FORD_MAN 1,026 Posted April 22, 2016 what is the biggest stroker kit for a 460 ,i see some really big chev ones over 600 cubes but the ford seems to be a bit smaller ?.is it because not as much development has gone into raising the deck for the bigger crank ? Stock block is 557ci with 4.440 bore 4.5 stroke, Ford Racing Big bore block is 573ci with 4.5" bore, 4.5" stroke, can be bored to 4.6"(598ci) and can get 4.75" Callies crank 632ci just found Eliminator Premier block (up to 2500hp), can bore 4.7" . up to 660ci in cast iron blocks. O and Jon Kaase engines in the states does a 820ci Ford Hemi alloy block Share this post Link to post Share on other sites
CHESTNUTXE 7,304 Posted April 22, 2016 The 820 cube sounds awsome,i can imagine that in a falcon with a 12/71 blower sticking out the bonnet,yeah the yanks love our 2v closed for their broncos and f trucks with 400 or 351m or 351c ,i have seen pictures where a whole pallet of heads were sent there . 1 gerg reacted to this Share this post Link to post Share on other sites
gerg 10,871 Posted April 23, 2016 Would need some serious dish with 302 chambers, but I guess a dished piston in a quench chamber is better than a flat top in an open chamber. Share this post Link to post Share on other sites
CHESTNUTXE 7,304 Posted April 23, 2016 remember that the 400 piston actually has a different pin height to the 351c,i would just put a set of aussie shaved opens so streetable at 9.5.1. Share this post Link to post Share on other sites
gerg 10,871 Posted April 23, 2016 Yeah stock pistons sit really far down the bore from memory. Share this post Link to post Share on other sites
