE 7,310 Posted October 4, 2016 well it works,im stoked now i can take it out on the town. 1 SLO247 reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,310 Posted October 4, 2016 now onto the bosch spotties bullfrog sent me some covers but does anyone no if there is ment to be a bosch sticker or emblem on the xe ones ? i no the xd had one. Share this post Link to post Share on other sites
VDO 124 Posted October 4, 2016 No, they're blank. Only the XE ESP had logos on the covers, but those were SEV Marchal lights. It may actually be the case that both Bosch and SEV Marchal could have been fitted to the XE ESP. Someone else might know..? Share this post Link to post Share on other sites
