83xe 5 Posted March 14, 2013 Heya guys . well i have started a new project [yes another money pit] and well in my rush toget the engine and box together i have forgotten to take the sigot bearing out , now the problem is i have never removed one before and is there a way to just bash the shit out of it to get it out? lever it out? Share this post Link to post Share on other sites
Ants 6,370 Posted March 14, 2013 Bash the shit out of it with a chisel,carefully lol. Share this post Link to post Share on other sites
Tweaker351 148 Posted March 14, 2013 Get a drill bit thats just big enough to make a hole in it nearly all the way through, but not dig into the crank. Drill it out then get a chisel and crack the bearing and it should just fall out. Share this post Link to post Share on other sites
thunderbolt 150 Posted March 14, 2013 fill it with day old porridge e then get a bolt that's a snug fit in the hole and hit it with the hammer The squashing of the rubbery porridge will push the bearing out paper soaked in water for a day can be used too Share this post Link to post Share on other sites
SatansReverence 264 Posted March 14, 2013 I thought it was bread. . 1 steve mcqueen reacted to this Share this post Link to post Share on other sites
thunderbolt 150 Posted March 14, 2013 I thought it was bread. . thats a good one too Share this post Link to post Share on other sites
Crazy2287 1,886 Posted March 14, 2013 I use grease.Jam it full of grease. Get a 3/4 drive extension bar and wrap elecky tape on it till it fits snug in the bearing inner race. Then bash the extension bar in with a hammer and the pressure will force the bearing out. 3 twelvepointfour, Stevemack and roKWiz reacted to this Share this post Link to post Share on other sites
Trev Vaa 1,185 Posted March 14, 2013 or the proper way, get an internal bearing puller. lol i have used grease when i haven't had mine on hand though 2 uterus and Stevemack reacted to this Share this post Link to post Share on other sites
thunderbolt 150 Posted March 14, 2013 I use grease. Jam it full of grease. Get a 3/4 drive extension bar and wrap elecky tape on it till it fits snug in the bearing inner race. Then bash the extension bar in with a hammer and the pressure will force the bearing out. grease wont on the needle roller bearing spigot bearings play dough or plasticine might Share this post Link to post Share on other sites
slydog 7,873 Posted March 14, 2013 Having tried all bar the Uncle Tobys idea??? I just use a die grinder to grind the material away in one or two spots then smash it with a cold chisel and have it out in under a minute every time now.Don't go nutso with the grinder or you will eat out the back of the crank,a line straight down to go thru the outer case is all thats needed than let your week's built up anger unload on the bearing. JMO though... Share this post Link to post Share on other sites
SatansReverence 264 Posted March 15, 2013 let your week's built up anger unload on the bearing. If I did that the bearing would come out past the balancer 1 uterus reacted to this Share this post Link to post Share on other sites
83xe 5 Posted March 16, 2013 OKAY so after abit of trying to wrench it out [ didnt work and wishing i was someplace else] i saw the comment about grease and a 3/8th extension , i tried and it worked PERFECTLY! now in my rush to do this i left the gearbox in and pulled the engine out , and well now its not going back together so nicely lol! Share this post Link to post Share on other sites
Lord_fahrquhar 2,580 Posted March 16, 2013 Will toast work? Or that sultana bread shit for a nice cinnamon smell instead of proxy moly based grease 1 Vannin reacted to this Share this post Link to post Share on other sites
Crazy2287 1,886 Posted March 16, 2013 Im gonna have to go with moly grease, Molybdenum is a fantastic ASSembily LUBE. In yo face bitches, He used the grease trick. /thread GTFO all yall' Share this post Link to post Share on other sites
thunderbolt 150 Posted March 16, 2013 Im gonna have to go with moly grease, Molybdenum is a fantastic ASSembily LUBE. In yo face bitches, He used the grease trick. /thread GTFO all yall' GTFO is that like GTHO but new Share this post Link to post Share on other sites
Crazy2287 1,886 Posted March 16, 2013 Also, If you don't have the clutch PERFECTLY lined up, you can get it together still but it can be a 4 hour CU*T!the same extension bar i used to drift out the spigot. I put it back in the spigot with enough tape so it sits in nice and square. Then make another layer of tape there the clutch will sit to center the clutch plate on the extension bar. then semi bolt it together and use a metal rule, measuring in 4 points around the housing from the extension bar to either the clutch fingers or the housing lip. Get it within a millimeter so all 4 measurements are the same. +-1mm. bolt it together. then fit it. Having the clutch centered is paramount to make it mate up as easy as possible. The only other thing that will stop it is the spline teeth no mating up. If this is a problem put it in gear and spin the tailshaft which in turn will spin the input shaft and line the splines up. if it turns and locks, its likely the splines have engaged. (of your back wheels are on the ground, Lawl. 2 robbie and xSMOKEx reacted to this Share this post Link to post Share on other sites
Crazy2287 1,886 Posted March 16, 2013 NO, it means get the fuck out =P 1 robbie reacted to this Share this post Link to post Share on other sites
thunderbolt 150 Posted March 16, 2013 Also, If you don't have the clutch PERFECTLY lined up, you can get it together still but it can be a 4 hour CU*T! the same extension bar i used to drift out the spigot. I put it back in the spigot with enough tape so it sits in nice and square. Then make another layer of tape there the clutch will sit to center the clutch plate on the extension bar. then semi bolt it together and use a metal rule, measuring in 4 points around the housing from the extension bar to either the clutch fingers or the housing lip. Get it within a millimeter so all 4 measurements are the same. +-1mm. bolt it together. then fit it. Having the clutch centered is paramount to make it mate up as easy as possible. The only other thing that will stop it is the spline teeth no mating up. If this is a problem put it in gear and spin the tailshaft which in turn will spin the input shaft and line the splines up. if it turns and locks, its likely the splines have engaged. (of your back wheels are on the ground, Lawl. when you don't have the clutch lined up put the bell on and hook up the clutch cable then wedge a stick between the seat mount and the clutch pedal then put the gear box in the clutch plate can move around and the box will go in like a lubed finger in a bum Share this post Link to post Share on other sites
Lord_fahrquhar 2,580 Posted March 16, 2013 Either that or get chuck Norris to roundhouse kick that fucker. Not only will it get the old bearing out, it will drive the new one in square and make the box side in quicker than that I would be in Jennifer Hawkins if she said lets go for it. Share this post Link to post Share on other sites
BBS XE 160 Posted March 16, 2013 When you get a new spigot bearing, find your nearest bearing shop and get it from there instead of Ford or ebay etc. You'll save about 30 bucks. Share this post Link to post Share on other sites
83xe 5 Posted March 16, 2013 sorry fellas i should have explained , im going from manual to auto , auto will be better i hope! Share this post Link to post Share on other sites
SatansReverence 264 Posted March 16, 2013 Why lord, why! 1 83xe reacted to this Share this post Link to post Share on other sites
xSMOKEx 47 Posted March 16, 2013 sorry fellas i should have explained , im going from manual to auto , auto will be better i hope! its a sad day when you resort to an auto lol Share this post Link to post Share on other sites
Crazy2287 1,886 Posted March 16, 2013 autos? I can dig it. manual is a pain in the ass when your trying to txt ur misses ur still at work while balancing a drink in your lap and a kfc burger in the other hand. 1 noddy reacted to this Share this post Link to post Share on other sites
slydog 7,873 Posted March 16, 2013 Or as the smart ones say about time.Manuals are for cars without hp too make them interesting to drive. 2 noddy and MoeFord reacted to this Share this post Link to post Share on other sites
