SPArKy_Dave 8,871 Posted April 13, 2016 http://users.erols.com/srweiss/tablehdc.htm#Ford Ford COPYRIGHT © 2000-2018 Stan Weiss — World Wide Enterprises Manufacturer Part Number Port/Vol Int/Exh Valve Size Int/Exh Combust. Chamber Vol .100 .150 .200 .250 .300 .350 .400 .450 .500 .600 .650 .700 Average Ford Y ECZ-G Iron N/A 1.927/1.51 N/A 62/51 90/72 116/87 133/94 147/102 158/109 166/114 170/119 171/123 - - - - Ford Y ECZ-G Ported Ford-Y-Block Street Iron N/A 1.94/1.60 N/A 64/57 96/75 122/94 148/113 165/126 181/132 193/143 207/150 215/152 - - - - Ford Y ECZ-G Ported Ford-Y-Block Performance Iron N/A 2.02/1.60 N/A 69/64 100/89 129/108 156/129 177/141 196/154 212/161 218/169 227/177 - - - - Ford Y '57 G Ported Joe Craine Street / Strip Iron N/A 2.00/1.60 N/A 61/55 - 124/109 - 171/133 - 205/160 217/166 226/171 234/180 - - - Lincoln Y ECU-E R & R performance Iron N/A 2.00/1.635 4.00 N/A 66/50 - 118/91 - 174/116 - 200/127 - 221/135 - - - - Lincoln Y ECU-E Ported R & R Performance Iron N/A 2.055/1.66 4.00 N/A 70/59 - 143/119 - 198/139 - 230/173 - 242/192 255/203 - - - Lincoln Y ECU-E Ported Abbot Stage 4 Iron N/A 2.055/1.66 N/A 71/58 - 145/118 - 197/140 - 225/176 - 236/192 246/205 - - - Lincoln Y ECU-E Ported Abbot Stage 5 Iron 199/- 2.055/1.66 77 72/59 - 146/120 - 204/142 - 229/178 - 239/195 254/209 - - - Lincoln 430 575 R & R Performance Iron N/A 2.14/1.78 4.25 N/A 69/50 - 128/97 - 177/132 - 209/153 - 234/179 247/192 251/196 @ .700 - - Lincoln 430 B9VE Street / Strip Port Les Schmader Iron N/A 2.14/1.78 N/A - - 173/124 - 217/167 - 251/186 - 277/200 287/208 - - - Lincoln 462 '67 C6VE Joe Craine Iron N/A 2.19/1.88 - No Pipe N/A - - - - - - - - 249/180 - - - - Lincoln 462 '67 C6VE Ported Joe Craine Iron N/A 2.19/1.88 - No Pipe N/A 66/63 - 143/127 - 218/190 - 278/199 292/- 298/201 - - - - Manufacturer Part Number Port/Vol Int/Exh Valve Size Int/Exh Combust. Chamber Vol .100 .150 .200 .250 .300 .350 .400 .450 .500 .600 .650 .700 Average Ford 1.6 Pinto Ported N/A 44mm/38mm N/A 54/43 - 112/75 - 160/98 - 174/119 - 180/134 186/144 - - - Ford 2.0 Pinto Early Carb Dave Baker N/A 42mm/- N/A 55/- - 96/- - 123/- - 135/- - 144/- - - - - Ford 2.0 Pinto Injected Dave Baker N/A 42mm/- N/A 49/- - 94/- - 133/- - 148/- - 156/- - - - - Ford 2.0 Pinto Ported Dave Baker N/A 45.6mm/- N/A 60/- - 117/- - 154/- - 181/- - 200/- - - - - Ford 2.0 (SOHC English) Pinto Ported Kelford Cams N/A 1.75/1.48 N/A 58/54 - 116/93 - 161/124 - 175/135 - 184/139 191/143 - - - Ford Pinto CNC Heads UK N/A 1.79/1.496 100mm No Pipe N/A 60/44 90/- 117/84 129/- 142/105 151/- 156/114 159/- 162/117 - - - - Ford Pinto Ported CNC Heads UK N/A 1.79/1.496 100mm No Pipe N/A 64/48 97/- 127/90 155/- 178/117 198/- 201/131 207/- 212/142 - - - - Ford 2.5 CNC Heads UK N/A 1.179/1.0195 100mm No Pipe N/A 74/60 114/- 148/144 172/- 184/176 192/- 199/174 201/- 199/175 - - - - Ford 2.5 Ported CNC Heads UK N/A 1.22/1.062 100mm No Pipe N/A 71/71 108/- 145/163 179/- 200/209 215/- 225/215 229/- 232/219 - - - - Ford 2.0 Duratec CNC Heads UK N/A 1.319/1.78 100mm No Pipe N/A 87/64 130/- 174/129 211/- 234/151 243/- 247/169 248/- 250/171 - - - - Ford 2.0 Duratec Ported CNC Heads UK N/A 1.319/1.78 100mm No Pipe N/A 87/77 128/- 173/158 214/- 247/207 272/- 291/224 302/- 307/231 - - - - Ford '06 2.0-2.3 Duratec Sabre Heads SF110 N/A 35mm/30mm - No Pipe N/A 85/66 125/99 163/128 193/144 211/151 219/155 224/158 225/160 226/161 - - - - Manufacturer Part Number Port/Vol Int/Exh Valve Size Int/Exh Combust. Chamber Vol .100 .150 .200 .250 .300 .350 .400 .450 .500 .600 .650 .700 Average Ford '06 2.0-2.3 Duratec Ported Sabre Heads SF110 N/A 35mm/30mm - No Pipe N/A 84/83 124/121 163/144 199/157 227/162 238/168 246/170 249/175 253/176 - - - - Ford '95 16v RS2000 Sabre Heads SF110 N/A 33.5mm/ 30mm 86mm No Pipe N/A 83/67 123/102 157/132 179/155 188/165 194/176 200/183 201/185 204/188 - - - - Ford '95 16v RS2000 Ported Sabre Heads SF110 N/A 33.5mm/ 30mm 86mm No Pipe N/A 79/75 119/111 163/144 196/164 217/184 274/192 230/199 232/202 233/206 - - - - Ford 2.3 Iron N/A 1.74/1.50 N/A 58/42 - 108/81 - 141/112 - 149/132 - 149/142 - - - - Ford 2.3 DP Ported Brian Iron N/A 1.74/1.50 N/A 54/48 - 115/90 - 156/113 - 179/129 - 187/137 - - - - Ford 2.3 SVO Ported N/A 1.74/1.50 N/A - - - - - - 202/156 - - - - - - Ford 2.3 SVO Turbo N/A 1.74/1.50 N/A 65/62 - 99/88 - 131/109 - 157/128 - 173/140 - - - - Ford 2.3 SVO Turbo Ported PowerHeads N/A 1.89/1.59 N/A 73/72 - 115/103 - 153/126 - 189/151 - 214/175 - - - - Ford 2.3 Esslinger Alum N/A 1.89/1.59 N/A 65/51 - 116/101 - 162/134 - 201/154 - 228/172 241/183 247/192 - - Ford 2.3 Esslinger D Alum N/A 1.89/1.59 - No Pipe N/A 54/48 - 113/87 - 171/120 - 215/143 - 242/160 253/174 - 260/182 - Ford 2.3 ARCA BOPORT Racing Heads N/A - 3.92 N/A 61/- 122/- 150/- 176/- 198/- 219/- 236/- - 252/- 275/- 290/- - - Ford 3.0 Essex v6 N/A - N/A 42/- - 81/- - 100/- - 107/- - 110/- - - - - Manufacturer Part Number Port/Vol Int/Exh Valve Size Int/Exh Combust. Chamber Vol .100 .150 .200 .250 .300 .350 .400 .450 .500 .600 .650 .700 Average Ford 3.0 Essex v6 Ported N/A - N/A 46/- - 95/- - 131/- - 152/- - 161/- - - - - Ford 4.0 Ported Super Six Motorsports Stage 2 N/A 1.81/1.54 N/A - - - - - - - - 206/160 - - - - Ford 4.0 Ported Super Six Motorsports Stage 2+ N/A 1.83/1.56 N/A - - - - - - - - 226/176 - - - - Ford 4.0 Ported Super Six Motorsports Stage 3 N/A 1.90/1.56 N/A - - - - - - - - 236/176 - - - - Ford ZTEK CNC Heads UK N/A 31.5mm/ 27.5mm N/A 85/64 129/- 171/129 198/- 208/151 216/- 222/170 225/- 227/171 - - - - Ford ZTEK Ported CNC Heads UK N/A 35mm/ 30mm N/A 85/69 129/- 172/153 206/- 233/192 247/- 256/203 262/- 265/211 - - - - Focus Zetec N/A 32mm/ 28mm N/A 79/68 - 144/126 - 175/148 - 184/155 - - - - - - Focus Zetec Alaniz Cyl Heads N/A 33mm/ 29mm N/A 74/68 - 144/114 - 173/132 - 182/139 - 186/139 - - - - Focus Zetec ZX3P 2.0l '00-04 Ported Alum N/A 33mm/ 30mm 47.7 81/75 119/109 154/145 181/168 193/186 205/188 214/193 220/195 - - - - - Focus Zetec Ported CFM Stage II N/A 33mm/ 29mm N/A 86/94 - 161/173 - 203/200 - 218/209 - - - - - - FocusSport Cosworth Zetec Focus N/A - N/A - - - - - - - - 222/175 - - - - Ford Cosworth YBT CNC Heads UK N/A 1.3/1.1 100mm No Pipe N/A 92/89 137/- 168/146 182/- 192/152 199/- 202/158 204/- 204/160 - - - - Manufacturer Part Number Port/Vol Int/Exh Valve Size Int/Exh Combust. Chamber Vol .100 .150 .200 .250 .300 .350 .400 .450 .500 .600 .650 .700 Average Ford Cosworth YB1 CNC Heads UK N/A 1.37/1.22 100mm No Pipe N/A 93/78 141/- 188/157 219/- 236/196 251/- 260/197 263/- 265/197 - - - - Ford Cosworth YB3BV CNC Heads UK N/A 1.37/1.22 100mm No Pipe N/A 99/93 148/- 197/188 236/- 265/207 292/- 308/222 316/- 320/223 - - - - Ford Fiesta Puma 1.7 CNC Heads UK N/A 1.179/1.0195 100mm No Pipe N/A 79/65 120/- 151/125 170/- 185/149 193/- 197/153 199/- 201/153 - - - - Ford Fiesta Puma 1.7 Ported CNC Heads UK N/A 1.179/1.0195 100mm No Pipe N/A 76/70 116/- 158/157 188/- 207/185 221/- 229/193 231/- 230/199 - - - - Ford CVH CNC Heads UK N/A 1.6495/1.4845 100mm No Pipe N/A 51/46 75/- 98/92 116/- 133/119 144/- 152/125 156/- 160/128 - - - - Ford CVH Ported CNC Heads UK N/A 1.6495/1.4845 100mm No Pipe N/A 58/48 88/- 117/99 144/- 164/129 178/- 189/159 197/- 201/174 - - - - Ford X2 Crossflow CNC Heads UK N/A 1.501/1.238 3.16 No Pipe N/A 48/35 72/- 95/64 109/- 120/80 122/- 124/87 124/- 126/89 - - - - Ford X2 Crossflow Ported CNC Heads UK N/A 1.545/1.322 3.16 No Pipe N/A 48/43 74/- 98/81 120/- 137/106 149/- 154/114 154/- 156/120 - - - - Ford XFLOW Ported CNC Heads UK N/A 1.625/1.377 3.16 No Pipe N/A 55/49 82/- 109/92 134/- 156/117 174/- 188/130 199/- 201/136 - - - - Ford I-6 US Iron N/A 1.65/1.38 N/A 45/36 - 87/68 - 108/91 - 119/98 - 124/103 127/105 - - - Ford I-6 OZ 250 Iron N/A 1.75/1.50 N/A 63/36 - 101/68 - 133/91 - 155/98 - 156/103 156/105 - - - Ford I-6 OZ 250 Ported Classic Inlines Iron N/A 1.75/1.50 N/A 54/45 - 105/76 - 135/92 - 163/107 - 172/119 172/126 - - - Manufacturer Part Number Port/Vol Int/Exh Valve Size Int/Exh Combust. Chamber Vol .100 .150 .200 .250 .300 .350 .400 .450 .500 .600 .650 .700 Average Ford I-6 Classic Inlines Alum N/A 1.84/1.50 N/A 52/40 - 99/79 - 143/111 - 180/144 - 201/164 210/174 - - - Ford I-6 Classic Inlines Ported Alum N/A 1.84/1.50 N/A 55/44 - 103/87 - 159/122 - 196/159 - 223/179 231/184 - - - World S/R 2.9 v6 Iron 180/64 1.657/1.419 58 - - - - - - - - - - - - - _Ford COPYRIGHT © 2000-2018 Stan Weiss — World Wide Enterprises Manufacturer Part Number Port/Vol Int/Exh Valve Size Int/Exh Combust. Chamber Vol 2mm 4mm 6mm 8mm 10mm 11mm 12mm 13mm 14mm 16mm 18mm Average Ford Cosworth YB MORGO Systems N/A 35mm/31mm - Pipe N/A 66/- 124/- 150/- 163/- 171/- 173/- 175/- 176/- - - - - Ford Cosworth YB Ported MORGO Systems for std cams N/A - N/A 64/- 129/- 178/- 201/- 208/- 210/- 210/- - - - - - Ford Cosworth YB Ported MORGO Systems for 11 mm lift cams N/A - N/A 72/- 143/- 204/- 235/- 248/- 252/- 255/- 257/- - - - - Ford 1.6 OHC Pinto Ported /Andre' Norrback Epoxy N/A 42mm/34mm 85mm No Pipe N/A 38/- 76/- 110/- 139/- 152/- - 154/- - 154/- - - - Ford OHC Pinto Ported /Andre' Norrback Rally N/A 44.5mm/ 38mm 98mm No Pipe N/A 46/- 91/- 135/- 166/- 185/- - 195/- - 202/- 202/- - - Ford OHC Pinto Ported /Andre' Norrback N/A 46mm/ 38mm 98mm No Pipe N/A 48/40 89/74 136/100 174/119 202/130 - 215/142 - 206/144 206/146 - - Ford OHC Pinto Ported /Andre' Norrback N/A 44mm/ 36mm 98mm No Pipe N/A 49/- 92/- 137/- 179/- 208/- - 221/- - 227/- 227/- - - Ford 2.0 OHC Pinto Ported /Andre' Norrback Rally N/A 46mm/36mm 98mm No Pipe N/A 52/- 98/- 144/- 188/- 215/- - 233/- - 236/- 236/- - - Ford OHC Pinto Ported /Andre' Norrback N/A 46mm/- N/A 50/- 96/- 142/- 180/- 207/- - 227/- - 240/- 245/- 248/- - Pinto Ported /Andre' Norrback N/A 52mm/ 40mm 98mm No Pipe N/A 53/48 101/80 148/109 189/136 229/160 - 254/176 - 279/186 295/195 312/202 - Pinto Ported /Andre' Norrback N/A 52mm/ 40mm 100mm No Pipe N/A 54/48 103/80 150/109 196/136 238/160 - 267/176 - 290/186 310/195 326/202 - Ford CVH MORGO Systems N/A 41.9mm/- N/A 39/- 69/- 97/- 119/- 128/- 133/- 136/- 139/- - - - - Manufacturer Part Number Port/Vol Int/Exh Valve Size Int/Exh Combust. Chamber Vol 2mm 4mm 6mm 8mm 10mm 11mm 12mm 13mm 14mm 16mm 18mm Average Ford CVH Ported MORGO Systems N/A 41.9mm/- N/A 51/- 92/- 140/- 175/- 190/- 193/- 196/- 198/- 199/- - - - Ford RS 2000/2300 MORGO Systems N/A 33.5mm/- N/A 69/- 127/- 161/- 171/- 179/- 182/- 184/- 186/- - - - - Ford RS 2000/2300 Ported MORGO Systems N/A 33.5mm/- N/A 63/- 126/- 177/- 204/- 222/- 228/- 233/- 236/- - - - - V6 3.5 3.7 EcoBoost COPYRIGHT © 2000-2018 Stan Weiss — World Wide Enterprises Manufacturer Part Number Port/Vol Int/Exh Valve Size Int/Exh Combust. Chamber Vol .150 .250 .350 .450 .550 .600 .650 .700 .800 .900 Average Ford Super Six Motorsports With Stock Intake manifold N/A 37mm/31mm N/A 122/100 189/151 235/176 257/189 262/191 - - - - - - Ford Ported Super Six Motorsports With Ported Intake manifold 204/95 1.45/1.22 N/A 136/120 237/180 279/231 302/250 317/260 - - - - - - V6 3.8 COPYRIGHT © 2000-2018 Stan Weiss — World Wide Enterprises Manufacturer Part Number Port/Vol Int/Exh Valve Size Int/Exh Combust. Chamber Vol .100 .200 .300 .400 .500 .600 .650 .700 .800 .900 Average Ford 3.8 SC Redline Performance Mustangs N/A 1.78/1.46 N/A - - - - 158/106 - - - - - - Ford 3.8 SC / Single Port N/A 1.78/1.46 N/A 52/40 82/71 111/95 144/113 170/123 181/127 183/129 - - - - Ford 3.8 SC / Single Port Ported Coy Miller N/A 1.85/1.625 N/A 56/50 113/103 164/144 199/187 216/201 225/208 226/206 - - - - Ford 3.8 SC Ported Stiegemeier Racing N/A 1.875/1.60 N/A - 131/120 181/166 217/206 229/212 232/215 - - - - - Ford 3.8 SC Ported Super Six Motorsports Stage 2 N/A 1.78/1.45 N/A - - - - - 203/154 - - - - - Ford 3.8 SC Ported Super Six Motorsports Stage 2+ N/A 1.83/1.50 N/A - - - - - 215/165 - - - - - Ford 3.8 SC Ported Super Six Motorsports Stage 3 88-95 N/A 1.85/1.55 N/A - - - - - 228/189 - - - - - Ford 3.8 SC Ported Redline Performance Mustangs 88-95 N/A 1.84/1.60 N/A - - - - 210/153 - - - - - - Ford 3.8 SC Ported Super Six Motorsports Stage 3 96-98 N/A 1.90/1.56 N/A - - - - - 240/181 - - - - - Ford 3.8 SC Ported Redline Performance Mustangs 96-98 N/A 1.86/1.55 N/A - - - - 210/153 - - - - - - Ford 3.8 Single Port Ported Matt SF600 N/A 1.84/1.575 - No Pipe N/A 86/48 168/99 216/151 251/205 279/235 294/260 305/264 312/267 - - - Ford 3.8 Split Port Ported Slvr 2000 N/A 1.94/1.55 N/A 69/59 164/104 198/142 239/173 268/201 294/224 - 319/231 - - - Manufacturer Part Number Port/Vol Int/Exh Valve Size Int/Exh Combust. Chamber Vol .100 .200 .300 .400 .500 .600 .650 .700 .800 .900 Average Ford 3.8 Split Port Ported "J" N/A 1.94/1.55 - No Pipe N/A 91/60 162/112 213/145 242/175 270/204 298/231 - - - - - Ford 3.8/4.2 Split Port Redline Performance Mustangs N/A 1.86/1.46 - No Pipe N/A 63/46 - - - 199/122 - - - - - - Ford 3.8/4.2 Split Port Ported Redline Performance Mustangs N/A 1.94/1.55 - No Pipe N/A 80/59 142/110 198/140 224/163 238/169 253/170 - - - - - Ford 3.8/4.2 Ported Super Six Motorsports Stage 2 N/A 1.86/1.45 N/A - - - - - 230/150 - - - - - Ford 3.8/4.2 Ported Super Six Motorsports Stage 2+ N/A 1.90/1.50 N/A - - - - - 240/160 - - - - - Ford 3.8/4.2 Ported Super Six Motorsports Stage 3 N/A 1.94/1.56 N/A - - - - - 260/170 - - - - - Cleveland COPYRIGHT © 2000-2018 Stan Weiss — World Wide Enterprises Manufacturer Part Number Port/Vol Int/Exh Valve Size Int/Exh Combust. Chamber Vol .100 .200 .300 .400 .500 .600 .700 .800 .900 1.000 Average Boss 302 C4V Iron N/A 2.19/1.67 N/A - - - 210/154 246/169 274/178 - - - - - Boss 302 C4V Mark Workman Iron N/A 2.19/1.67 N/A 71/60 149/99 221/128 269/154 287/168 290/176 298/178 - - - - Ford 351 C2V Iron N/A 2.03/1.67 N/A - - - 200/143 - 199/163 - - - - - Ford 351 C2V Iron N/A 2.03/1.67 N/A - - - 203/145 - 230/172 - - - - - Ford 351 C4V D1ZE-GA Iron 244/137 2.19/1.71 76 - - - - - 284/154 - - - - - Ford 351 C4V CHI Iron N/A 2.19/1.71 N/A 64/38 113/78 166/112 209/135 245/155 267/160 275/- - - - - Ford 351 C4V Iron N/A 2.19/1.71 N/A - 131/88 188/129 220/146 256/159 269/165 279/166 - - - - Ford 351 C4V D0AE Closed Chamber Mark Workman Iron N/A 2.19/1.71 N/A 72/54 145/94 212/126 270/151 299/172 302/185 304/185 - - - - Ford 351 C4V Hans Ported Iron N/A 2.19/1.71 N/A 82/45 160/65 232/145 294/176 - - - - - - - Ford 351 C4V Glen Ported Iron N/A 2.19/1.71 N/A 65/56 123/100 188/139 246/166 294/183 322/186 333/185 - - - - Ford 4V Closed Chamber Dr Js Performance Iron N/A 2.19/1.70 - Pipe N/A 70/58 135/99 195/131 247/156 282/168 289/177 290/181 290/180 - - - Ford 4V Closed Chamber Ported Dr Js Performance Iron N/A 2.25/1.70 - Pipe N/A 82/68 153/110 224/149 291/180 326/198 340/211 355/225 364/228 - - - Manufacturer Part Number Port/Vol Int/Exh Valve Size Int/Exh Combust. Chamber Vol .100 .200 .300 .400 .500 .600 .700 .800 .900 1.000 Average Ford 4V Closed Chamber Ported BH Performance Iron N/A - - No Pipe N/A 70/64 131/107 198/145 248/169 300/192 322/200 330/- - - - - Ford 4V Closed Chamber Ported Bullet Cylinder Heads Intake Tongues are fitted Iron 259/- 2.19/1.71 68 71/58 144/109 212/153 256/180 289/207 318/218 342/225 - - - - Ford Aussie 2V PowerHeads SF600 Iron N/A 2.04/1.67 69 59/44 112/79 156/109 178/130 187/153 191/172 - - - - - Ford Aussie 2V Ported PowerHeads SF600 Iron N/A 2.19/1.71 62 79/75 154/109 206/156 231/180 244/200 253/209 - - - - - Ford Aussie 2V Ported John Brides Iron N/A 2.08/1.65 N/A 73/51 158/97 225/120 240/139 246/160 - - - - - - Ford C302 C302B 212/95 2.15/1.65 62 - - - - - - 325/- - - - - Ford C302B Stiegemeyer Racing SF600 Ported 217/112 2.19/1.65 4.155 No Pipe N/A 81/73 157/131 223/180 266/210 306/223 331/228 325/- - - - - Ford C302B SVO Ported Bullet Cylinder Heads Alum N/A 2.19/1.65 N/A 75/77 144/128 210/164 260/196 298/216 326/227 348/235 - - - - Ford D302 D302B 212/95 2.15/1.65 62 - - - - - - 325/- - - - - Ford 351M/400 D5AE-A2A Matt SF1020 Iron N/A 2.041/1.654 N/A - 114/76 172/106 193/130 201/149 206/155 - - - - - AFD 2V Alum 200/115 2.08/1.60 N/A - 124/105 179/140 231/164 271/176 290/185 - - - - - AFD 4V Closed Chamber SF300 Alum 235/115 2.15/1.65 N/A 70/55 147/108 215/151 269/185 298/205 316/216 330/221 - - - - Manufacturer Part Number Port/Vol Int/Exh Valve Size Int/Exh Combust. Chamber Vol .100 .200 .300 .400 .500 .600 .700 .800 .900 1.000 Average AFD 4V Ported Dr Js Performance Alum N/A 2.19/1.70 - Pipe N/A 78/52 150/108 216/146 277/174 318/207 331/224 348/236 362/243 - - - Avenger XTC 351-C CNC Alum 265/90 2.25/1.74 60/70 75/65 145/111 217/138 281/165 328/214 344/233 350/247 360/260 - - - Blue Thunder Low-Ex Alum N/A - N/A - - - - - - - 325/210 - - - Blue Thunder Ported Alum N/A 2.10/1.65 N/A - - - - - - - 380/265 - - - Blue Thunder Hi-Ex Alum N/A 2.20/1.70 N/A - - - - - - - 325/240 - - - Blue Thunder Ported Hi-Ex Alum N/A 2.20/1.71 N/A - - - - - - - 395/285 - - - Blue Thunder Stage 3 Ported Alum 220/- 2.20/1.71 N/A - - - - - - 400/300 - - - - Blue Thunder Comp Ported Alum N/A 2.25/1.70 4.155 N/A - - - - - - 423/311 - - - - Blue Thunder Custom Performance Stage IV Ported Hi-Ex Alum N/A 2.20/1.71 N/A - - - - - - - 410/295 - - - Blue Thunder Ported Dave Jack Alum N/A 2.20/1.70 4.155 No Pipe 52 - - - - - - 415/289 - - - - Blue Thunder Ported Chad Speier v3.10 Alum N/A 2.15/1.71 4.155 No Pipe N/A - 141/104 214/144 272/186 328/217 369/243 382/249 388/254 391/258 395/263 - Blue Thunder 3.6 Ported Chad Speier Alum 260/- 2.15/1.71 - No Pipe 55 - 141/104 226/144 288/180 339/196 376/244 390/258 394/265 397/268 402/270 - Manufacturer Part Number Port/Vol Int/Exh Valve Size Int/Exh Combust. Chamber Vol .100 .200 .300 .400 .500 .600 .700 .800 .900 1.000 Average CHI 2V Alum 190/- 2.07/1.65 N/A 77/64 147/114 207/153 255/185 286/200 300/214 298/222 - - - - CHI 3V Alum 185/- 2.08/1.65 N/A 77/64 147/114 201/153 250/191 286/208 290/222 - - - - - CHI 3V Alum 208/- - N/A 77/64 139/114 200/153 248/191 288/208 314/219 - - - - - CHI 3V CNC Alum 218/- 2.15/1.65 N/A 64/52 124/94 179/130 234/159 282/193 314/217 334/230 350/243 - - - CHI 3V Ported Kelford Cams Alum 218/- 2.15/1.65 N/A 70/57 140/112 197/168 254/194 305/209 336/224 341/234 - - - - CHI 3V Alum 225/- 2.15/1.65 N/A 70/64 140/114 205/153 259/191 295/208 322/219 340/228 - - - - CHI 3V Ported Bullet Cylinder Heads Alum 237/121 2.19/1.71 69 82/60 148/110 205/152 256/209 295/224 326/245 352/252 - - - - CHI 3V CNC Alum 260/- - N/A 78/60 150/111 210/150 270/188 315/208 340/223 360/260 370/230 - - - CHI 3V CNC Darin Morgan (EMC) Alum 252.5/- 2.18/1.60 42 - 148/- 231/- 304/- 364/- 390/- 402/- 406/- 411/- - - CHI 4V Alum 228/- 2.19/1.65 N/A 76/64 145/114 - 256/185 295/200 315/214 325/222 - - - - 3V Ported P. I. Motorsorts Alum 213/- 2.19/1.71 60 - 149/102 210/137 257/162 298/185 317/203 321/221 - - - - CHI CNC Dr Js Performance I-50 Alum N/A 2.18/- N/A 68/- 138/- 228/- 288/- 321/- 363/- 386/- 394/- 408/- 416/- - Manufacturer Part Number Port/Vol Int/Exh Valve Size Int/Exh Combust. Chamber Vol .100 .200 .300 .400 .500 .600 .700 .800 .900 1.000 Average CHI Kaase 2.85 C-400 Alum N/A 2.19/1.65 45 69/45 153/111 225/163 285/210 337/233 373/245 396/253 400/253 - - - CHI Kaase 3.1 C-400 Alum N/A 2.19/1.65 45 68/45 149/111 228/163 294/210 348/233 381/245 397/253 400/253 - - - Edelbrock Performer RPM 61629 SF1020 Alum 190/90 2.05/1.60 60 58/54 120/105 180/138 227/151 260/161 265/165 - - - - - Edelbrock Performer RPM Alum 190/90 2.05/1.60 60 70/49 139/93 205/123 242/145 268/161 272/172 - - - - - P I Motorsports 3V Alum 213/- 2.19/1.71 60 - 149/102 210/137 257/162 298/185 318/203 -/221 - - - - Pro Comp Alum 220/90 2.19/1.71 60 65/50 107/86 162/122 208/145 245/160 267/168 - - - - - Pro Comp Ported Speed-O-Motive Alum 230/110 2.19/1.71 74 65/54 141/108 200/147 247/176 285/200 318/217 335/230 342/238 - - - Pro Comp Ported Dr Js Performance I-52 Alum 265/- 2.20/1.70 80 79/- 161/- 231/- 295/- 339/- 373/- 395/- 404/265 406/- 409/- - Pro Comp Ported Chad Speier Alum 260/- 2.15/- N/A - 140/- 202/- 260/- 310/- 341/- 352/- 361/- - - - Pro Comp Ported Chad Speier V2.90 I-45 E-45 Alum 250/- 2.19/1.71 N/A - 140/115 202/150 260/184 310/217 339/232 352/239 361/243 - - - Trick Flow SF600 Alum 190/- 2.08/1.60 62 - - - - - 280/230 - - - - - Trick Flow Bowl Blended SF600 Alum 190/112 2.08/1.60 4.03 1 7/8" Pipe 62 68/55 140/111 202/151 248/187 286/217 299/232 - - - - - Manufacturer Part Number Port/Vol Int/Exh Valve Size Int/Exh Combust. Chamber Vol .100 .200 .300 .400 .500 .600 .700 .800 .900 1.000 Average Trick Flow CNC TEA Alum 225/115 2.08/1.60 4.125 1 7/8" Pipe 60 68/55 146/115 223/162 282/204 313/231 336/240 339/244 - - - - Modular COPYRIGHT © 2000-2018 Stan Weiss — World Wide Enterprises Manufacturer Part Number Port/Vol Int/Exh Valve Size Int/Exh Combust. Chamber Vol .100 .200 .300 .400 .500 .550 .600 .700 .800 .900 Average 2V '92-'98 / NPI 146/- 44.5mm/ 34mm 51 - - - - 156/116 - - - - - - '96 Non P.I. N/A - N/A 46/- 84/- 121/- 147/- 170/- 176/- - - - - - '96-'98 Non P.I. Ported Steen Racing N/A - N/A - - - - - 190/165 - - - - - '96-'98 Non P.I. 4.6L Ported BH Performance N/A 44.5mm/ 34mm - No Pipe N/A 69/58 118/87 161/142 201/169 216/186 - 227/191 - - - - '96-'98 Non P.I. 4.6L Ported Renegade N/A 44.5mm/ 34mm N/A 67/62 120/97 165/137 193/152 210/164 - 222/174 - - - - '01 P.I. Alum N/A - N/A 54/- 98/- 135/- 156/- 166/- 168/- - - - - - '99 & up P.I. Alum 159/- 44.5mm/ 36mm 42 - - - - - 163/150 - - - - - '99 & up P.I. FPS Alum N/A 44.5mm/ 36mm N/A 54/55 102/91 139/121 159/142 169/142 - 165/150 176/153 - - - '99 & up P.I. Ported FPS Alum N/A 45.2mm/ 36.8mm N/A 57/57 109/98 157/136 180/172 204/187 - 215/194 226/209 - - - '99 & up P.I. Ported Steen Racing Stage 1 Alum N/A - N/A 57/52 119/94 146/102 176/149 210/170 - - - - - - '99 & up P.I. Ported Steen Racing Stage 2 Alum N/A - N/A 69/68 128/104 154/102 181/163 216/181 - - - - - - '99 & up P.I. Fox Lake 5.0 S/F Alum N/A 44.5mm/ 36mm N/A 55/55 90/86 130/121 142/143 150/150 161/153 - - - - - Manufacturer Part Number Port/Vol Int/Exh Valve Size Int/Exh Combust. Chamber Vol .100 .200 .300 .400 .500 .550 .600 .700 .800 .900 Average '99 & up P.I. Ported Stage 1 Fox Lake 5.0 S/F Alum N/A 44.5mm/ 36mm N/A 60/60 100/90 142/127 169/150 187/164 190/172 - - - - - '99 & up P.I. Ported Stage 2 Fox Lake 5.0 S/F Alum N/A 44.5mm/ 36mm N/A 61/64 103/96 151/133 179/169 205/175 220/181 - - - - - '99 & up P.I. 4.6L Ported BH Performance Alum N/A - - No Pipe N/A 63/68 114/116 162/157 199/187 213/194 - 222/204 - - - - '99 GT 5.0 S/F Alum N/A 44.5mm/ 36mm N/A - 111/95 150/123 170/139 179/150 180/154 181/155 - - - - '99 GT Ported Stage III 5.0 S/F Alum N/A 44.5mm/ 36mm N/A - 125/101 165/129 191/147 204/160 209/164 212/166 - - - - 4.6L 2V P.I. HRM Alum N/A 44.5mm/36mm N/A 54/55 107/91 139/121 159/137 169/142 - 175/150 - - - - 4.6L 2V P.I. Ported HRM Alum N/A - N/A 57/56 107/98 154/133 179/169 194/182 - 203/185 - - - - 4.6L 2V P.I. PowerHeads SF600 Alum N/A - N/A 63/65 112/101 148/132 172/150 178/161 180/162 182/162 - - - - 4.6L 2V P.I. Performance C.A.P.A. Performance Alum N/A 46.83mm/ 35.88mm 53 - - - - - 185/148 - - - - - 4.6L 2V P.I. Ported C.A.P.A. Performance Alum N/A 45mm/ 36mm 47 - - - - - - 225/205 - - - - 4.6L 2V P.I. CNC Livernois Motorsports Stage II Alum N/A 45mm/ 36mm N/A - - - - - - 207/195 - - - - 4.6L 2V P.I. CNC Livernois Motorsports Stage III Alum N/A 45.5mm/ 37mm N/A - - - - - - 225/205 - - - - Manufacturer Part Number Port/Vol Int/Exh Valve Size Int/Exh Combust. Chamber Vol .100 .200 .300 .400 .500 .550 .600 .700 .800 .900 Average 4.6L 2V P.I. CNC M2 Race Systems Alum 187/- 45.5mm/ 37mm 3.575 N/A 59/49 116/91 164/124 193/148 211/163 - 221/173 - - - - 4.6L 2V P.I. Ported PowerHeads SF600 Alum N/A - N/A 89/84 146/137 182/172 212/189 226/200 231/202 232/202 - - - - 4.6L 2V P.I. Ported Patriot Performance Stage I Alum N/A 1.752/1.417 3.552 N/A 60/52 107/94 152/130 185/160 209/178 211/185 214/192 - - - - 4.6L 2V P.I. Ported Renegade N/A - N/A 64/52 116/94 162/130 192/160 213/178 - 217/185 - - - - 4.6L P.I. / 5.4L 2V Ported Patriot Performance Stage II SF1020 Alum 180/67 1.781/1.452 3.552 46 64/52 116/98 162/135 192/162 213/182 217/189 218/193 - - - - 4.6L P.I. / 5.4L 2V Ported Patriot Performance Stage III Alum 180/67 1.84/1.452 3.552 46 68/53 121/100 169/138 203/165 219/186 227/196 233/201 - - - - 4.6L P.I. / 5.4L 2V TEA Stage 2 Alum N/A 1.78/1.45 N/A 60/52 114/100 161/138 192/170 212/194 219/199 221/202 - - - - 4.6L P.I. / 5.4L 2V TEA Stage 3 Alum N/A 1.84/1.45 N/A 56/55 112/100 160/139 202/167 226/188 235/196 243/204 - - - - 5.4L 2V '99-04 LFP Stage II Alum 180/67 1.78/1.45 46 65/51 118/99 162/135 191/165 214/184 218/188 223/196 - - - - Lightning PI Ported collins SF600 Alum N/A 44.5mm/ 36mm N/A 60/60 101/101 144/134 179/156 207/178 - 220/191 - - - - Lightning PI Ported Smithberg Racing Alum N/A 44.5mm/ 36mm 3.625 No Pipe N/A 71/43 133/78 183/116 212/151 226/178 229/187 233/191 236/199 - - - '00 F-150 Dale SF600 Alum N/A 44.5mm/ 36mm N/A 54/50 103/104 143/126 162/138 172/143 175/145 - - - - - Manufacturer Part Number Port/Vol Int/Exh Valve Size Int/Exh Combust. Chamber Vol .100 .200 .300 .400 .500 .550 .600 .700 .800 .900 Average '00 F-150 Ported Dale SF600 Alum N/A 44.5mm/ 36mm N/A 61/57 111/96 153/130 186/164 212/180 218/184 220/190 - - - - Motorsport 2V SVO N/A - N/A - - - - - 215/147 - - - - - Motorsport 2V SVO 173/- 46.8mm/ 35.8mm 53 - - - - 193/140 - - - - - - Motorsport 2V SVO 173/- 46.8mm/ 35.8mm 53 - - - - - - 206/142 - - - - Motorsport 2V SVO Mild Porting 200/- 46.8mm/ 35.8mm 3.50 No Pipe 56 60/48 125/91 182/131 215/162 235/184 242/190 243/192 - - - - Motorsport 2V SVO Ported Fox Lake N/A 46.8mm/ 35.8mm 3.55 N/A 72/60 143/103 195/135 214/153 238/185 248/194 257/196 - - - - 3V Stock Blow-By Racing Alum N/A 33.8mm/ 37.5mm N/A 77/53 147/98 200/120 216/138 223/148 - 225/154 - - - - 3V Ported Blow-By Racing Alum N/A 33.8mm/ 37.5mm N/A 75/46 162/104 228/136 274/163 284/177 - 293/190 - - - - 3V Stock PowerHeads SF600 Alum N/A 33.8mm/ 37.5mm N/A 74/71 146/119 198/145 217/170 225/190 225/193 225/196 - - - - 3V Ported PowerHeads SF600 Alum N/A 33.8mm/ 37.5mm N/A 84/81 160/128 212/169 247/195 265/212 270/218 271/226 - - - - 3V Stock Fox Lake MMFF Alum N/A 33.8mm/ 37.5 3.55 N/A - - - - 220/165 - 228/175 - - - - 3V Ported Fox Lake MMFF Alum N/A 33.8mm/ 37.5mm 3.55 N/A - - - - 256/188 - 269/203 - - - - Manufacturer Part Number Port/Vol Int/Exh Valve Size Int/Exh Combust. Chamber Vol .100 .200 .300 .400 .500 .550 .600 .700 .800 .900 Average 3V Ported Fox Lake Alum N/A 33.8mm/ 37.5mm 3.55 N/A - - 221/142 249/175 264/190 - 272/204 - - - - 3V CNC M2 Race Systems Alum N/A 34mm/ 37.5mm 3.575 N/A 85/47 177/98 233/129 260/153 273/172 - 283/189 - - - - 3V Ported Sutton High Performance Alum N/A 33.8mm/ 37.5mm N/A - - 223/143 264/173 288/189 - 298/198 - - - - 3V Ported TEA Stage 1 Alum N/A 33.8mm/ 37.5mm - Pipe N/A 84/51 159/108 221/153 264/182 279/209 283/216 287/223 - - - - 3V Ported PSI Performance Alum N/A 33.8mm/ 38.5mm N/A 129/91 172/119 235/154 248/179 263/198 272/201 281/205 - - - - 3V Stock Livernois Motorsports Alum N/A 33.8mm/ 37.5mm N/A 84/54 145/100 208/125 217/153 227/153 - 227/158 - - - - 3V CNC Livernois Motorsports Stage II Alum N/A 34mm/ 37.5mm N/A - - - - - - 280/185 - - - - 3V CNC Livernois Motorsports Alum N/A 35mm/ 38.5mm N/A 99/47 188/106 237/141 259/162 272/176 - 282/186 - - - - 3V CNC Livernois Motorsports Stage III Alum N/A 35mm/ 38.5mm 3.552 N/A 131/65 219/126 268/166 285/186 291/205 - 301/215 - - - - 3V CNC FORD Motorsports Alum N/A 35mm/ 38.5mm N/A - - - - - - 295/200 - - - - 3V '05 Stock 5.0 S/F Alum N/A 33.8mm/ 37.5mm N/A - 146/107 208/130 229/147 235/159 237/163 238/165 - - - - 4V FR500 Alum N/A 37mm/ 30mm N/A - - - - 233/168 - - - - - - Manufacturer Part Number Port/Vol Int/Exh Valve Size Int/Exh Combust. Chamber Vol .100 .200 .300 .400 .500 .550 .600 .700 .800 .900 Average 4V FR500 CNC M2 Race Systems Alum N/A 37mm/ 30mm 3.575 N/A 99/84 182/135 251/181 294/209 318/226 - 330/234 - - - - 4V '93-'98 "B" Stock Gamrace Alum N/A 37mm/30mm 3.57 N/A - 144/106 194/126 218/145 234/146 - 230/152 - - - - 4V '93-'98 "B" Sportman CNC Gamrace Alum N/A 37mm/30mm 3.57 N/A - 166/113 230/140 262/160 280/165 - 277/170 - - - - 4V '93-'98 "B" Stage 2 CNC Gamrace Alum N/A 37mm/30mm 3.57 N/A - 166/119 230/153 262/189 280/204 - 277/215 - - - - 4V '97 Cobra 5.0 S/F Alum N/A 37mm/ 30mm N/A - 168/141 224/162 246/167 249/168 - - - - - - 4V '99 Cobra 5.0 S/F Alum N/A 37mm/ 30mm N/A - 170/140 220/160 237/169 243/169 - - - - - - 4V Cobra Stock Alum N/A 37mm/ 30mm N/A - - - - - 260/201 - - - - - 4V Cobra 92-98 "B" 99-02 "C" Ported Fox Lake Alum N/A 37mm/ 30mm 3.55 N/A - - 241/219 293/249 315/264 324/270 - - - - - 4V Cobra Ported Fox Lake Stage 3 Alum N/A - N/A - - - - - - 350/300 - - - - 4V Cobra M2 Race Systems Alum N/A 37mm/ 30mm 3.575 N/A 89/67 168/121 224/160 253/179 267/182 - 275/185 280/186 - - - 4V Cobra CNC M2 Race Systems Alum 219/- 37mm/ 30mm 3.575 N/A 89/75 168/140 234/181 284/210 304/224 - 321/231 325/236 - - - 4V Cobra Stage I Ported TMS Alum N/A - N/A - - - - - 290/195 - - - - - Manufacturer Part Number Port/Vol Int/Exh Valve Size Int/Exh Combust. Chamber Vol .100 .200 .300 .400 .500 .550 .600 .700 .800 .900 Average 4V Cobra Stage II Ported TMS Alum N/A - N/A - - - - - 306/202 - - - - - 4V Cobra '96-'98 Ported TEA Alum N/A - N/A 87/76 155/153 228/214 283/248 305/269 - - - - - - 4V Cobra '03-'up Ported TEA Alum N/A - N/A 89/73 174/149 255/209 300/243 324/263 - - - - - - 4V Navigator Ported Fox Lake SF600 Alum N/A - 3.55 No Pipe N/A 94/88 182/158 247/204 279/225 304/236 310/238 314/242 - - - - 4V '03 5.0 S/F Alum N/A 37mm/ 30mm 3.57 N/A 95/74 161/126 226/159 259/171 266/175 268/176 - - - - - 4.6L 4V '96-'98 Ported Stage 1 C.A.P.A. Performance Alum N/A - N/A - - - - 272/172 - - - - - - 4.6L 4V '96-'98 Ported Stage 2 C.A.P.A. Performance Alum N/A - 43 - - - - 287/194 - - - - - - 4.6L 4V '96-'98 Ported Full C.A.P.A. Performance Alum N/A - 52 - - - - 304/241 - - - - - - 4.6L 4V '99-'01 Ported Stage 1 C.A.P.A. Performance Alum N/A - 54 - - - - 257/185 - - - - - - 4.6L 4V '99-'01 Ported Stage 2 C.A.P.A. Performance Alum N/A - 54 - - - - 273/195 - - - - - - 4.6L 4V '99-'01 Ported Full C.A.P.A. Performance Alum N/A - 54 - - - - 288/237 - - - - - - 4.6L 4V '99-up PowerHeads SF600 Alum N/A 37mm/ 30mm N/A 93/78 170/127 221/167 245/184 257/189 258/193 258/195 - - - - Manufacturer Part Number Port/Vol Int/Exh Valve Size Int/Exh Combust. Chamber Vol .100 .200 .300 .400 .500 .550 .600 .700 .800 .900 Average 4.6L 4V '99-up Ported PowerHeads SF600 Alum N/A - N/A 95/85 173/157 243/195 290/209 305/217 307/220 307/224 - - - - 4.6L 4V '99-up Ported TEA Alum N/A - N/A 95/85 178/165 245/225 283/247 307/255 313/259 320/260 - - - - 4.6L 4V Ported Patriot Performance Stage 1.5 Alum N/A - 3.552 N/A 97/75 178/136 245/187 289/214 308/225 313/230 316/233 - - - - 5.0L 4V '11 Alum 193/- 37mm/ 31mm N/A - - - - - - - - - - - 5.0L 4V '11- Ported TEA Alum N/A 37mm/ 31mm 3.70 Pipe N/A 91/82 165/160 228/206 283/219 305/228 318/231 - - - - - Trick Flow Twisted Wedge 2V SF600 Alum 185/93 1.84/1.45 38/42 56/43 122/96 173/135 213/164 233/175 241/177 236/180 - - - - Trick Flow Twisted Wedge 2V SF600 Alum 185/93 1.84/1.45 3.564 38 58/46 124/99 176/141 218/170 241/175 - 242/183 - - - - Trick Flow Twisted Wedge 2V Alum 185/93 1.84/1.45 3.564 1 3/4" Pipe N/A 58/49 125/101 175/143 224/174 250/179 - 252/188 - - - - Trick Flow Twisted Wedge 2V CNC Alum 195/95 1.90/1.47 44 - - - - - - - - - - - Trick Flow Twisted Wedge 2V Ported HRM Alum N/A 1.84/1.45 3.564 N/A 71/60 139/108 195/151 238/183 268/197 - 291/206 - - - - Trick Flow Twisted Wedge 2V CNC Chamber TFS-51910001-CNC SF600 Alum 185/93 1.84/1.45 3.562 1 3/4" Pipe 38/42 59/57 131/107 188/151 230/188 250/204 - 257/211 - - - - Trick Flow Twisted Wedge 2V Fox Lake SF600 Alum N/A 1.84/1.45 3.552 N/A 66/60 121/102 185/141 223/179 239/197 241/201 242/203 - - - - Manufacturer Part Number Port/Vol Int/Exh Valve Size Int/Exh Combust. Chamber Vol .100 .200 .300 .400 .500 .550 .600 .700 .800 .900 Average Trick Flow Twisted Wedge 2V Ported Fox Lake SF600 Alum N/A 1.84/1.45 3.552 N/A 67/62 124/106 189/143 227/190 255/205 263/209 271/211 - - - - Trick Flow Twisted Wedge 2V Ported Fox Lake MMFF Alum N/A 1.84/1.45 3.552 N/A 69/62 130/118 189/158 235/195 259/189 - 269/195 - - - - Windsor COPYRIGHT © 2000-2018 Stan Weiss — World Wide Enterprises Manufacturer Part Number Port/Vol Int/Exh Valve Size Int/Exh Combust. Chamber Vol .100 .200 .300 .400 .500 .600 .700 .800 .900 1.000 Average Ford 289 Iron N/A 1.78/1.45 N/A - - - - 165/107 - - - - - - Ford 289 HiPo Iron N/A 1.78/1.45 53.5 - - 139/98 161/113 170/121 177/125 - - - - - Ford 289-302-5.0 PowerHeads SF600 Iron N/A 1.78/1.45 N/A 52/39 95/74 132/96 141/104 154/107 152/107 - - - - - Ford 289-302-5.0 Ported PowerHeads SF600 Iron N/A 1.94/1.60 N/A 64/62 122/109 174/150 202/169 215/175 219/180 - - - - - Ford 302 '73 CCM Iron N/A 1.78/1.45 4.03 1 3/4" Pipe 62 56/43 107/79 141/110 155/120 163/125 167/129 - - - - - Ford 302 E7TE Iron 127/44 1.78/1.45 N/A 52/39 95/74 132/98 143/104 159/109 - - - - - - Ford 302 E7TE Iron CCM 127/44 1.78/1.46 N/A 59/39 109/73 142/100 148/110 150/113 - - - - - - Ford 302 E7TE Iron MMFF N/A 1.78/1.46 N/A 55/40 110/75 142/101 160/110 157/112 155/111 - - - - - Ford 302 E7TE Ported Thumper Iron N/A 1.78/1.46 N/A 73/54 121/104 178/135 197/150 219/155 220/160 - - - - - Ford 302 E7TE Ported PowerHeads SF600 Iron N/A 1.90/1.60 N/A 63/62 124/109 189/150 213/169 217/174 - - - - - - Ford 302 E7TE Ported McCoy Iron N/A - N/A - - - - 240/166 - - - - - - Ford GT-40 E7TZ 145/55 1.84/1.54 60 64/52 111/98 159/125 183/129 187/129 192/129 - - - - - Manufacturer Part Number Port/Vol Int/Exh Valve Size Int/Exh Combust. Chamber Vol .100 .200 .300 .400 .500 .600 .700 .800 .900 1.000 Average Ford GT-40P E7TZ CCM 145/55 1.85/1.46 60 58/45 121/88 159/112 186/125 190/127 195/128 195/128 - - - - Ford GT-40X Iron CCM 176/- 1.94/1.54 64 57/49 110/89 162/123 193/150 215/155 230/155 - - - - - Ford GT-40X Ported Iron N/A 1.94/1.54 N/A 63/50 125/99 184/145 224/170 245/178 254/174 - - - - - Ford GT-40X X302 X306 X307 Alum 178/62 1.94/1.54 64/58 - - - - 239/170 - - - - - - Ford GT-40 Y303 Alum 166/54 1.94/1.54 54 64/52 114/98 166/128 199/136 212/134 217/- - - - - - Ford GT-40 X303 X305 Alum 178/62 1.94/1.54 64/58 64/60 130/112 184/143 220/163 238/173 249/175 - - - - - Ford GT-40 Y302 Alum 160/53 1.94/1.54 N/A - - - - - - - - - - - Ford GT-40 Y302 Y303 (SVO) Ported Gamrace Alum 163/- 1.94/1.54 66 - 135/110 182/145 225/166 258/182 274/189 270/193 - - - - Ford Z304 Alum 204/85 2.02/1.60 63 65/56 135/113 199/172 245/200 272/213 - - - - - - Ford Z304 Westech Alum 200/- 2.02/1.60 59 61/50 132/95 187/131 234/160 252/174 259/180 262/180 - - - - Ford Z304 CNC Alum N/A 2.02/1.60 63 69/61 149/110 225/159 278/192 314/221 - - - - - - Ford Z304 Ported ET Performance Alum 226/- 2.08/1.60 4.03 68 76/54 147/108 221/154 273/197 300/214 314/223 326/232 - - - - Manufacturer Part Number Port/Vol Int/Exh Valve Size Int/Exh Combust. Chamber Vol .100 .200 .300 .400 .500 .600 .700 .800 .900 1.000 Average Ford Z304 Ported Gamrace Alum 220/- 2.08/1.60 68 - - 205/150 260/193 295/220 312/229 318/238 - - - - Ford Z304 Ported Gamrace Alum 230/- 2.08/1.60 68 - - 203/150 266/193 295/220 318/229 335/238 - - - - Ford 351 Iron N/A 1.84/1.54 58 - - - - - 177/142 - - - - - Ford 351 Iron N/A 1.84/1.54 58 - - 152/107 171/113 181/115 189/115 - - - - - Ford 351 PowerHeads SF600 Iron N/A 1.84/1.54 N/A 56/39 99/74 136/96 151/104 163/107 166/109 - - - - - Ford 351 Ported PowerHeads SF600 Iron N/A 1.94/1.60 N/A 69/62 128/109 182/150 206/169 225/175 232/180 - - - - - Ford 351 Ported Darrell Iron 160/- 2.00/1.585 - 1 3/4" Pipe 59 - 125/108 179/144 218/170 246/181 249/181 - - - - - Ford 351 DOOE Iron N/A 1.90/1.60 4.00 No Pipe 60 69/45 111/80 153/105 183/109 183/111 183/113 - - - - - Ford N351 Iron 195/67 2.02/1.60 4.04 No Pipe 64 - 141/97 160/127 212/142 232/161 244/169 255/172 - - - - Ford N351 Ported Stage 2 Beasley Engineering Iron 206/73 2.02/1.60 4.04 No Pipe 58 - 137/94 165/133 221/167 257/208 278/221 296/236 - - - - Ford N351 Ported Full Beasley Engineering Iron 219/78 2.08/1.60 4.04 No Pipe 58 87/59 155/103 203/143 251/208 287/226 305/246 309/254 - - - - Ford N351 CNC M2 Race Systems Iron 219/- 2.08/1.60 66 - - 198/122 241/175 268/208 279/220 292/227 303/232 - - - Manufacturer Part Number Port/Vol Int/Exh Valve Size Int/Exh Combust. Chamber Vol .100 .200 .300 .400 .500 .600 .700 .800 .900 1.000 Average Ford N351 Tri-Mark Iron 194/- 2.02/1.60 N/A 61/60 120/107 173/126 210/140 230/158 235/169 236/176 - - - - Ford N351 Ported Tri-Mark Stealth Iron 200/- 2.02/1.60 N/A 70/59 145/112 200/147 230/177 247/191 257/199 263/204 - - - - Ford N351 Stock Bill Jones BUT 2.05 Iron N/A 2.05/1.60 4.03 No Pipe N/A 64/50 119/98 160/125 195/137 223/149 233/161 - - - - - Ford N351 Ported Bill Jones Iron N/A 2.05/1.60 4.03 No Pipe N/A 68/54 128/102 183/154 221/181 253/195 276/206 - - - - - Ford N352 Tri-Mark Iron 185/- 2.02/1.60 N/A 61/60 120/107 173/126 210/140 230/158 235/169 236/176 - - - - Ford N352 Ported Tri-Mark Stealth Iron 197/- 2.02/1.60 N/A 70/59 135/112 197/147 223/177 242/191 257/199 263/204 - - - - Ford N352 Ported Tri-Mark Super Stealth Iron N/A 2.02/1.60 N/A 69/55 149/112 200/149 231/177 255/197 271/208 280/215 - - - - Ford SC1 Ported Bullet Cylinder Heads Small Port Volume N/A 2.18/1.60 N/A 77/60 160/109 221/155 278/190 321/226 345/252 370/261 380/266 - - - Ford SC1 Ported ET Performance 272/- 2.18/1.60 4.155 58 68/56 151/114 225/166 291/205 343/223 371/232 382/240 389/246 - - - Ford SC1 Head Circle Ported HRD N/A 2.18/1.625 N/A - 157/111 232/176 297/224 342/254 383/269 398/278 413/286 - - - Ford SC1 Bennett Ported N/A 2.20/1.60 N/A - - - - - - - 420/290 - - - Ford SC1 CNC M2 Race Systems 273/- 2.18/1.60 4.155 62 58/50 129/105 205/155 276/209 328/237 374/249 405/253 412/261 - - - Manufacturer Part Number Port/Vol Int/Exh Valve Size Int/Exh Combust. Chamber Vol .100 .200 .300 .400 .500 .600 .700 .800 .900 1.000 Average Ford 233 Raised Seat Ported Chapman 233/- 2.15/1.60 - No Pipe 52 71/53 149/114 236/152 282/190 327/228 358/238 360/251 364/255 - - - Ford Yates/C3L/C3 210/119 2.10/1.60 N/A - - - - - - - - - - - Ford Yates/C3L Ported SF600 N/A 2.10/1.60 4.07 No Pipe N/A 73/54 148/112 234/152 289/206 325/225 340/243 348/258 - - - - Ford Yates/C3L 215 Ported Chapman 215/- 2.125/1.60 - No Pipe 52 70/53 146/114 228/152 291/190 332/228 347/238 347/251 - - - - Ford Yates/C3L 221 Ported Chapman 221/- 2.10/1.60 - No Pipe 66 72/53 145/110 215/162 285/202 313/228 328/239 340/247 - - - - Ford Yates/C3L/C3 233 Ported Chapman 233/- 2.10/1.60 - No Pipe 50-60 75/53 143/110 220/162 286/202 310/228 328/239 337/247 - - - - Ford Yates/C3 239 Ported Alum 239/- 2.10/1.60 4.06 2 1/4" Pipe N/A 73/54 146/104 217/145 269/179 306/206 317/229 311/244 318/268 - - - Ford Yates/C3L Ported 241/- 2.15/1.585 51 - 150/102 226/151 286/200 334/226 361/240 366/245 - - - - Ford Yates/C3L Ported Automotive Specialists 242/- 2.10/1.60 64 - 154/119 226/164 276/198 322/220 341/229 345/236 - - - - Ford Yates/C3 Ported Greg Good N/A 2.125/1.625 - No Pipe N/A - - 243/172 300/212 331/236 362/252 374/260 381/264 - - - Ford Yates/C3 Cup Head Ported HRD N/A 2.16/1.58 N/A - 145/114 224/171 291/232 339/252 364/265 379/272 - - - - Ford Yates/C3 Cup Head N/A - N/A - - - - 362/262 383/278 388/286 391/296 - - - Manufacturer Part Number Port/Vol Int/Exh Valve Size Int/Exh Combust. Chamber Vol .100 .200 .300 .400 .500 .600 .700 .800 .900 1.000 Average Ford C35 210/119 2.10/1.60 N/A - - - - - - - - - - - Ford C35 Head Ported HRD N/A 2.125/1.60 N/A - 150/115 233/153 302/225 339/250 357/266 366/274 - - - - Ford C3H Ported N/A 2.20/1.60 N/A - - - - - - - 400/275 - - - Ford D3 Head Circle Ported HRD N/A 2.16/1.61 N/A - 161/111 246/161 315/215 346/246 381/261 395/270 404/276 - - - Ford D3 Head Circle Ported HRD N/A 2.18/1.625 N/A - 149/120 243/169 310/229 355/250 386/258 401/256 410/273 - - - Ford D3 Head Drag Ported HRD 285/- 2.20/1.61 N/A - 149/115 238/169 311/226 350/251 383/265 405/272 418/285 430/291 - - Ford D3 Head Ported MBE 308/162 2.20/1.60 - No Pipe N/A - 140/102 224/146 305/195 370/228 412/259 442/270 449/275 451/278 453/- - Ford D3 Head Ported MBE I-55 E-55 SF1020 324/162 2.225/1.57 4.155 No Pipe N/A - 133/99 221/147 301/192 364/220 406/240 438/261 444/270 442/275 450/280 - Ford D3 Head Ported 280/150 2.18/1.625 48 - 154/101 230/140 301/206 351/237 381/253 393/263 400/272 - - - Ford D3 Head Ported N/A 2.20/1.60 N/A - 123/140 196/140 267/187 331/220 368/245 393/263 400/272 413/281 417/287 - AFR 165 Street SF600 Alum 165/69 1.90/1.60 4.06 1 3/4" Pipe 58-64 - 123/118 186/153 225/178 243/185 250/191 - - - - - AFR 165 Street CCM Alum 165/- 1.90/1.60 N/A 60/51 123/108 176/144 210/174 232/184 232/188 235/189 - - - - Manufacturer Part Number Port/Vol Int/Exh Valve Size Int/Exh Combust. Chamber Vol .100 .200 .300 .400 .500 .600 .700 .800 .900 1.000 Average AFR 165 #1402 Weingartner Racing Alum N/A 1.90/1.60 4.155 N/A 57/54 113/112 171/151 216/180 236/191 238/195 244/197 247/- - - - AFR 165 Street Nitrous Exhaust SF600 Alum 165/69 1.90/1.60 4.06 1 3/4" Pipe 58-64 - 123/129 186/171 225/199 243/211 250/218 - - - - - AFR 165 Comp SF600 Alum N/A 1.90/1.60 4.06 1 3/4" Pipe 58 - 129/121 186/155 228/192 242/207 254/215 - - - - - AFR 165 CNC SF600 Alum 165/- 1.90/1.60 4.06 1 3/4" Pipe 55-60 - 135/122 200/163 240/192 251/208 260/215 - - - - - AFR 165 Ported CCM Alum N/A 1.90/1.60 4.03 1 3/4" Pipe N/A 59/57 127/114 189/164 225/194 245/203 252/209 - - - - - AFR 185 Street/Strip SF600 Alum 185/69 2.02/1.60 4.06 1 3/4" Pipe 58-64 - 129/118 189/153 234/178 267/185 277/191 - - - - - AFR 185 Street/Strip Nitrous Exhaust SF600 Alum 185/69 2.02/1.60 4.06 1 3/4" Pipe 58-64 - 129/129 189/171 234/199 267/211 277/218 - - - - - AFR 185 Comp SF600 Alum N/A 2.02/1.60 4.06 1 3/4" Pipe N/A - 136/125 200/180 245/211 272/225 287/231 - - - - - AFR 185 Comp Ported CCM Alum N/A 2.02/1.60 4.03 1 3/4" Pipe N/A 66/59 148/113 202/162 242/199 274/215 286/222 296/227 - - - - AFR 185 CNC SF600 Alum 185/70 2.02/1.60 4.06 1 3/4" Pipe N/A - 142/118 200/164 255/200 285/210 297/215 - - - - - AFR 185 Street Ported ET Performance Alum N/A 2.02/1.60 4.03 61 78/56 152/123 214/155 252/183 266/196 284/201 289/204 - - - - AFR 190 Ported SF600 Alum 190/- 2.02/1.60 4.060 1 3/4" Pipe N/A - 152/121 211/158 257/193 290/214 310/222 - - - - - Manufacturer Part Number Port/Vol Int/Exh Valve Size Int/Exh Combust. Chamber Vol .100 .200 .300 .400 .500 .600 .700 .800 .900 1.000 Average AFR 195 CNC SF600 Alum 195/70 2.02/1.60 4.06 1 3/4" Pipe N/A - 152/126 208/171 260/207 287/222 308/231 - - - - - AFR 205 Race SF600 Alum 205/70 2.08/1.60 4.125 1 7/8" Pipe 58 - 141/125 201/180 251/211 291/225 306/231 310/235 - - - - AFR 205 Race Nitrous Exhaust SF600 Alum 205/70 2.08/1.60 4.125 1 7/8" Pipe 58 - 141/121 201/173 251/208 291/231 306/240 310/244 - - - - AFR 205 Ported ET Performance Alum 205/- 2.08/1.60 4.03 58 76/57 145/116 205/156 259/185 296/200 307/207 308/210 316/214 - - - AFR 205 Race SF600 Alum 205/70 2.08/1.60 4.06 1 3/4" Pipe 58 - 149/126 205/170 260/210 291/227 315/231 327/234 - - - - AFR 205 Race Nitrous Exhaust SF600 Alum 205/73 2.08/1.60 4.06 1 3/4" Pipe 58 - 149/121 205/173 260/208 291/231 315/240 327/244 - - - - AFR 220 CNC SF600 220/70 2.10/1.60 4.125 1 7/8" Pipe 58-69 - 154/129 207/188 267/230 302/245 321/251 333/255 340/258 - - - AFR 225 Old Race SF600 225/80 2.08/1.60 4.125 1 7/8" Pipe 60 - 149/130 216/187 264/230 295/242 312/250 320/255 - - - - AFR 225 Race SF600 225/80 2.08/1.60 4.125 1 7/8" Pipe 60 - 143/130 211/187 260/230 289/242 317/255 325/258 - - - - AFR 225 Out of Box 225/80 2.08/1.60 60 - 147/110 205/152 257/211 287/225 299/229 312/230 - - - - AFR 225 Ported ET Performance 225/- 2.08/1.60 4.03 58 74/56 146/115 207/157 262/195 299/210 312/219 323/223 327/- - - - Avenger Alum N/A 2.02/1.60 58 - - - - - 270/205 - - - - - Manufacturer Part Number Port/Vol Int/Exh Valve Size Int/Exh Combust. Chamber Vol .100 .200 .300 .400 .500 .600 .700 .800 .900 1.000 Average Avenger 185 CNC Alum 185/80 2.02/1.60 60/70 69/59 129/118 188/153 234/178 269/189 278/195 281/210 288/228 - - - Avenger 205 CNC Alum 205/80 2.05/1.60 60/70 70/61 142/124 190/162 252/200 284/218 299/225 305/230 309/235 - - - Avenger 215 CNC Alum 215/80 2.05/1.60 60/70 75/61 146/106 194/162 254/200 287/216 300/226 310/235 310/235 - - - Avenger 230 CNC 20 Deg Alum 230/82 2.08/1.60 60/70 74/68 147/125 205/178 258/215 289/227 308/235 318/245 322/245 - - - Avenger 230 R CNC 20 Deg Alum 230/82 2.08/1.60 60/70 78/68 150/125 212/178 260/215 291/227 315/235 329/245 339/245 - - - Avenger AK-400 CNC Alum 270/- 2.15/1.60 47/52 79/57 154/112 212/147 275/197 325/227 371/242 409/257 417/266 - - - Avenger SX1-SC1 CNC Alum 260/105 2.15/1.60 46/68 76/56 144/110 212/145 279/197 326/222 372/238 391/252 412/266 - - - Blue Thunder Alum 220/- - N/A - - - - - - 360/270 - - - - Blue Thunder Out of Box Alum N/A 2.15/1.625 N/A 84/71 160/130 236/168 293/193 332/214 361/224 - - - - - Blue Thunder Ported Flatlanders Stage 3 Alum 220/ 2.20/1.71 N/A - - - - - - 400/300 - - - - Blue Thunder Ported Flatlanders Comp Alum N/A 2.225/1.70 4.155 N/A - - - - - - 423/311 - - - - Blue Thunder 4.3 Ported ET Performance Alum 270/- 2.18/1.60 4.155 66 66/52 145/116 221/155 302/180 350/225 400/245 408/258 410/265 414/274 416/280 - Manufacturer Part Number Port/Vol Int/Exh Valve Size Int/Exh Combust. Chamber Vol .100 .200 .300 .400 .500 .600 .700 .800 .900 1.000 Average Blue Thunder 4.3 Ported ET Performance Alum 290/- 2.20/1.60 4.125 66 67/52 147/116 227/155 313/180 368/225 411/245 422/258 427/265 435/274 440/280 - Blue Thunder 4.3 Ported ET Performance Alum 300/- 2.25/1.60 4.125 66 67/52 144/104 239/138 314/165 367/186 408/234 434/250 437/260 436/274 440/280 - Blue Thunder 3.6 Ported ET Performance Alum 255/- 2.20/1.625 4.155 55 74/62 145/110 209/148 271/181 321/209 351/231 362/243 370/252 - - - Blue Thunder Ported CPF SF600 Alum N/A 2.26/- 4.125 N/A 62/- 139/- 224/- 317/- 381/- 425/- 439/- 450/- 453/- 458/- - Blue Thunder Ported SF600 Alum N/A - 4.155 N/A 59/- 133/- 220/- 305/- 358/- 413/- 426/- 426/- 431/- 431/- - Brodix SP FO Alum 195/- 2.08/1.60 67 - 120/103 180/130 224/153 241/166 255/179 267/191 270/202 - - - Brodix Track 1 53/119 Alum 195/- 2.08/1.60 68 - 124/100 172/129 212/153 241/166 255/176 261/180 - - - - Brodix T1 F Std X SUPR Alum 195/- 2.08/1.60 67 - 120/103 180/130 224/159 255/179 267/191 270/202 - - - - Brodix Track 1 X 53/119 Alum 195/- 2.08/1.60 68 - 124/100 172/134 212/164 241/184 255/195 261/203 - - - - Brodix Track 1 CNC M2 Race Systems 53/119 Alum 211/- 2.08/1.60 4.03 76 - 136/115 194/156 247/198 287/214 312/220 315/225 - - - - Brodix T1 Std 20 Deg CNC M2 Race Systems 53/119 Alum 211/- 2.08/1.60 68 - 150/124 216/164 263/196 300/211 316/217 317/224 - - - - Brodix T1 STS Std 214 20 Deg CNC 53/119 Alum 214/- 2.08/1.60 68 - 140/119 210/161 265/190 298/203 320/212 326/220 - - - - Manufacturer Part Number Port/Vol Int/Exh Valve Size Int/Exh Combust. Chamber Vol .100 .200 .300 .400 .500 .600 .700 .800 .900 1.000 Average Brodix T1 STS Std 225 20 Deg CNC 53/119 Alum 225/- 2.08/1.60 68 - 147/119 215/161 262/190 303/203 324/212 334/220 - - - - Brodix T1 Std 20 Deg Ported Jones Engineering I-45 E-45 Alum 218/- 2.08/1.60 72 - 126/95 185/128 239/177 282/212 306/224 313/230 319/236 - - - Brodix ST 5.0 & ST 5.0 R 20 Deg 53/119 Alum 171/- 1.94/1.60 60 - 130/100 186/132 225/156 237/172 241/184 - - - - - Brodix ST 5.0 R 20 Deg CNC M2 Race Systems 53/119 Alum 185/- 2.02/1.60 4.03 66 - 145/119 208/150 245/179 272/198 277/209 281/216 - - - - Brodix ST 5.0 R Ported Chad Speiers V2.50 SF600 53/119 Alum N/A 2.08/1.60 4.06 1 7/8" Pipe 68 - 134/111 194/147 240/180 272/203 294/217 310/229 322/233 327/238 328/242 - Brodix ST 5.0 R Ported Chad Speiers 53/119 Alum 225/- 2.10/1.60 4.06 68 - 138/113 199/148 238/180 276/203 303/217 321/227 327/235 333/239 337/241 - Brodix ST 5.0 Ported Fox Lake 53/119 Alum 187/80 2.02/1.60 4.03 62 - - 201/147 243/192 269/211 285/219 - - - - - Brodix KC LH F 17 Deg 195 CNC 53/119 Alum 195/- 2.02/1.60 60 - 154/119 219/169 260/200 287/209 294/214 300/214 - - - - Brodix KC LH F 17 Deg 210 CNC 53/119 Alum 210/- 2.08/1.60 59 - 151/113 223/166 269/200 300/217 319/222 323/222 - - - - Brodix KC 195 S 17 Deg Keith Craft 53/119 Alum 195/- 2.02/1.60 2" Pipe 59 - 155/114 217/162 266/202 293/223 300/234 305/235 - - - - Brodix KC 210 S 17 Deg Keith Craft 53/119 Alum 210/- 2.08/1.60 2" Pipe 59 - 146/117 211/171 261/216 297/237 322/247 328/252 325/254 - - - Brodix Neal BF200 Ported Alum 248/- 2.125/1.60 46 - 165/110 224/151 279/201 325/231 355/244 364/253 - - - - Manufacturer Part Number Port/Vol Int/Exh Valve Size Int/Exh Combust. Chamber Vol .100 .200 .300 .400 .500 .600 .700 .800 .900 1.000 Average Brodix Neal BF200 Ported Al Neal Alum 293/- 2.125/1.60 46 - 177/109 245/148 309/206 333/234 365/245 388/267 - - - - Brodix Neal BF200 Ported TEA Alum 318/- 2.225/1.60 4.155 Pipe 40-47 63/58 137/119 227/161 299/228 359/271 393/292 414/303 421/310 428/316 435/320 - Brodix Neal BF201-202 Ported Alum 255/- 2.18/1.60 46 - 153/105 218/143 277/200 333/236 370/249 388/258 391/263 - - - Brodix Neal BF201 Ported Chapman Alum 287/157 2.18/1.625 - No Pipe 44.5 64/52 142/107 221/164 284/208 339/236 379/242 385/251 387/254 - - - Brodix Neal BF202 Alum 277/- 2.18/1.60 49 - 136/109 221/165 276/207 327/235 368/245 391/253 - - - - Brodix Neal BF202 used CHW Alum 280/156 2.18/1.60 - No Pipe 57 66/57 139/100 193/128 245/177 290/196 311/211 331/228 352/244 - - - Brodix Neal BF202 Ported Bennett Alum N/A - N/A - - - - - - - 425/300 - - - Brodix Neal BF202 Ported TEA Alum 260/- 2.125/- N/A - - - - - - - 380/- - - - Brodix Neal BF202 Ported TEA Alum 295/- - N/A - - - - - - - 400/- - - - Brodix Neal BF202 Ported TEA Alum 311/- - N/A 70/61 145/116 227/163 304/226 365/264 398/284 420/296 432/306 - - - Brodix Neal BF202 Ported TEA Alum 311/- 2.20/1.60 56-58 64/61 137/116 230/163 300/226 360/264 389/284 411/296 424/306 - - - Brodix Neal Bennett Ported N/A - N/A - - - - - - - 420/280 - - - Manufacturer Part Number Port/Vol Int/Exh Valve Size Int/Exh Combust. Chamber Vol .100 .200 .300 .400 .500 .600 .700 .800 .900 1.000 Average Brodix Neal BF300-301 Ported Alum 196/- 2.125/1.60 65 - 152/122 214/166 265/195 300/213 325/220 331/225 334/228 - - - Brodix BF301 HRD Ported Alum N/A 2.125/1.60 65 - 143/128 218/172 290/221 321/230 354/259 362/266 - - - - Brodix Neal Ported ET Performance Alum N/A 2.10/1.60 4.125 N/A 70/53 147/110 230/164 291/205 344/232 380/250 406/261 406/269 410/275 - - Canfield 170 Alum 170/- 2.02/1.60 - No Pipe 61 - 123/89 166/123 207/148 237/174 - - - - - - Canfield 192 SF600 Alum 192/- 2.02/1.60 - No Pipe 54/58/65 70/54 150/102 204/132 242/171 262/190 272/201 274/207 - - - - Canfield 193 Out of Box plus VJ SF600 Alum 193.7/- 2.02/1.60 - 1 3/4" Pipe N/A 78/63 157/108 209/140 251/178 268/193 280/203 283/210 - - - - Canfield 195 VJ SF600 Alum 195/- 2.02/1.60 4.03 1 3/4" Pipe 54/58/65 - 150/107 203/131 243/171 263/183 272/190 276/201 281/209 - - - Canfield 215 Ported TEA Alum 215/- - N/A 66/54 144/116 219/165 261/211 281/237 300/253 310/264 - - - - Canfield Ported Fox Lake Alum N/A 2.02/1.60 70 - - - 277/217 - - 300/230 - - - - Canfield Ported Alum N/A 2.02/1.60 N/A - 133/102 191/152 243/185 276/206 288/216 300/221 - - - - Canfield Ported Doug Alum N/A 2.02/1.60 N/A 68/61 138/118 208/167 255/198 282/211 296/224 - - - - - CFE ProKing 10 Deg Alum N/A - N/A - - - - - - - -/255 410/- - - Manufacturer Part Number Port/Vol Int/Exh Valve Size Int/Exh Combust. Chamber Vol .100 .200 .300 .400 .500 .600 .700 .800 .900 1.000 Average Dart '98 Flowtech - Steven Magnotti 3 Angle VJ SF110 Alum 197/- 2.02/1.60 4.00 No Pipe N/A 61/49 120/101 164/125 199/146 218/156 242/160 254/- - - - - Dart Windsor Kendrick Auto N/A 2.02/1.60 N/A 75/58 127/115 175/122 214/154 235/168 247/171 250/171 - - - - Dart Windsor Ported Kendrick Auto N/A 2.02/1.60 N/A 79/59 149/120 184/144 238/179 267/195 295/202 301/205 - - - - Dart 180 Iron Eagle 180/73 1.94/1.60 4.03 No Pipe 62 - 125/112 178/139 226/152 247/159 256/161 260/163 - - - - Dart 200 Iron Eagle 200/73 2.02/1.60 - No Pipe 58/62 - 154/112 208/139 254/152 271/159 274/161 276/163 - - - - Dart PRO1 170 No Back Cut Alum 170/65 1.94/1.60 4.03 No Pipe 62 - 137/112 200/151 240/171 251/173 261/172 - - - - - Dart PRO1 195 No Back Cut Alum 195/75 2.02/1.60 4.155 No Pipe 62 - 145/116 205/150 246/172 272/180 283/184 288/185 - - - - Dart PRO1 210 CNC 20 Deg SF600 Alum 210/76 2.05/1.60 4.03 No Pipe 62 - 132/108 195/151 252/187 287/203 305/208 304/212 - - - - Dart PRO1 225 CNC 20 Deg SF600 Alum 225/85 2.08/1.60 4.155 No Pipe 62 - 136/115 201/164 259/205 300/225 323/231 325/238 - - - - Dart PRO1 CNC 20 Deg Alum 225/87 2.08/1.60 4.155 No Pipe 62 - 136/115 201/164 259/205 300/225 323/230 325/235 - - - - Edelbrock E-Street 5023, 5025 SF1020 Alum 170/60 1.90/1.60 60 65/42 121/92 174/130 216/150 242/162 249/168 - - - - - Edelbrock E-Street 5023, 5025 SF1020 Alum 170/60 2.02/1.60 60 65/42 121/92 174/130 216/150 242/162 249/168 - - - - - Manufacturer Part Number Port/Vol Int/Exh Valve Size Int/Exh Combust. Chamber Vol .100 .200 .300 .400 .500 .600 .700 .800 .900 1.000 Average Edelbrock E-Street Ported Fox Lake SF600 Alum 200/- 2.02/1.60 4.03 N/A 72/69 140/120 208/175 250/199 273/217 303/235 - - - - - Edelbrock 6022, 6032 OLD Alum 170/60 1.90/1.60 60 72/57 132/104 183/142 214/163 225/170 224/174 - - - - - Edelbrock 6025, 6035 OLD Alum 170/60 2.02/1.60 60 70/57 128/104 183/142 219/163 229/172 226/174 - - - - - Edelbrock Performer 60329, RPM 60299 SF1020 Alum 170/60 1.90/1.60 N/A 72/57 132/104 183/142 216/159 245/170 249/174 244/175 - - - - Edelbrock Performer 60359, RPM 60259, 60399 Alum 170/60 2.02/1.60 N/A 70/57 128/104 183/142 219/163 251/170 255/174 246/175 - - - - Edelbrock Performer RPM Ported Fox Lake SF600 Alum 200/- 2.02/1.60 4.03 65 73/65 142/118 208/159 247/204 277/221 300/230 - - - - - Edelbrock Performer 5.0/5.8l 60289, 60379 SF1020 Alum 170/60 1.90/1.60 60 72/57 131/105 185/131 214/156 223/168 226/175 - - - - - Edelbrock Performer 5.0/5.8l 60299, 60399 SF1020 Alum 170/60 2.02/1.60 60 70/57 130/104 185/142 219/163 229/172 226/175 - - - - - Edelbrock/ Glidden 51319 CNC Alum 169/68 1.94/1.57 60 72/60 140/115 203/165 247/192 260/203 261/207 - - - - - Edelbrock/ Glidden 51309 CNC Alum 188/68 2.02/1.57 60 77/60 147/115 212/165 259/192 284/203 293/207 285/209 - - - - Edelbrock/ Glidden Victor Ported ET Performance Alum 300/- 2.16/1.57 4.125 59 66/50 140/114 212/153 281/186 323/220 355/244 372/256 378/267 383/273 - - Edelbrock/ Glidden Victor Ported Jim Kuntz Alum 312/97 2.18/1.58 45 - - - - - - - - 394/253 - - Manufacturer Part Number Port/Vol Int/Exh Valve Size Int/Exh Combust. Chamber Vol .100 .200 .300 .400 .500 .600 .700 .800 .900 1.000 Average Edelbrock/ Glidden Victor 15 Deg CNC 61099 Alum 280/94 2.15/1.56 - No Pipe 61 78/55 152/110 230/182 275/216 330/230 355/238 365/242 - - - - Edelbrock/ Glidden Victor 15 Deg CNC Chapman 6109 Alum 280/95 2.15/1.56 - No Pipe 61 72/57 144/98 211/130 266/163 313/206 343/225 364/234 368/243 - - - Edelbrock/ Chapman Victor 15 Deg CNC 61299 Alum 276/95 2.10/1.65 61 70/53 141/105 212/182 273/204 315/227 343/237 355/242 - - - - Edelbrock/ Chapman Victor 15 Deg CNC 6129 Chapman Alum 277/95 2.15/1.625 61 70/53 141/105 212/166 273/204 315/227 343/237 355/242 357/251 - - - Edelbrock Victor 15 Deg 612969 SF1020 Alum 240/80 2.125/1.625 47 76/67 141/110 203/152 256/187 298/210 323/215 339/220 - - - - Edelbrock Victor 15 Deg 77219 Alum 240/80 2.125/1.625 47 76/67 141/110 203/152 256/187 298/210 323/215 339/220 - - - - Edelbrock Victor 15 Deg 7721 Ported Chad Speier Alum N/A 2.18/- 4.155 N/A - 145/- 217/- 275/- 329/- 366/- 384/- 390/- 394/- - - Edelbrock Victor 15 Deg 7721 Ported Chad Speier Alum 290/- 2.18/1.60 4.155 2" Pipe 58 - 151/111 229/164 285/207 337/237 367/255 375/266 386/272 389/275 393/278 - Edelbrock Victor 15 Deg 7721 Ported BuschRacing I-45 E-45 Alum N/A 2.125/1.625 4.06 N/A - - 222/185 273/223 325/249 362/262 375/270 383/278 381/285 - - Edelbrock Victor Ported Fox Lake Stage 1 Alum 281/- 2.125/1.625 38-62 - - - - - - 366/281 - - - - Edelbrock Victor Ported Fox Lake Stage 2 Alum 301/- 2.20/1.625 38-62 - - - - - - - 381/281 - - - Edelbrock Victor Ported Bennett Alum N/A - 40/60 - - - - - - - 410/285 - - - Manufacturer Part Number Port/Vol Int/Exh Valve Size Int/Exh Combust. Chamber Vol .100 .200 .300 .400 .500 .600 .700 .800 .900 1.000 Average Edelbrock Victor -13 Ported Bennett Alum 266/- 2.18/1.56 N/A 70/52 148/97 225/140 277/174 324/212 366/238 378/258 388/264 392/271 - - Edelbrock Victor -13 Ported Bennett Alum N/A 2.18/1.58 42 - - - - - - - - 400/272 - - Edelbrock Victor -15 Ported Bennett Alum 272/- 2.18/1.60 N/A 68/50 144/95 210/140 262/180 305/215 344/240 374/262 400/274 409/276 - - Edelbrock Victor Ported Fox Lake Stage 1 Alum 251/- 2.125/1.625 38/56 - - - - - - 351/255 - - - - Edelbrock Victor Ported Fox Lake Stage 2 Alum 293/- 2.205/1.625 38/56 - - - - - - - 376/274 - - - Edelbrock Victor 7721 Ported Gamrace Alum 290/- 2.18/1.625 58 - - 210/165 276/215 331/240 368/255 391/265 391/270 - - - Edelbrock Victor 7708 Ported Gamrace Alum 310/- 2.20/1.60 36 - - 223/152 288/204 337/236 365/254 382/260 397/265 400/270 - - Edelbrock Victor Ported TEA Alum N/A 2.12/1.62 N/A 75/61 149/125 231/180 274/230 313/263 345/280 359/295 - - - - Edelbrock Victor Ported TEA Alum 280/- 2.15/1.625 N/A 71/61 147/117 224/173 278/218 320/252 358/274 365/287 - - - - Edelbrock Victor Ported TEA Alum 295/- 2.18/1.60 N/A 66/61 136/108 216/163 278/224 333/264 380/280 390/285 - - - - Edelbrock Victor Ported TEA Alum 305/- - N/A 66/57 136/108 214/154 278/228 339/260 379/282 395/286 399/294 - - - Edelbrock Victor Ported ET Performance Alum N/A 2.20/1.60 4.155 57 66/49 144/100 208/161 279/212 325/243 350/265 370/271 384/273 391/275 - - Manufacturer Part Number Port/Vol Int/Exh Valve Size Int/Exh Combust. Chamber Vol .100 .200 .300 .400 .500 .600 .700 .800 .900 1.000 Average Edelbrock Victor Jr. 20 Deg 77169, 77179, 77189, 77199, SF1020 Alum 210/75 2.05/1.60 60/70 64/54 127/108 186/140 234/167 268/189 291/195 285/199 - - - - Edelbrock Victor Jr. Alum CCM N/A 2.05/1.60 N/A 66/53 127/109 186/150 233/179 266/193 276/201 276/204 - - - - Edelbrock Victor Jr. Ported Fox Lake Stage 1 Alum 210/- 2.055/1.60 60/70 - - - - - 280/220 - - - - - Edelbrock Victor Jr. Ported Fox Lake Stage 2 Alum 215/- 2.055/1.60 65 - - - - - - 308/230 - - - - Edelbrock Victor Jr. Ported Fox Lake Stage 3 OLD Alum 223/- 2.055/1.60 N/A - - - - - - 320/240 - - - - Edelbrock Victor Jr. Ported Fox Lake Stage 3 Alum 230/- 2.08/1.625 65/75 - - - - - - 332/255 - - - - Edelbrock Victor Jr. Gamrace Alum N/A 2.05/1.60 N/A - - 182/145 225/166 258/182 274/189 270/103 - - - - Edelbrock Victor Jr. CNC Chambers Gamrace Stage 1 Alum 217/- 2.08/1.60 64 - - 198/165 253/190 290/210 306/220 306/225 - - - - Edelbrock Victor Jr. CNC Race Gamrace Stage 1 Alum 232/- 2.08/1.60 66 - - 208/160 263/195 300/224 321/238 327/244 332/247 - - - Edelbrock Victor Jr. Ported Modern Cylinder Heads Alum N/A 2.055/1.60 N/A - - - - - - 329/249 - - - - Edelbrock Victor Jr. Ported Bullet Cylinder Heads Alum 224/83 2.05/1.60 70 71/68 134/114 194/150 250/171 285/190 307/203 311/218 - - - - Edelbrock Victor Jr. 20 Deg 61269 Pro-Port CNC SF1020 Alum 230/80 2.10/1.60 4.00 60 67/51 141/110 209/174 254/207 287/218 309/218 321/224 - - - - Manufacturer Part Number Port/Vol Int/Exh Valve Size Int/Exh Combust. Chamber Vol .100 .200 .300 .400 .500 .600 .700 .800 .900 1.000 Average Edelbrock Victor Jr. 20 Deg 61279 Pro-Port CNC SF1020 Alum 230/80 2.10/1.60 4.00 60 67/52 141/110 209/173 254/210 287/221 309/224 321/227 - - - - Edelbrock Victor Jr. Ported TEA Alum 225/- 2.05/1.60 N/A 76/66 143/125 204/174 260/215 298/244 314/261 320/270 - - - - Edelbrock Victor Jr. Ported TEA Alum 225/- 2.05/1.60 4.03 Pipe 1 7/8 N/A 76/57 143/125 210/174 265/215 305/244 311/250 320/261 - - - - Edelbrock Victor Jr. Ported TEA Renegade Alum 225/- 2.05/1.60 N/A 64/52 133/122 202/175 253/219 297/247 312/266 320/278 - - - - Edelbrock/ Glidden Victor Jr. 18 Deg 61309 CNC SF1020 Alum 225/78 2.08/1.60 60 65/56 142/112 207/176 260/207 296/221 312/226 318/228 - - - - Edelbrock/ Glidden 6130 CNC Chapman Alum 212/80 2.08/1.60 - No Pipe 62 65/56 142/112 207/176 260/207 296/221 312/226 318/228 - - - - Edelbrock Victor 15 Deg 77289, 77299 Alum 255/90 2.10/1.625 48/58 68/54 145/112 215/167 266/198 303/206 323/207 327/209 - - - - Edelbrock/ Glidden II GV2 77319 Ported Chad Speier Alum N/A - 4.155 2" Pipe N/A - 140/108 216/154 281/208 336/242 380/260 405/274 417/278 420/282 429/284 - Edelbrock RPM Xtreme CNC SF1020 Alum 185/75 2.02/1.57 59 78/63 146/119 213/173 257/197 281/205 292/209 - - - - - Edelbrock Performer RPM Clevor 61629, 61699 SF1020 Alum 190/90 2.05/1.60 60 68/54 128/105 180/138 227/151 260/161 265/165 - - - - - Edelbrock/ Glidden SC-1 Port BES Alum N/A 2.25/1.60 35-49 - 143/106 226/160 295/202 354/233 405/253 423/265 439/275 448/278 457/281 - Edelbrock SC-1 Ported TEA Alum 380/- 2.225/1.60 4.185 N/A 63/53 135/113 225/170 297/232 362/270 410/294 431/312 445/321 462/328 470/333 - Manufacturer Part Number Port/Vol Int/Exh Valve Size Int/Exh Combust. Chamber Vol .100 .200 .300 .400 .500 .600 .700 .800 .900 1.000 Average Edelbrock SC-1 Ported Fox Lake SF600 Alum N/A - 4.155 N/A - 150/115 226/172 279/214 348/242 400/258 435/273 461/285 462/296 - - Flo-Tek OLD Alum 180/62 1.94/1.54 58 61/57 124/98 178/119 209/137 223/161 248/191 - - - - - Flo-Tek 180 SF1020 Alum 180/62 1.94/1.54 58 - 114/98 169/132 209/136 218/136 224/136 227/136 197/130 - - - Flo-Tek 190 SF1020 Alum 190/71 2.02/1.54 60 - 147/114 206/151 235/168 254/178 268/190 274/203 277/206 - - - Holley 5.0 Systemax 175.5/71 1.94/1.60 61 63/56 124/100 174/130 206/155 221/167 233/176 - - - - - Holley 5.0 Systemax Weingartner Racing N/A 1.94/1.60 4.155 N/A 62/59 122/98 173/124 207/143 215/156 213/163 212/167 - - - - Holley 5.0 Systemax Ported N/A 2.02/1.60 63 67/54 142/106 200/152 236/190 273/225 292/225 - - - - - Jegs Kaase Bullet Cylinder Heads Alum 248/83 2.10/1.60 66 77/64 150/109 216/160 270/209 312/222 332/229 346/235 - - - - Kaase P-38 Heads SF1020 Alum 240/86 2.10/1.60 60 - 156/111 219/142 265/169 297/185 308/199 309/208 - - - - Kaase P-38 Heads SF1020 Alum 240/86 2.10/1.60 60 - 163/110 232/153 285/194 328/222 348/233 350/238 - - - - Patriot Freedom 185 Alum 185/72 2.02/1.60 60 83/68 152/120 210/161 238/186 256/198 268/204 - - - - - Pro Comp SF600 Alum N/A 2.02/1.60 4.00 Pipe N/A - 103/101 140/136 179/169 218/172 244/170 - - - - - Manufacturer Part Number Port/Vol Int/Exh Valve Size Int/Exh Combust. Chamber Vol .100 .200 .300 .400 .500 .600 .700 .800 .900 1.000 Average Pro Comp MMFF Alum 190/- 2.02/1.60 60 59/47 116/85 167/126 213/157 241/171 251/176 258/180 - - - - Pro Comp MMFF Alum 210/- 2.02/1.60 N/A 57/55 102/91 147/131 194/160 233/170 256/174 262/177 - - - - Pro Comp CNC Alum 210/80 2.02/1.60 - 1 7/8" Pipe 64 - 135/115 193/185 232/203 258/214 277/224 - - - - - Pro Comp CNC MMFF Alum 215/- 2.05/1.60 N/A 63/53 130/102 182/139 230/166 264/186 291/198 303/205 - - - - Pro Comp CNC Alum 225/80 2.05/1.60 - 1 7/8" Pipe 64 - 147/120 205/165 258/185 289/222 306/232 314/240 - - - - Pro-Filer CNC HP Speier Racing Alum 227/- 2.08/1.60 4.03 2" Pipe N/A - 141/101 212/150 263/195 298/224 317/242 330/253 337/261 343/265 348/268 - Pro Topline CNC MMFF N/A 2.10/1.60 63 69/51 123/102 171/140 221/175 264/207 292/216 305/221 - - - - Pro Topline Cyclone CNC Gamrace Alum 215/- - 61 - 156/- 204/- 248/- 275/- 294/- 304/- 306/- - - - Pro Topline Gerald Alum 215/- 2.08/1.60 4.03 N/A - 129/- 186/- 232/- 265/- 284/- 292/- 299/- - - - Pro Topline Out of Box Weingartner Racing Alum 215/- 2.08/1.60 4.155 No Pipe N/A 60/51 118/95 155/116 210/143 258/168 287/182 291/190 290/194 294/- - - RHS CCM Alum 180/- 2.02/1.60 4.03 No Pipe N/A 63/44 118/97 172/133 223/159 249/169 255/174 266/177 - - - - RHS Pro Action / Pro Topline SF600 Alum 180 180/- 2.02/1.60 58/64 72/60 154/121 208/159 254/184 271/193 274/199 276/202 - - - - Manufacturer Part Number Port/Vol Int/Exh Valve Size Int/Exh Combust. Chamber Vol .100 .200 .300 .400 .500 .600 .700 .800 .900 1.000 Average RHS Pro Action / Pro Topline 180 CNC Livernois Motorsports SF600 Alum 195/- 2.02/1.60 4.03 No Pipe 64 66/56 141/108 215/140 252/177 278/204 298/211 - - - - - RHS Pro Action / Pro Topline 180 CNC Livernois Motorsports Alum 210/- 2.02/1.60 - 1 3/4" Pipe N/A 68/52 151/113 216/142 252/176 283/191 313/213 - - - - - RHS Westech 180 Iron 180/- 2.02/1.60 4.03 58 57/48 111/98 158/133 206/170 240/189 252/198 260/203 - - - - RHS Westech 200 Alum 200 200/- 2.02/1.60 58 65/50 118/96 167/130 216/157 254/175 271/181 277/- - - - - RHS Westech 200 Iron 200/- 2.02/1.60 4.03 58 63/50 119/104 172/140 216/174 244/193 264/203 275/209 - - - - RHS Pro Action / Pro Topline SF600 Alum 200 200/- 2.02/1.60 58/64 68/60 143/121 212/159 259/184 277/193 283/199 286/202 - - - - RHS Pro Action / Pro Topline SF600 Alum 215 215/- 2.08/1.60 58/64 75/60 151/121 217/159 267/184 302/193 310/199 314/202 - - - - RHS Pro Action / Pro Topline Alum 215 Shawn 215/- 2.08/1.60 4.125 No Pipe N/A 75/70 132/112 186/135 234/178 270/193 285/195 294/199 - - - - RHS 215 Out of Box Weingartner Racing 215/- 2.08/1.60 4.155 No Pipe N/A 70/57 141/107 200/140 238/157 271/164 287/165 290/166 294/164 291/163 - - RHS 215 Ported Weingartner Racing I-50 E-45 N/A 2.08/1.60 4.155 No Pipe N/A 65/54 146/104 217/137 263/166 301/185 330/202 342/215 342/219 344/220 - - RHS Ported Chad Speiers I-45 E-45 Iron 216/- 2.055/1.60 4.00 1 3/4" Pipe N/A - 141/110 215/157 262/193 295/211 312/219 318/228 327/233 330/236 333/238 - RHS Ported Revolutionary 227/- 2.08/1.60 4.155 No Pipe 62 73/66 138/130 205/167 258/194 296/213 319/229 333/233 339/239 342/239 - - Manufacturer Part Number Port/Vol Int/Exh Valve Size Int/Exh Combust. Chamber Vol .100 .200 .300 .400 .500 .600 .700 .800 .900 1.000 Average RHS Westech 215 Iron 215/- 2.08/1.60 4.03 58 60/52 116/102 168/134 217/172 260/181 292/190 305/200 - - - - SuperBoss 351 PowerHeads SF600 205/105 2.19/1.71 67 76/63 136/105 186/151 235/179 284/200 312/215 - - - - - SuperBoss 351 Ported PowerHeads SF600 230/125 2.19/1.71 67 90/87 149/120 210/173 257/205 305/231 341/241 - - - - - TFS Street Heat SF600 192/- 2.02/1.60 64 - - - - - 255/190 - - - - - TFS Street Heat SF600 N/A 2.08/1.60 64 - - - - - - - 340/- - - - Trick Flow 170 Ported Smithberg Racing Alum 185/- 2.02/1.60 4.03 No Pipe N/A 80/47 146/102 208/135 258/166 285/197 302/212 305/218 - - - - Trick Flow HP SF600 Alum 192/87 2.02/1.60 4.03 1 3/4" Pipe 64 67/55 133/103 186/138 230/166 257/183 267/193 - - - - - Trick Flow HP TEA SF600 Alum 192/87 2.02/1.60 4.03 1 3/4" Pipe 64 67/55 137/103 194/138 244/166 270/183 283/193 - - - - - Trick Flow HP CNC Chamber SF600 Alum 192/87 2.02/1.60 4.03 1 3/4" Pipe 64 67/55 137/103 194/138 244/166 270/183 283/193 - - - - - Trick Flow HP CNC SF600 Alum 225/95 2.08/1.60 4.03 2" Pipe 58 - - - - - - 333/255 - - - - Trick Flow HP CNC SF600 Alum 225/95 2.08/1.60 4.03 2" Pipe 70 72/58 146/117 216/162 268/210 305/234 322/247 335/257 - - - - Trick Flow HP / Street Heat Ported Fox Lake Stage 1 Alum 208/- 2.02/1.60 70 - - - - - 285/215 - - - - - Manufacturer Part Number Port/Vol Int/Exh Valve Size Int/Exh Combust. Chamber Vol .100 .200 .300 .400 .500 .600 .700 .800 .900 1.000 Average Trick Flow HP / Street Heat Ported Fox Lake Stage 2 Alum 215/- 2.055/1.60 70 - - - - - - 311/230 - - - - Trick Flow HP / Street Heat Ported Fox Lake Stage 3 Alum 227/- 2.08/1.60 72 - - - - - - 331/250 - - - - Trick Flow HP / Street Heat Ported Fox Lake Stage 5 Alum 240/- 2.08/1.625 73 - - - - - - 352/251 - - - - Trick Flow HP / Street Heat Gamrace Alum N/A 2.02/1.60 N/A - 117/102 170/138 213/166 238/183 252/193 259/- - - - - Trick Flow HP / Street Heat CNC Chamber Gamrace Alum N/A 2.02/1.60 N/A - 136/113 198/165 233/187 264/201 272/206 279/209 - - - - Trick Flow HP / Street Heat Ported Gamrace Alum 205/- 2.08/1.625 74 - - 214/173 254/202 288/215 296/222 307/227 307/232 - - - Trick Flow HP Ported Bennett Alum 227/- 2.10/1.60 56-74 - - - - - - - 332/260 - - - Trick Flow HP Ported TEA Alum N/A 2.08/- N/A - - - 281/- 306/- 324/- 333/- 340/260 - - - Trick Flow HP Ported TEA 218 Alum 218/- 2.08/1.60 N/A 72/58 144/117 205/162 261/203 295/229 316/236 332/241 - - - - Trick Flow HP Ported TEA 225 Alum 225/- 2.08/1.60 4.03 2" Pipe N/A 68/58 146/112 213/163 271/210 313/239 332/251 341/258 347/259 - - - Trick Flow HP Ported TEA 225 Alum 225/- 2.08/1.60 N/A 71/63 142/120 218/175 277/221 313/248 331/265 346/276 - - - - Trick Flow HP Ported TEA 245 Alum 245/- 2.10/1.60 4.125 2" Pipe N/A 69/51 146/112 229/168 292/209 318/238 341/258 351/269 355/270 - - - Manufacturer Part Number Port/Vol Int/Exh Valve Size Int/Exh Combust. Chamber Vol .100 .200 .300 .400 .500 .600 .700 .800 .900 1.000 Average Trick Flow HP Ported TEA 245 Alum 245/- 2.10/1.60 4.125 N/A 73/62 151/133 238/189 298/239 325/259 341/266 351/270 354/272 - - - Trick Flow HP Ported TEA 250 I-50 Alum 250/- 2.125/1.60 4.155 2" Pipe 70 65/56 142/121 214/182 270/225 322/250 346/263 360/272 369/277 373/281 377/282 - Trick Flow HP Ported TEA 255 Alum 255/- 2.125/1.58 N/A 61/51 136/121 220/175 281/221 325/250 353/267 370/274 380/281 385/284 391/285 - Trick Flow HP Ported TEA 255 I-55 Alum 255/- 2.125/1.60 4.125 2" Pipe 68 62/58 133/125 214/177 278/222 323/251 355/265 368/276 378/283 384/287 387/290 - Trick Flow HP Ported TEA Stage 3 Denny Alum N/A 2.10/1.60 53 - 148/95 216/124 265/156 294/175 309/186 309/194 313/197 - - - Trick Flow HP Ported ET Performance 230 Alum 230/- 2.055/1.60 4.06 68 72/58 144/115 215/150 262/190 293/215 314/222 325/236 - - - - Trick Flow HP Ported ET Performance 240 Alum 240/- 2.125/1.625 4.155 68 70/54 142/107 196/154 258/194 304/220 333/232 334/245 - - - - Trick Flow HP Ported M2 Race Systems Alum 238/- 2.12/1.58 4.155 72 - - - 275/160 320/210 350/240 370/252 - - - - Trick Flow TW - CARB SF600 Alum 170/66 2.02/1.60 61 63/53 141/107 205/144 233/171 251/187 251/193 - - - - - Trick Flow TW CNC 185 SF600 Alum 185/66 2.02/1.60 4.03 2" Pipe 64 72/58 142/112 216/150 258/192 287/220 301/231 - - - - - Trick Flow TW CNC 205 SF600 Alum 205/66 2.02/1.60 4.03 2" Pipe 64 71/56 144/112 220/150 270/192 299/220 316/231 - - - - - Trick Flow TW TEA 205 SF600 Alum 205/66 2.02/1.60 4.03 2" Pipe 64 71/58 143/114 221/152 271/189 301/220 315/234 - - - - - Manufacturer Part Number Port/Vol Int/Exh Valve Size Int/Exh Combust. Chamber Vol .100 .200 .300 .400 .500 .600 .700 .800 .900 1.000 Average Trick Flow TW 190 TFS-51400015 SF600 Alum 190/66 2.02/1.60 4.03 1 7/8" Pipe 64 69/53 144/111 210/144 252/182 268/193 268/194 - - - - - Trick Flow TW 190 TH SF600 Alum 190/66 2.02/1.60 4.03 1 7/8" Pipe N/A 71/57 145/115 214/150 57/187 268/194 273/197 - - - - - Trick Flow TW 195 Weingartner Racing Back Cut I Alum 195/- 2.02/1.60 4.155 N/A 69/48 143/92 200/129 242/153 276/169 277/179 266/186 - - - - Trick Flow TW Ported Ford Performanve Solution Stage I Alum N/A - N/A - - - - - 295/220 - - - - - Trick Flow TW Ported Ford Performanve Solution Stage II Alum N/A - N/A - - - - - 305/225 - - - - - Trick Flow TW Ported Ford Performanve Solution Stage III Alum N/A - N/A - - - - - 315/235 - - - - - Trick Flow TW Ported Fox Lake Stage 1 Alum 175/- 2.02/1.60 62 - - - - - 281/210 - - - - - Trick Flow TW Ported Fox Lake Stage 2 Alum 185/- 2.02/1.60 65 - - - - - 300/220 - - - - - Trick Flow TW Ported Fox Lake Stage 3 Alum 195/- 2.02/1.60 65 - - - - - 310/220 - - - - - Trick Flow TW Ported Fox Lake Stage 4 Alum 207/- 2.055/1.60 65 - - - - - 320/230 - - - - - Trick Flow TW Ported ET Performance Alum 215/- 2.08/1.60 4.03 68 64/57 137/103 203/143 261/178 291/203 310/214 316/221 - - - - Trick Flow TW Ported Bennett Stage 2 Alum N/A - N/A - - - - - - 300/215 - - - - Manufacturer Part Number Port/Vol Int/Exh Valve Size Int/Exh Combust. Chamber Vol .100 .200 .300 .400 .500 .600 .700 .800 .900 1.000 Average Trick Flow TW Ported Bennett Stage 3 Alum N/A - N/A - - - - - - 320/230 - - - - Trick Flow TW Ported TEA Alum 185/- 2.02/1.60 N/A 72/58 142/114 215/152 259/189 287/220 300/234 - - - - - Trick Flow TW Ported TEA 190 Alum 190/66 2.02/1.60 4.03 1 3/4 Pipe 56 71/60 139/111 205/150 257/185 292/212 311/227 - - - - - Trick Flow TW Ported TEA Alum 205/- 2.02/1.60 N/A 71/58 143/114 221/152 271/189 301/220 315/234 - - - - - Trick Flow TW Ported TEA Eric Alum 205/- 2.02/1.60 N/A 71/52 145/105 219/146 273/180 305/209 315/228 - - - - - Trick Flow TW Ported TEA Renegade Alum 205/- 2.04/1.60 N/A 57/53 149/111 228/155 283/203 314/228 325/240 - - - - - Trick Flow TW R SF600 Alum 206/92 2.08/1.60 61 - - - - - - 305/235 - - - - Trick Flow TW R CNC SF600 Alum 225/100 2.08/1.60 4.03 2" Pipe 65 67/59 141/116 213/159 270/205 308/244 331/259 341/271 - - - - Trick Flow TW R Ported Ford Performanve Solution Stage I Alum N/A - N/A - - - - - - 330/250 - - - - Trick Flow TW R Ported Ford Performanve Solution Stage II Alum N/A - N/A - - - - - - 345/260 - - - - Trick Flow TW R Ported Ford Performanve Solution Stage III Alum N/A - N/A - - - - - - 360/270 - - - - Trick Flow TW R Ported Fox Lake Stage 1 Alum 208/- 2.08/1.60 62 - - - - - - 325/245 - - - - Manufacturer Part Number Port/Vol Int/Exh Valve Size Int/Exh Combust. Chamber Vol .100 .200 .300 .400 .500 .600 .700 .800 .900 1.000 Average Trick Flow TW R Ported Fox Lake Stage 2 Alum 216/- 2.08/1.60 64 - - - - - - 335/260 - - - - Trick Flow TW R Ported Fox Lake Stage 3 Alum 233/107 2.125/1.625 61 - - - - - - 358/268 - - - - Trick Flow TW R Ported Fox Lake Stage 3 Old Alum 240/- 2.15/1.625 68 - - - - - - 362/273 - - - - Trick Flow TW R Ported Bennett Stage 1 Alum N/A - N/A - - - - - - 325/240 - - - - Trick Flow TW R Ported Bennett Stage 2 Alum N/A - N/A - - - - - - 340/270 - - - - Trick Flow TW R Ported Bennett Stage 3 Alum N/A - N/A - - - - - - 360/275 - - - - Trick Flow TW R Ported TEA 225 Alum 225/80 2.08/1.60 N/A 67/59 141/121 215/161 271/204 306/243 332/258 345/270 - - - - Trick Flow TW R Ported TEA 235 Alum 235/80 2.125/1.60 N/A 70/54 143/106 215/155 271/208 310/250 339/259 358/270 - - - - Trick Flow TW R Ported TEA 235 Outlaw Alum 235/80 2.125/1.60 N/A 67/59 143/121 220/164 277/209 316/246 344/259 370/280 - - - - Trick Flow TW R Ported TEA 245 Alum 245/100 2.125/1.60 4.125 N/A 82/64 153/115 213/163 267/214 315/255 346/281 370/300 385/305 - - - Trick Flow R Ported Alum 215/- 2.08/1.60 N/A 61/56 130/103 197/141 257/178 300/211 330/230 347/238 - - - - Trick Flow 524002xx - R Series SF600 Alum 206/92 2.08/1.60 61 68/50 147/102 205/146 242/178 275/200 296/212 305/222 - - - - Manufacturer Part Number Port/Vol Int/Exh Valve Size Int/Exh Combust. Chamber Vol .100 .200 .300 .400 .500 .600 .700 .800 .900 1.000 Average Trick Flow 52400001/2 - R Series Blend & Polish N/A - 61 66/55 146/111 208/157 254/200 287/225 307/244 325/254 - - - - World Windsor Sr SF600 Iron N/A 2.02/1.60 - No Pipe N/A 66/59 129/106 184/148 226/174 257/181 264/183 268/185 248/186 - - - Windsor Sr 197/- 2.02/1.60 65 - - 162/121 196/137 218/149 225/160 - - - - - Windsor Sr N/A 2.05/1.60 65 - - 162/121 196/137 218/149 - 315/- - - - - Windsor Sr Ported Iron N/A 2.08/1.60 64 79/63 149/121 205/160 257/190 293/207 310/216 - - - - - World Windsor Jr SF600 Iron N/A 1.94/1.60 - No Pipe N/A 76/53 127/83 167/117 203/141 231/157 246/168 248/175 248/178 - - - World Windsor Jr 171/- 1.94/1.60 58 - 116/84 159/96 189/120 204/126 216/129 222/132 - - - - World Windsor Jr Iron 180/84 1.94/1.60 58 - 120/81 165/108 195/123 214/130 226/134 234/135 - - - - World Windsor Jr Ported Bullet Cylinder Heads Iron 195/- 1.94/1.50 64 62/53 132/103 185/144 231/170 257/192 273/197 - - - - - World Roush 200 N/A 2.02/1.60 N/A - 129/117 187/139 232/145 257/140 260/152 264/154 - - - - World Roush 200 Andrew Iron N/A 2.02/1.60 64 61/54 121/108 175/128 219/138 241/145 248/148 - - - - - World Roush 200 Exhaust Bowl and Chamber Blended Andrew Iron N/A 2.02/1.60 65 61/52 121/107 175/156 219/175 241/183 248/188 - - - - - Manufacturer Part Number Port/Vol Int/Exh Valve Size Int/Exh Combust. Chamber Vol .100 .200 .300 .400 .500 .600 .700 .800 .900 1.000 Average World Roush 200 Ported Bullet Cylinder Heads Iron 217/83 2.05/1.60 68 70/58 142/105 201/163 259/198 273/209 300/211 308/210 - - - - World 180p.v. Ported Bullet Cylinder Heads Iron 202/79 2.05/1.60 70 70/54 135/107 193/139 250/172 272/198 293/209 294/211 - - - - World / Kuntz 18 Deg 200 Manowar SF600 Alum 200/- 2.02/1.60 - No Pipe N/A 67/54 129/107 185/141 227/168 258/184 283/193 299/198 306/200 - - - World / Kuntz 18 Deg CNC 228 SF600 Alum 228/73 2.08/1.60 - No Pipe 72 68/59 135/107 195/144 238/178 268/201 296/217 308/225 318/228 - - - World / Kuntz 18 Deg 225 Manowar SF600 Alum 225/- 2.08/1.60 - No Pipe 72 62/51 118/101 174/141 219/169 253/186 282/193 299/198 313/200 - - - World / Kuntz 18 Deg CNC 242 Manowar SF600 Alum 242/75 2.10/1.60 - No Pipe 72 64/61 124/109 182/149 231/179 266/193 298/199 319/203 326/205 - - - World / Kuntz 18 Deg Alum 230/- 2.12/1.60 N/A - - - - - - - 340/230 - - - World / Kuntz 10 Deg 275 Manowar SF600 Alum 275/102 2.20/1.60 - No Pipe 64 73/63 148/122 220/166 283/204 327/222 352/237 365/243 347/246 - - - World / Kuntz 10 Deg 285 Manowar SF600 Alum 285/102 2.20/1.60 - No Pipe 72 65/52 117/97 182/138 249/173 308/202 348/231 372/244 352/251 - - - World / Kuntz 10 Deg CNC 310 Manowar SF600 Alum 310/106 2.20/1.60 - No Pipe 72 65/53 140/106 212/144 274/173 326/195 363/218 381/233 391/240 - - - Ford_Big_Block COPYRIGHT © 2000-2018 Stan Weiss — World Wide Enterprises FE COPYRIGHT © 2000-2018 Stan Weiss — World Wide Enterprises Manufact. Part Number Port/Vol Int/Exh Valve Size Int/Exh Comb. Cham. Vol .100 .200 .300 .400 .450 .500 .550 .600 .700 .800 .900 1.000 Average Ford C1AE Bill Ballinger Iron 144/104 2.03/1.56 N/A 66/52 133/98 193/125 220/138 - 230/144 - 237/146 241/147 - - - - Ford C1AE Bowl Ported Scott Vincent Iron N/A 2.09/1.65 N/A 74/49 149/91 202/124 241/162 - 249/198 - 259/205 263/212 - - - - Ford C1AE Bowl + Blend Ported Scott Vincent Iron N/A 2.09/1.65 N/A 66/49 141/91 218/124 256/162 - 269/198 - 282/205 286/212 - - - - Ford C4AE 6090G Iron 150/108 2.03/1.56 N/A - 130/111 180/135 220/155 - 236/165 - 246/165 - - - - - Ford C4AE 6090G Ported Les Schmader Iron N/A 2.09/1.653 - 2" Pipe 74 70/55 156/109 222/151 257/180 - 272/195 - 281/197 291/200 - - - - Ford C4AE-G Ported Scott Vincent Iron 170/125 2.09/1.66 - 2" Pipe N/A 80/56 149/104 207/149 250/186 - 250/197 - 253/200 260/199 - - - - Ford C6FE-A Flowtech - Steven Magnotti 3 Angle VJ SF110 Alum N/A 1.94/1.60 4.00 No Pipe N/A 65/43 118/91 153/120 181/142 190/152 194/- 200/- 206/- - - - - - Ford C6FE-A Flowtech - Steven Magnotti Mild Intake Port Ported Exhaust and Chamber Work SF110 Alum N/A 1.94/1.60 4.00 No Pipe N/A 67/45 121/96 161/139 195/161 208/164 225/166 233/166 235/- 245/- - - - - Ford C8AE-H Iron N/A 2.03/1.56 68-71 - 115/88 168/122 198/133 - 202/139 - - - - - - - Ford C8AE-H Low Riser Flowtech - Steven Magnotti SF110 Iron N/A 2.055/1.558 - No Pipe N/A 56/43 109/84 167/123 196/136 200/140 204/143 208/149 211/152 215/- - - - - Ford C8AE-H Low Raiser Flowtech - Steven Magnotti Ported Exhaust Valve Back Cut 30 SF110 Iron N/A 2.055/1.558 - No Pipe N/A 62/46 130/95 190/141 233/154 253/157 260/162 263/166 266/174 -/182 - - - - Ford 428 C0AE Med Riser Flowtech - Steven Magnotti SF110 Iron N/A 2.09/1.65 - No Pipe N/A 61/44 111/86 156/132 196/158 206/175 211/178 215/202 218/204 - - - - - Manufact. Part Number Port/Vol Int/Exh Valve Size Int/Exh Comb. Cham. Vol .100 .200 .300 .400 .450 .500 .550 .600 .700 .800 .900 1.000 Average Ford 427 Med Riser Iron N/A 2.19/1.73 67 - - - - - 240/- - 250/- - - - - - Ford 427 Med Riser Ported Keith Craft Iron N/A - 67 - - - - - - - 300/- - - - - - Ford 427 Med? Riser Iron N/A - 67 - - - - - - - 296/177 - - - - - Ford 427 Hi? Riser Iron N/A 2.18/1.72 67 - - - - - - - 284/177 - - - - - Ford 427 Hi Riser John Iron N/A 2.19/- N/A 83/- 140/- 193/- 239/- - 267/- - 268/- 275/- 278/- - - - Ford 427 Hi Riser C4AE 6090F Iron 193/125 2.19/1.73 67 - - - - - - - - - - - - - Ford 427 Hi Riser Ported Iron - - N/A - - - - - - - - 370/- -/290 - - - Ford 427 Tunnel Port Monty Iron N/A 2.19/1.73 N/A 97/53 173/105 237/154 273/180 - 296/190 - 285/194 283/194 291/196 - - - Ford 427 Tunnel Port Jim Milled Smoothed Exhaust Bowl Iron N/A 2.19/1.75 67 84/50 156/105 202/158 242/191 267/205 287/213 301/216 298/217 289/217 - - - - Ford 427 Tunnel Port N/A 2.25/1.73 88-90 - - - - - - - 308/166 - - - - - Ford 427 Tunnel Port John N/A 2.25/- N/A 81/- 155/- 212/- 255/- - 288/- - 305/- 315/- 322/- - - - Ford 427 Tunnel Port C7OE N/A 2.25/1.73 N/A - 161/101 216/141 251/173 - 269/182 - 294/184 307/186 314/186 - - - Manufact. Part Number Port/Vol Int/Exh Valve Size Int/Exh Comb. Cham. Vol .100 .200 .300 .400 .450 .500 .550 .600 .700 .800 .900 1.000 Average Ford 427 Tunnel Port Mild Port Jim Iron N/A 2.25/1.75 - No Pipe N/A - 177/115 240/153 279/179 - 306/190 - 326/197 342/201 - - - - Ford 427 Tunnel Port Ported Iron N/A 2.25/1.75 - No Pipe N/A - - - - - - - 383/256 - - - - - Ford 427 SOHC HRM Iron N/A 2.25/1.90 N/A 86/60 170/129 244/186 281/220 - 302/246 - 324/260 336/264 340/266 - - - Ford 427 SOHC Iron N/A 2.25/1.90 N/A - - - - - - - 355/248 - - - - - Ford 427 SOHC Ported N/A 2.30/1.90 N/A - 185/130 262/190 340/224 - 389/253 - 403/273 405/286 -/295 - - - Ford 427 SOHC Ported R&R HRM Tulip Intake 30 Deg Seat Alum N/A 2.30/1.90 N/A 92/58 173/130 226/190 283/224 - 332/253 - 364/273 380/286 394/295 - - - Ford 427 SOHC Ported R&R HRM Nailhead Intake 45 Deg Seat Alum N/A 2.30/1.90 N/A 87/58 175/130 270/190 337/224 - 375/253 - 400/273 400/286 401/295 - - - Ford 428 CJ Iron 152/122 2.09/1.66 4.18 N/A 76/46 150/85 202/118 228/145 - 236/163 - 243/174 244/181 - - - - Ford 428 CJ Iron 152/122 2.09/1.66 4.18 N/A - - - - - - - 243/181 - - - - - Ford 428 CJ C80E-N Bill Ballinger Iron N/A 2.09/1.66 N/A 61/51 135/91 204/121 230/149 - - - 248/175 252/179 - - - - Ford 428 CJ NHRA Keith Craft Iron 155/123 2.09/1.66- N/A - - - - - 275/210 - - - - - - - Ford 428 CJ Ported Keith Craft Iron N/A 2.15/1.66 N/A - - 224/151 271/186 - 292/204 - 300/224 302/228 - - - - Manufact. Part Number Port/Vol Int/Exh Valve Size Int/Exh Comb. Cham. Vol .100 .200 .300 .400 .450 .500 .550 .600 .700 .800 .900 1.000 Average Ford 428 CJ Canadian Iron 170/123 - N/A - - - - - - - - - - - - - Blue Thunder M/R Ported Keith Craft Alum N/A - N/A - - - - - - - - 350/260 - - - - Blue Thunder M/R Ported ET Performance Alum N/A 2.25/1.65 4.350 87 76/63 156/119 215/161 276/191 - 318/215 - 341/229 358/237 - - - - Blue Thunder H/R Ported Keith Craft Alum N/A - N/A - - - - - - - - - - 405/280 - - Blue Thunder H/R Ported Alum N/A 2.30/1.75 4.350 Pipe 65 - - - - - - - - - 385/280 - - - Blue Thunder Ported Shanons Engineering Alum N/A - N/A - - - - - - - - 350/- - - - - Coon 427 SOHC Ported R&R HRM Nailhead Intake 45 Deg Seat Alum N/A 2.30/1.90 N/A 81/58 179/133 263/202 340/248 - 402/280 - 422/295 429/298 415/300 - - - Dove 427 Tunnel Port Alum N/A 2.25/1.73 N/A - - - - - - - - 370/230 - - - - Dove 428 CJ Canadian Alum N/A 2.09/1.65 58/72 - - - - - - - - 320/210 - - - - Dove 428 Hi Velocity Alum N/A 2.09/1.65 58/72 - - - 290/- - 290/- - - - - - - - Edelbrock 6006 Alum 170/125 2.09/1.66 N/A - 149/112 185/148 222/171 - 252/183 - - - - - - - Edelbrock 6006 Alum 170/125 2.09/1.66 N/A 77/51 140/100 183/138 214/157 - 238/174 - 248/185 256/185 - - - - Manufact. Part Number Port/Vol Int/Exh Valve Size Int/Exh Comb. Cham. Vol .100 .200 .300 .400 .450 .500 .550 .600 .700 .800 .900 1.000 Average Edelbrock Performer RPM 390-428 CJ 60069, 61699 SF1020 Alum 170/125 2.09/1.66 72/76 88/64 153/113 195/148 233/171 - 265/183 - 270/200 - - - - - Edelbrock Performer RPM 390-428 CJ 60059 Joe Sherman Alum N/A 2.09/1.66 N/A 75/55 146/108 182/138 217/159 - 243/168 - 258/191 266/197 - - - - Edelbrock Performer RPM 390-428 CJ 60059 Mild Port Joe Sherman Alum N/A 2.15/1.66 77 75/60 142/120 201/158 251/177 - 280/188 - 293/206 302/217 - - - - Edelbrock Performer RPM 390-428 CJ 60059 John Alum N/A 2.09/- N/A 68/- 125/- 172/- 218/- - 237/- - 250/- 260/- 262/- - - - Edelbrock Performer RPM 390-428 CJ 60059 Ported John Alum N/A 2.25/- N/A 75/- 147/- 208/- 261/- - 285/- - 310/- 320/- 339/- - - - Edelbrock Chad Speier Out of Box SF600 Alum N/A 2.09/- 4.155 N/A - 144/- 183/- 216/- - 240/- - 249/- 253/- 257/- - - - Edelbrock Chad Speier Ported SF600 Alum N/A 2.09/- 4.155 N/A - 152/- 217/- 262/- - 284/- - 297/- 298/- 300/- - - - Edelbrock 390 Stock BH Performance Alum N/A 2.09/1.66 - No Pipe N/A 70/- 137/- 179/- 224/- - 248/- - 247/- 253/- - - - - Edelbrock 390 Bowl Port BH Performance Alum N/A 2.09/1.66 - No Pipe N/A 69/64 137/111 194/142 247/166 - 284/193 - 298/203 291/208 - - - - Edelbrock Performer RPM FE NPS Alum N/A 2.09/1.66 4.252 No Pipe N/A 75/52 138/98 177/132 220/160 - 244/180 - 248/191 257/194 - - - - Edelbrock Performer RPM FE 60079 Alum 170/125 2.09/1.66 76 88/64 153/113 195/148 233/171 - 265/183 - 270/200 - - - - - Edelbrock Street/Strip Port CCM Alum N/A 2.19/1.71 72 76/61 141/118 200/168 248/202 - 285/221 - 299/236 304/244 - - - - Manufact. Part Number Port/Vol Int/Exh Valve Size Int/Exh Comb. Cham. Vol .100 .200 .300 .400 .450 .500 .550 .600 .700 .800 .900 1.000 Average Edelbrock Ported Alum N/A 2.09/1.66 4.18 N/A 78/62 153/120 228/154 271/190 - 294/212 - 305/230 317/244 330/250 - - - Edelbrock Ported Alum N/A 2.25/1.78 N/A - - - - - - - 340/275 - - - - - Edelbrock Stage II Ported Keith Craft Alum N/A 2.09/1.66 N/A - - - - - - - - - 330/250 - - - Edelbrock Stage II Ported Keith Craft Alum 165/130 2.15/1.66 - 2" Pipe N/A - - - - - - - 324/235 - - - - - Edelbrock Stage II Ported Keith Craft Alum 165/130 2.19/1.75 4.165 2" Pipe N/A - - - - - - - 324/235 - - - - - Edelbrock Stage III Ported Keith Craft Alum 185/140 2.25/1.75 N/A - - - 270/- - 318/- - 338/- 355/- 375/280 - - - Edelbrock Stage III Ported Keith Craft Alum 185/140 2.25/1.75 N/A - - - - - - - - - 370/270 380/280 - - Edelbrock Performer FE Ported ET Performance Alum N/A 2.19/1.65 4.18 N/A 73/63 148/119 211/158 269/185 - 305/202 - 309/217 319/228 - - - - Edelbrock Ported Kuntz Alum N/A 2.15/1.625 N/A - - 235/159 284/192 - 319/221 - 335/243 355/254 356/259 359/262 - - Edelbrock Ported Kuntz Alum N/A 2.25/1.75 N/A - - 232/172 281/203 - 313/228 - 333/250 353/261 362/262 - - - Edelbrock Ported Kuntz Alum N/A 2.30/1.70 - No Pipe 79 - - - - - - - - - - - 400/275 - Edelbrock Ported Fox Lake SF600 Alum N/A - 4.125 N/A 79/72 159/107 220/136 272/183 - 323/209 - 334/231 348/253 - - - - Manufact. Part Number Port/Vol Int/Exh Valve Size Int/Exh Comb. Cham. Vol .100 .200 .300 .400 .450 .500 .550 .600 .700 .800 .900 1.000 Average Shelby 427 Alum N/A 2.25/1.75 N/A - - - 241/156 - 264/175 - 275/180 279/- - - - - Shelby 427 Alum Stage II Porting N/A 2.25/1.75 N/A - - - 265/185 - 294/200 - 309/209 314/214 - - - - Shelby 427 Alum 163/128 2.25/1.75 82 - - - - - - - 280/185 - - - - - Shelby 427 Alum Stage II Porting N/A - 82 - - - - - - - 320/235 - - - - - TFS Brent Lykins SF600 Alum 169.8/- 2.19/1.625 4.155 No Pipe 69.8 96/66 159/120 233/164 283/197 - 317/215 - 333/220 333/- - - - - Ultra Pro Machining Billet Canted Valve I-50 E-50 Alum N/A 2.30/1.75 N/A 77/53 165/103 250/145 328/184 - 381/222 - 413/264 436/281 455/291 465/299 471/302 - 385 Series COPYRIGHT © 2000-2018 Stan Weiss — World Wide Enterprises Manufact. Part Number Port/Vol Int/Exh Valve Size Int/Exh Comb. Cham. Vol .100 .200 .300 .400 .500 .600 .700 .800 .900 1.000 1.100 Average Ford 429 Iron N/A 2.08/1.656 N/A - - - 184/119 217/129 239/130 260/- - - - - - Ford 429 Iron N/A - N/A - - - 229/174 254/177 272/177 - - - - - - Ford E7TE Scott Johnston Iron N/A 2.08/1.656 N/A 58/42 117/88 174/117 196/131 224/137 239/141 247/142 - - - - - Ford E7TE Ported Scott Johnston Iron N/A 2.08/1.656 N/A 74/54 147/103 211/137 263/169 289/191 303/206 312/219 - - - - - Ford 429 CJ Iron N/A 2.24/1.72 N/A - - - - 300/189 331/201 - - - - - - Ford D0OE-R CJ Scott Johnston Iron N/A 2.24/1.72 N/A 67/50 133/94 186/122 235/140 275/151 302/158 322/159 - - - - - Ford D0OE-R CJ Bret Iron N/A 2.25/1.75 N/A 72/55 137/109 200/134 266/149 289/157 317/161 337/163 350/- - - - - Ford D0OE-R CJ Ported Mike R Iron N/A 2.24/1.72 N/A 81/57 156/112 227/151 277/175 310/192 343/203 362/209 375/211 - - - - Ford D0OE-R CJ Ported Charlie Evans Iron N/A 2.24/1.72 - No Pipe N/A 71/59 138/102 206/129 265/156 310/175 342/184 364/188 375/211 - - - - Ford SCJ Ported Stuska1 Iron N/A - 4.40 N/A 76/- 143/- 213/- 261/- 302/- 340/- 367/- 383/- - - - - Ford A429 N/A - N/A - 152/115 216/149 253/177 280/190 290/197 290/199 - - - - - Ford A429 Charlie Evans N/A - N/A 69/60 136/104 205/148 261/172 283/180 292/183 298/184 - - - - - Manufact. Part Number Port/Vol Int/Exh Valve Size Int/Exh Comb. Cham. Vol .100 .200 .300 .400 .500 .600 .700 .800 .900 1.000 1.100 Average Ford A429 Charlie Evans N/A 2.245/1.76 N/A 72/57 154/121 230/148 298/172 332/213 345/225 357/230 - - - - - Ford A429 CJ Ported Jon Kaase N/A - N/A - - - - - - - 420/295 - - - - Ford 429 DOVE Iron N/A 2.08/1.65 - 2 1/8" Pipe N/A 68/56 138/105 207/128 246/141 268/144 281/146 - - - - - - Ford 429 DOVE Ported Iron N/A 2.19/1.735 - 2 1/8" Pipe N/A 70/59 146/119 217/149 269/167 299/174 308/180 310/- - - - - - Ford DOVE Ported chd600 SF600 Iron N/A 2.19/1.80 - No Pipe N/A 68/57 147/110 216/151 273/174 297/188 304/192 - - - - - - Ford 429 DOVE-C CCM Iron N/A 2.06/1.76 75 65/47 119/88 178/115 216/124 248/126 270/126 286/- - - - - - Ford 429 DOVE-C Iron N/A 2.06/1.76 N/A - 122/87 178/115 226/130 250/140 264/143 274/144 - - - - - Ford 429 DOVE-C Ported Scott Johnston Iron N/A 2.19/1.745 - No Pipe N/A 86/60 144/107 204/140 270/168 306/195 325/212 342/222 360/230 - - - - Ford 429 DOVE-C Ported Charlie Evans Iron N/A 2.20/- 4.35 N/A 70/- 150/- 223/- 280/- 306/- 317/- 327/- - - - - - Ford 429 '73 D2VE-AA FORD Muscle Iron N/A 2.09/1.66 4.50 N/A 81/69 144/112 202/140 240/150 271/154 290/156 - - - - - - Ford D2VE Ported Blake Iron N/A 2.25/- N/A 76/- 164/- 227/- 273/- 298/- 307/- 312/- 318/- - - - - Ford 460 Jim Grubbs CCM Iron N/A 2.08/1.65 - No Pipe N/A 66/47 125/89 185/117 225/127 253/129 271/129 - - - - - - Manufact. Part Number Port/Vol Int/Exh Valve Size Int/Exh Comb. Cham. Vol .100 .200 .300 .400 .500 .600 .700 .800 .900 1.000 1.100 Average Ford 460 DOVE-A2A Dr Js Performance Iron N/A - N/A 69/48 132/97 203/123 240/129 266/129 275/129 282/129 - - - - - Ford 460 DOVE-A2A Ported Dr Js Performance Iron N/A - N/A 71/50 136/97 206/126 251/148 288/165 317/179 331/190 - - - - - Ford D20E PI Ported Brian Eyler 45 Deg / Back Cut Intake Tulip Exhaust SF600 Iron 310/- 2.25/1.76 - No Pipe N/A 84/65 176/100 246/142 298/174 314/182 329/194 339/199 348/199 - - - - Ford 460 D3VE-C Scott Johnston Iron N/A 2.08/1.65 N/A 62/47 119/87 189/119 236/125 263/129 270/129 - - - - - - Ford 460 D3VE-C Ported Stage 2 Scott Johnston Iron N/A 2.19/1.76 N/A 95/60 163/107 223/140 268/168 301/195 325/202 342/202 355/202 - - - - Ford 460 D3VE-C Iron 244/89 2.08/1.65 N/A - - - - - 270/128 - - - - - - Ford 460 D3VE-C Ported Iron N/A 2.19/1.76 N/A - - 218/148 266/185 291/193 314/205 323/207 - - - - - Ford 460 D3VE Ported Anderson Port Development Iron N/A 2.25/- 4.375 N/A 80/- 150/- 219/- 264/- 316/- 351/- 370/- 384/- 390/- - - - Ford F3TE Ported Scott Johnston Iron N/A 2.19/1.76 N/A 87/82 163/116 227/150 275/175 305/199 316/215 326/222 - - - - - Ford 429 New SCJ Alum 290/148 2.20/1.76 72 - - - - - - - 330/225 - - - - Ford 429 New SCJ Alum 290/148 2.20/1.76 72 - 154/103 202/139 248/185 274/200 298/208 309/212 318/214 - - - - Ford 429 New SCJ CCM Alum N/A 2.20/1.76 72 73/60 155/106 222/141 275/177 314/191 317/203 316/211 321/213 - - - - Manufact. Part Number Port/Vol Int/Exh Valve Size Int/Exh Comb. Cham. Vol .100 .200 .300 .400 .500 .600 .700 .800 .900 1.000 1.100 Average Ford 429 New SCJ Hand Blending Alum N/A 2.20/1.76 - No Pipe 72 81/72 155/104 250/146 313/175 359/195 345/206 340/213 331/217 - - - - Ford 429 New SCJ Ported Scott Johnston Alum 315/- 2.20/1.76 - No Pipe N/A 95/59 166/104 256/153 330/182 356/200 370/213 380/238 370/250 - - - - Ford SCJ Ported Smithberg Racing Alum N/A 2.20/1.76 4.31 No Pipe N/A 77/63 187/114 274/156 333/190 377/205 399/219 403/229 411/240 - - - - Ford 460 CJ SVO N/A 2.25/1.75 N/A - - - 240/165 274/176 292/181 - - - - - - Ford 460 CJ Kendrick Auto Alum N/A 2.25/1.76 N/A - 144/116 199/159 254/166 291/189 308/194 322/195 - - - - - Ford 460 CJ Ported Kendrick Auto Alum N/A 2.25/1.76 N/A - 143/123 202/176 264/202 317/230 348/253 371/256 - - - - - Ford A460 Ported TEA 350/180 2.35/1.88 94 80/63 160/131 244/179 314/227 380/271 415/311 435/339 457/361 - - - - Ford A460 Ported dfree383 N/A 2.40/1.90 4.625 No Pipe 78 76/59 152/120 235/158 310/197 368/235 413/267 437/292 445/314 - - - - Ford A460 Ported Charlie Evans N/A 2.30/1.88 - No Pipe N/A 73/62 157/118 237/164 303/212 362/252 399/283 410/301 421/310 - - - - Ford A460 Ported Charlie Evans N/A 2.35/1.88 - No Pipe N/A 75/57 158/110 233/156 297/204 356/244 400/277 430/300 423/311 - - - - Ford A460 Ported Charlie Evans N/A 2.40/1.90 - No Pipe N/A 71/57 152/111 239/158 309/206 362/256 405/285 437/300 458/306 - - - - Ford B-460 Charlie Evans N/A 2.38/1.88 - No Pipe N/A - 159/130 250/178 335/226 405/272 447/313 473/338 484/353 490/363 - - - Manufact. Part Number Port/Vol Int/Exh Valve Size Int/Exh Comb. Cham. Vol .100 .200 .300 .400 .500 .600 .700 .800 .900 1.000 1.100 Average Ford C-460 Charlie Evans N/A 2.45/1.90 4.625 No Pipe N/A - 159/111 227/150 285/183 327/201 351/214 367/221 380/225 - - - - Ford C-460 Bowl Blend Charlie Evans I-45 E-45 N/A 2.45/1.90 4.625 No Pipe N/A - 154/111 230/166 306/217 380/260 425/270 427/293 413/302 - - - - Ford C-460 SuperBowl Blend Charlie Evans Tulip Exh N/A 2.425/1.88 - No Pipe N/A - 166/129 254/200 319/260 386/292 445/317 456/333 447/345 - - - - Ford C-460 Ported Charlie Evans I-45 E-45 N/A 2.45/1.90 4.625 No Pipe N/A - 158/125 238/164 316/212 384/270 431/295 464/315 480/325 - - - - Ford C-460 CNC Charlie Evans N/A 2.45/1.90 4.625 No Pipe N/A - 160/130 245/170 327/210 400/280 450/315 478/340 500/355 - - - - Ford C-460 Bowl Blend - Short Turn N/A 2.40/1.80 N/A - - 246/161 323/194 384/230 423/290 451/310 469/318 - - - - Ford C-460 N/A - N/A - - - - - - 440/- - - - - - Ford C-460 Ported N/A 2.45/1.88 N/A - - - - 456/330 480/365 496/379 505/385 - - - - Ford C-460 Ported Jon Kaase N/A 2.45/1.88 4.60 N/A - - - - - - - 500/385 - - - - Ford C-460 Ported M2 Race Systems N/A 2.45/1.85 4.60 N/A 73/65 139/127 208/176 281/214 345/245 389/276 428/316 457/354 473/363 - - - Ford C-460 Ported MBE I-55 E-55 SF600 N/A 2.55/1.80 4.52 No Pipe 50-90 - 144/115 211/171 286/218 360/255 416/286 460/306 498/320 517/330 530/340 542/342 - Ford C-460 Ported TEA 385/- 2.45/1.90 4.625 N/A 83/63 160/125 257/175 334/260 394/294 442/320 471/339 484/350 490/357 - - - Manufact. Part Number Port/Vol Int/Exh Valve Size Int/Exh Comb. Cham. Vol .100 .200 .300 .400 .500 .600 .700 .800 .900 1.000 1.100 Average Ford C-460 Ported ET Performance N/A 2.45/1.88 4.60 N/A 90/58 158/120 256/168 330/252 393/272 436/311 468/322 481/340 485/348 - - - Ford C-460 Meaux Racing Ported C460/Larry N/A 2.40/1.90 4.50 No Pipe N/A - 154/126 227/177 305/217 369/246 414/265 431/284 450/294 - - - - Ford C-460 Meaux Racing Ported C460/Larry N/A 2.40/1.90 4.60 No Pipe N/A - 153/126 226/177 307/217 402/246 430/265 452/284 460/294 - - - - Ford E-460 Ported ET Performance N/A - 4.50 N/A 80/56 158/113 258/159 345/198 414/232 460/265 485/285 504/303 513/314 - - - Ford E-460 Ported Charlie Evans N/A 2.52/- 4.625 N/A - - 248/- 340/- 417/- 483/- 521/- 540/- 550/- 557/- - - Ford E-460 Ported Charlie Evans N/A 2.52/- 4.625 N/A - - 240/- 325/- 408/- 481/- 525/- 555/- 571/- 571/- - - Ford E-460 Meaux Racing Ported Glidden SF600 N/A 2.42/1.82 4.50 N/A - 137/- 210/- 278/- 345/275 400/312 439/329 457/- 476/- 482/- - - Ford Boss 429 Hemi N/A 2.40/1.90 N/A - - - - - 379/225 - - - - - - Ford Boss 429 Hemi Dr Js Performance N/A 2.40/1.94 - Pipe N/A 83/60 152/125 243/175 327/217 363/248 361/271 362/287 364/300 - - - - Ford Boss 429 Hemi Ported Dr Js Performance N/A 2.40/1.94 - Pipe N/A 81/61 175/140 277/186 360/231 415/269 439/300 444/316 445/327 - - - - Ford Hemi Charlie Evans I-30 E-45 N/A 2.282/1.90 N/A 87/56 154/110 201/158 252/190 297/212 330/226 348/237 351/246 - - - - Ford New SCJ Scott Johnston Out of Box Alum N/A 2.20/1.76 N/A 73/60 155/106 222/141 275/177 314/191 317/203 316/211 321/213 - - - - Manufact. Part Number Port/Vol Int/Exh Valve Size Int/Exh Comb. Cham. Vol .100 .200 .300 .400 .500 .600 .700 .800 .900 1.000 1.100 Average Ford New SCJ Charlie Evans Out of Box Alum N/A 2.20/1.76 - No Pipe N/A 73/57 167/102 250/144 318/175 340/186 328/196 328/202 - - - - - Ford New SCJ Bowl blend Charlie Evans Alum N/A 2.20/1.76 - No Pipe N/A 73/58 167/103 252/145 323/177 371/190 349/207 344/218 - - - - - Ford New SCJ Ported Charlie Evans Alum N/A 2.20/1.76 - No Pipe N/A 72/61 154/114 252/157 336/185 393/204 366/225 362/233 - - - - - Ford New SCJ Jon Kaase N/A 2.20/1.76 N/A 84/73 181/119 264/164 330/183 357/199 345/218 345/227 - - - - - Ford New SCJ Ported N/A 2.20/1.76 N/A - - - 330/182 380/200 390/217 - - - - - - Ford New SCJ Ported Active Racing SF600 N/A 2.25/1.76 N/A 89/79 173/134 247/171 308/198 337/225 323/242 - - - - - - Ford New SCJ Jon Kaase Stage 1 Ported N/A - N/A - - - - - - 352/249 - - - - - Ford New SCJ Jon Kaase Stage 2 Ported N/A - N/A - - - - - - - 419/266 - - - - Ford Pro Stock RCV (Canted Valve) Ported Darin Morgan SF600 Alum N/A 2.575/1.865 - No Pipe N/A - 175/103 273/154 369/200 457/243 530/286 583/327 614/344 637/351 644/360 - - Hemi 747jetmech Ported N/A 2.36/1.96 N/A 122/73 220/159 285/196 360/230 405/257 436/270 433/282 419/291 - - - - AFR 270 Alum 270/132 2.25/1.76 75/85 - 169/130 244/174 309/214 354/238 385/254 - - - - - - AFR 285 Alum 285/142 2.25/1.76 75/85 - 168/128 245/175 313/218 357/249 396/267 411/276 - - - - - Manufact. Part Number Port/Vol Int/Exh Valve Size Int/Exh Comb. Cham. Vol .100 .200 .300 .400 .500 .600 .700 .800 .900 1.000 1.100 Average AFR 300 Alum 300/142 2.30/1.76 75/85 - 162/126 241/172 309/218 360/252 405/274 423/284 - - - - - Avenger CJ Ported Alum 355/155 2.20/1.76 74/80 79/75 149/138 218/176 278/200 337/226 367/262 381/282 392/293 - - - - Bennett Ported C-460 N/A - N/A - - - - - - - 500/375 - - - - Blue Thunder "B" Chevy Exhaust VJ Charlie Evans SF600 Alum N/A 2.30/1.82 4.625 N/A 67/60 129/114 188/148 251/176 301/194 322/207 331/215 - - - - - Blue Thunder "B" Chevy Exhaust Bowl Work Charlie Evans SF600 Alum N/A 2.30/1.82 4.625 N/A 71/61 150/118 209/158 273/188 329/213 340/237 343/258 - - - - - Blue Thunder "B" Chevy Exhaust Ported Street/Strip Charlie Evans SF600 Alum N/A 2.30/1.82 4.625 N/A 72/67 148/122 213/163 277/191 331/215 351/241 356/265 - - - - - Blue Thunder "B" Chevy Exhaust Ported Race Charlie Evans SF600 Alum N/A 2.30/1.82 4.625 N/A 73/67 152/122 216/163 281/198 335/227 361/251 377/271 - - - - - Blue Thunder "B" Chevy Exhaust Ported Gerry Cooper Alum N/A - N/A - 163/129 229/171 294/210 343/256 373/285 391/307 410/312 - - - - Blue Thunder "B" Ford Exhaust Charlie Evans Alum N/A 2.30/1.82 4.625 N/A 67/65 129/107 188/144 251/172 301/189 322/194 331/194 - - - - - Blue Thunder "B" Ford Exhaust Bowl Work VJ Charlie Evans Alum N/A 2.30/1.82 4.625 N/A 71/63 150/112 209/145 273/174 329/200 340/225 343/244 - - - - - Blue Thunder CJ 460 CNC Chamber Alum N/A 2.25/1.88 86 78/62 167/114 219/147 280/175 322/195 335/211 354/225 364/242 - - - - Blue Thunder CJ 460 Bowl and Port Alum N/A 2.25/1.88 N/A 77/- 155/- 223/- 285/- 340/- 363/- 380/- 389/- 397/- - - - Manufact. Part Number Port/Vol Int/Exh Valve Size Int/Exh Comb. Cham. Vol .100 .200 .300 .400 .500 .600 .700 .800 .900 1.000 1.100 Average Blue Thunder Ported Flatlanders Stage 3 Ford Exhaust Alum N/A 2.25/1.88 65 - - - - - - 365/234 - - - - - Blue Thunder Ported Flatlanders Stage 3 Chevy Exhaust Alum N/A 2.25/1.88 65 - - - - - - 365/245 - - - - - Blue Thunder Ported Flatlanders Comp Ford Exhaust Alum N/A 2.25/1.88 65 - - - - - - 412/295 - - - - - Blue Thunder Ported Ford Exhaust Alum N/A 2.25/1.88 4.50 N/A 75/63 142/113 210/151 275/184 307/214 341/239 367/256 380/270 - - - - Blue Thunder Ported Coast High Performance Comp Ford Exhaust Alum N/A 2.25/1.88 74 - - - - - - 405/295 - - - - - Blue Thunder Ported Flatlanders Comp Chevy Exhaust Alum N/A 2.25/1.88 65 - - - - - - 412/322 - - - - - Blue Thunder THOR Ported ET Performanc Alum 408/- 2.425/1.84 4.50 74 86/52 162/118 243/180 319/227 393/275 460/320 482/347 500/357 498/360 498/368 - - Blue Thunder THOR Ported ET Performanc Alum 440/- 2.475/1.84 4.60 82 74/52 168/118 245/180 320/227 400/275 452/320 493/347 513/357 525/360 534/368 - - Blue Thunder THOR Ported ET Performanc Alum 470/- 2.52/1.82 4.60 85 74/54 168/125 251/174 330/225 406/267 472/305 521/346 555/367 577/395 583/402 - - Blue Thunder THOR Ported Keith Craft Alum N/A - N/A - - - - - - - - - 580/400 - - Blue Thunder THOR Gen 2 Ported Charlie Evans Alum N/A - - No Pipe N/A - 161/125 240/176 321/233 399/300 460/335 495/352 519/361 530/368 540/372 - - Blue Thunder THOR Gen II Ported Meaux Racing SF600 Alum N/A 2.48/1.85 - No Pipe N/A - 136/122 220/176 317/222 385/264 451/307 497/327 522/341 540/350 546/355 - - Manufact. Part Number Port/Vol Int/Exh Valve Size Int/Exh Comb. Cham. Vol .100 .200 .300 .400 .500 .600 .700 .800 .900 1.000 1.100 Average Edelbrock Performer RPM Ported ET Performance Alum N/A 2.19/1.76 4.390 N/A 74/61 157/126 227/163 292/195 339/215 370/230 383/247 395/253 - - - - Edelbrock Performer RPM 460 60669 FORD Muscle Alum 292/100 2.19/1.76 4.50 95/75 75/68 141/116 208/154 260/181 297/200 309/212 - - - - - - Edelbrock Performer RPM 460 Charlie Evans Out of Box Alum N/A 2.19/1.75 - No Pipe N/A 66/58 135/106 202/144 253/171 296/187 316/200 327/205 - - - - - Edelbrock Performer RPM 460 Ported Charlie Evans Alum N/A 2.19/1.75 - No Pipe N/A 67/57 138/114 204/158 260/189 309/216 334/230 347/241 - - - - - Edelbrock Performer RPM 460 60669, 60679 SF1020 Alum 292/100 2.19/1.76 95/75 76/67 140/118 207/153 260/180 300/200 319/207 326/207 - - - - - Edelbrock Performer RPM 6066, 6067 Ported Alum N/A - N/A - 160/125 230/164 289/201 330/221 360/242 379/251 392/262 - - - - Edelbrock Performer RPM 460 61649,61659 Victor Jr. 460 CJ 61669 Alum 310/100 2.19/1.76 75 76/67 140/118 207/153 260/180 300/200 319/207 326/207 - - - - - Edelbrock Performer RPM 460 CJ 61649, 61659 SF1020 Alum 310/100 2.19/1.76 75 76/67 140/118 207/153 260/180 300/200 319/207 326/207 - - - - - Edelbrock Performer RPM 460 CJ 61649, 61659 Jim Grubbs CCM Alum N/A 2.19/1.76 - Pipe N/A 68/61 136/109 201/148 253/174 300/191 305/202 - - - - - - Edelbrock Performer RPM 460 CJ Out of Box Scott Johnston Alum N/A 2.19/1.76 N/A 82/64 156/110 225/155 279/182 323/200 341/214 347/212 350/212 - - - - Edelbrock Performer RPM 460 CJ Ported Scott Johnston Alum N/A 2.19/1.76 N/A 79/64 153/114 225/161 278/192 324/215 353/240 365/248 380/250 - - - - Edelbrock Performer RPM Ported Keith Craft Alum N/A 2.245/1.745 75/95 - - - - - - - 390/260 - - - - Manufact. Part Number Port/Vol Int/Exh Valve Size Int/Exh Comb. Cham. Vol .100 .200 .300 .400 .500 .600 .700 .800 .900 1.000 1.100 Average Edelbrock Ported Alum N/A 2.25/1.76 N/A - 160/125 230/164 289/201 330/221 360/242 379/251 392/262 - - - - Edelbrock Ported Nick Alum N/A 2.19/1.76 - No Pipe N/A - 151/112 225/150 277/179 315/200 347/215 364/223 380/228 - - - - Edelbrock Victor Jr 460 CJ 61669 SF1020 Alum 310/100 2.19/1.76 75 76/67 140/118 207/153 260/180 300/200 319/207 326/207 - - - - - Eliminator Alum N/A - N/A 65/63 134/135 203/188 271/233 333/265 380/286 393/297 415/305 431/313 - - - Eliminator 385-902 Ported Alum 371/179 2.425/1.88 82 - - - - - - - 450/320 - - - - Eliminator 385-903 Ported Alum 371/179 2.425/1.88 82 - - - - - - - - - 480/350 - - Flow Technologies - EX-514 Ported Iron N/A 2.35/1.88 N/A 75/56 150/118 227/150 300/191 367/270 407/270 429/293 414/308 419/301 - - - Flow Technologies - EX-514 Dave McLain Alum N/A 2.35/1.88 N/A 73/66 145/128 217/176 283/210 334/239 377/261 404/278 420/293 419/301 - - - Flow Technologies - EX-514 CNC Dave McLain Alum N/A 2.35/1.88 N/A 74/64 146/128 219/170 287/212 347/247 388/282 412/302 434/317 436/330 - - - Flow Technologies - EX-514 Stage I Ported Alum N/A 2.35/1.88 65-84 - - - - - - - 410/315 - - - - Flow Technologies - EX-514 Ported Charlie Evans Alum N/A 2.35/1.88 - No Pipe N/A 70/67 148/116 225/154 296/190 359/229 405/268 435/298 447/317 - - - - Flow Technologies - EX-514 Stage III Ported Alum N/A 2.40/1.88 4.40 65-84 - - - - - - - 485/345 - - - - Manufact. Part Number Port/Vol Int/Exh Valve Size Int/Exh Comb. Cham. Vol .100 .200 .300 .400 .500 .600 .700 .800 .900 1.000 1.100 Average Jon Kaase P51 Charlie Evans Out of Box Alum N/A 2.25/1.76 - No Pipe N/A 74/58 172/106 260/144 335/181 376/210 384/227 368/240 368/246 - - - - Jon Kaase P51 Intake Bowls Ported Charlie Evans Alum N/A 2.25/1.76 - No Pipe N/A 74/58 171/106 260/144 337/181 384/210 399/227 403/240 407/246 - - - - Jon Kaase P51 Ported Charlie Evans Alum N/A 2.30/1.76 - No Pipe N/A 72/57 155/112 253/151 336/187 392/219 423/242 421/255 418/264 - - - - Jon Kaase P51 Alum 310/145 2.25/1.76 N/A 72/52 152/107 234/151 306/183 350/202 368/215 388/229 395/239 - - - - Jon Kaase P51 SF600 Alum 310/145 2.25/1.76 72 105/103 175/137 258/170 330/199 375/223 395/242 401/251 - - - - - Jon Kaase P51 Ported Stuska1 Alum 315/- - 4.40 N/A 78/- 170/- 261/- 332/- 383/- 398/- 422/- 430/- 433/- - - - Jon Kaase Boss Nine CCM Alum N/A 2.30/1.90 N/A 79/65 161/128 244/186 308/244 366/272 409/287 406/299 396/306 - - - - Jon Kaase Boss Nine Ported Wells Alum N/A 2.30/1.90 - No Pipe N/A 75/52 158/123 248/172 328/223 388/261 422/290 430/308 432/314 - - - - Jon Kaase Boss Nine Ported Wells Alum N/A 2.30/1.90 - No Pipe N/A 74/53 163/127 276/182 356/246 409/282 432/308 430/313 428/315 - - - - Pro Comp 300 Alum 300/130 2.19/1.71 84 73/61 153/110 219/145 241/160 260/174 291/196 306/205 - - - - - Pro-FilerP/N 205 BBF C Alum 420/- 2.45/1.85 60 - 165/135 257/179 331/218 395/262 - 484/308 512/322 524/329 521/334 - - Pro-Filer Ported Bennett I-52 E-55 Alum N/A 2.40/1.90 - No Pipe N/A - 166/115 243/164 304/210 356/244 410/272 462/289 486/305 504/319 - - - Manufact. Part Number Port/Vol Int/Exh Valve Size Int/Exh Comb. Cham. Vol .100 .200 .300 .400 .500 .600 .700 .800 .900 1.000 1.100 Average Pro-Filer 550 Ported Bennett Alum N/A 2.45/1.85 66 - - - - - - - - 550/- - - - Pro-Filer BBF C-460 CNC Darin Morgan SF600 Alum N/A 2.45/1.85 - No Pipe N/A - 150/125 237/178 312/233 390/279 456/315 498/342 525/359 540/371 540/376 - - Shanons Engineering - EX 514 Bowl Blend N/A 2.35/1.94 63-78 - - - - - - 392/288 - - - - - Shanons Engineering - EX 514 Mod. Ported N/A 2.35/1.94 63-78 - - - - - - 418/310 - - - - - Shanons Engineering - EX 514 Pro Ported N/A 2.40/1.90 63-78 - - - - - - - 458/343 - - - - Shanons Engineering - A-series Ported N/A - N/A - - - - - - - 481/- - - - - Sonny's Ported C-460 N/A - 65 - - - - - - - 507/- - - - - Trick Flow Street SF600 N/A 2.20/1.76 N/A 72/60 152/110 219/145 273/180 312/204 334/223 - - - - - - Trick Flow 429/460 SF600 Alum 290/130 2.20/1.76 4.38 2" Pipe 74 72/60 152/110 219/145 280/180 331/204 344/225 350/240 - - - - - Trick Flow 429/460 Charlie Evans Out of Box Alum 290/130 2.20/1.76 - No Pipe 74 66/50 144/100 211/138 275/168 325/193 351/211 351/222 - - - - - Trick Flow 429/460 Bowl Work Charlie Evans Alum N/A 2.20/1.76 N/A 68/54 146/104 214/143 279/178 328/206 356/227 354/235 - - - - - Trick Flow 429/460 Ported Charlie Evans Alum N/A 2.20/1.76 N/A 69/64 148/116 233/147 301/208 335/208 357/228 373/240 - - - - - Manufact. Part Number Port/Vol Int/Exh Valve Size Int/Exh Comb. Cham. Vol .100 .200 .300 .400 .500 .600 .700 .800 .900 1.000 1.100 Average Trick Flow 429/460 Ported Smithberg Racing Alum 305/- 2.20/1.76 4.31 No Pipe 74 77/56 156/115 235/154 294/188 335/218 365/241 385/264 408/279 - - - - Trick Flow 429/460 Ported TEA Alum 325/145 2.25/1.76 - 2 Pipe 80 78/58 138/117 211/158 288/199 343/237 369/260 387/276 394/287 - - - - Trick Flow 429 CJ Ported Kaase Alum N/A 2.25/1.75 N/A - - 245/172 308/203 350/228 375/241 395/244 401/246 - - - - Trick Flow (A460 Style) Ported Fox Lake Stage 1 Alum N/A 2.30/1.88 90 - - - - - - - 411/300 - - - - Trick Flow (A460 Style) Ported Fox Lake Stage 2 Alum N/A 2.35/1.88 90 - - - - - - - 442/335 - - - - Trick Flow (A460 Style) Ported Fox Lake Stage 3 Alum N/A 2.35/1.88 92 - - 238/183 292/225 353/258 396/288 433/311 463/346 465/354 - - - Trick Flow A460 SF600 Alum 340/- 2.30/1.88 83 - - - - - - - 423/300 - - - - Trick Flow A460 SF600 Alum 340/172 2.30/1.88 4.50 2" Pipe 91 72/68 142/121 213/164 271/202 325/235 365/262 395/284 412/300 - - - - Trick Flow A460 Alum 340/172 2.30/1.88 91 72/57 142/106 213/145 271/179 325/209 365/238 395/260 412/274 - - - - Trick Flow A460 Alum 340/172 2.30/1.88 91 72/64 142/132 213/156 271/190 325/222 365/250 395/268 412/280 - - - - Trick Flow A460 CNC Chamber SF600 Alum 340/172 2.35/1.88 4.50 2" Pipe N/A 76/67 160/120 246/162 312/204 357/237 392/264 418/286 428/303 - - - - Trick Flow A460 CNC SF600 Alum 360/180 2.40/1.88 4.60 2" Pipe N/A 79/71 162/129 244/175 308/216 369/251 410/280 478/304 458/321 - - - - Manufact. Part Number Port/Vol Int/Exh Valve Size Int/Exh Comb. Cham. Vol .100 .200 .300 .400 .500 .600 .700 .800 .900 1.000 1.100 Average Trick Flow A460 Dave McLain Out of Box Alum N/A 2.30/1.88 N/A 72/61 154/126 225/175 279/211 322/243 358/269 372/281 383/292 393/- - - - Trick Flow A460 Charlie Evans Out of Box Alum N/A 2.35/1.88 N/A - 157/112 233/157 293/190 345/218 380/240 390/255 393/262 - - - - Trick Flow A460 Ported Charlie Evans SF600 Alum N/A 2.35/1.88 4.625 No Pipe N/A 74/58 161/118 245/165 315/200 375/235 408/267 439/294 465/312 - - - - Trick Flow A460 Ported BJs Cylinder Head Alum N/A 2.392/1.92 4.625 No Pipe N/A 74/69 153/140 237/180 311/224 368/265 416/296 450/314 452/327 - - - - Trick Flow A460 350 Ported TEA Alum N/A 2.35/1.88 N/A 80/63 160/131 244/179 314/227 380/271 424/311 448/339 460/361 - - - - Trick Flow A460 350 Ported TEA Alum 350/180 2.35/1.88 N/A 80/63 160/131 244/179 314/227 380/271 415/311 435/339 457/361 - - - - Trick Flow A460 360 Ported TEA Alum 360/180 2.40/1.88 4.60 85/87 80/72 170/134 251/182 325/227 389/271 430/312 455/345 463/364 - - - - Trick Flow A460 Ported BES Alum N/A - 84 - 164/123 268/172 344/218 403/267 450/311 475/338 485/354 491/367 501/375 - - Trick Flow A460 Alum 360/180 2.40/1.88 4.60 2" Pipe 85/87 79/71 162/129 244/175 308/216 369/251 410/280 437/304 453/321 - - - - 1 gerg reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,310 Posted April 13, 2016 so many figures there for all,look at the blue thunder cleveland heads ! Share this post Link to post Share on other sites
gerg 10,871 Posted January 21, 2017 Some port mould analysis on clevo 2V, 4V, and Edelbrock heads. Very interesting. This site was paywalled a few years ago and I subscribed, now it's owned by another mob and runs on advertising So anyone can access it. http://www.fordmuscle.com/archives/2007/10/351CHeads/index2.php Share this post Link to post Share on other sites
ando76 4,354 Posted January 21, 2017 Thanks for posting gerg. Very informative. I've got a set of 2v closed chambers arriving from Cam tomorrow. I did some before testing as they had been touched by someone. They only went about 10cfm better than standard. Hoping for much larger gains after Cam's work as they are going on a meth skid car. 1 gerg reacted to this Share this post Link to post Share on other sites
gerg 10,871 Posted January 21, 2017 Thanks for posting gerg. Very informative. I've got a set of 2v closed chambers arriving from Cam tomorrow. I did some before testing as they had been touched by someone. They only went about 10cfm better than standard. Hoping for much larger gains after Cam's work as they are going on a meth skid car. Hey Ando what was done to them to gain 10cfm? I plan on just tidying up the bowl and short turn and getting a 3-angle seat on mine. Also a 3-angle doesn't do much at max lift, but part lift improves heaps. Share this post Link to post Share on other sites
ando76 4,354 Posted January 22, 2017 Not that much really. Someone had got in there with the burr and removed some material but it was kinda all over the place. Cam had to re-do it all, fix x section, tidy up around the valve guides, throat area correction etc etc. it went on and on. I'm expecting decent flow out of them now. Will probably flow similar to my clevo units. You can sorta see from those plugs how just a good seat cut (Cam's is pretty special, I.e. More than 3 cuts), bowl/throat correction and some love in the short turn really picks these old girls up. The good seat cut really works right thru the lift range. Yes it's most effective when the valve first cracks and up to mid lift. Here it accelerates the air and gets the air speed really happening. Of course that then carries thru to the mid to high lift areas. So you can see how in reality it works the whole way thru the range. You won't get as higher airspeed and swirl in the mid to high, without first creating it in the low. It's a flow on effect if you like. It's also something that you may not necessarily see on the bench, in fact there may even be some slowing in the high lift 'on the bench'. Put them on the engine and they make more power than the cfm suggests and most times more than heads with big high lift cfm flow. Well that's my experience. Send them up mate, you know you want to. Don't need to come to me, just Cam in Brissy. 1 gerg reacted to this Share this post Link to post Share on other sites
gerg 10,871 Posted January 22, 2017 Yeah that's the exact theory I'm applying on my revamp. Get the momentum going earlier and the kinetic energy will keep it flowing till the valve closes. That's something that a flow bench can never pick up: stop-start flow and pulse tuning. Even though mine's only a 302, it could still benefit from a better shaped port. Aussie 2Vs have pretty shit flow for the size of the port, most flow charts I've looked up are at around the 180 mark (marginally better than a 351W) whereas US units are a consistent 200. Could come down to the quality of machining down into the bowl. Sure I could send them away but I'd like to have a go at the ports myself and get the 3-angle and back-cut done outside. Share this post Link to post Share on other sites
ando76 4,354 Posted January 22, 2017 Good plan. I'll PM you. Share this post Link to post Share on other sites
