steveheffo 1 Posted April 10, 2016 Hello I need to change my gas converter I was wondering do i need to decant the tanks before I disconnect the gas line from the converter or do the tank solenoids prevent the gas flow .... btw the battery and wiring is out of the car........ thanks Steve Share this post Link to post Share on other sites
hendrixhc 10,918 Posted April 10, 2016 Should be a shut of tap on the tank in line with the gas line. 1 tpak addict reacted to this Share this post Link to post Share on other sites
XFChris 126 Posted April 10, 2016 Should be a shut of tap on the tank in line with the gas line. ^This If its a common brand of tank, there will be a service panel cover, which will be secured by 2 nuts or similar, take that off, You then should be able to see, amongst other things, a brass? looking knob, or tap. Turn that fully clockwise and that should cutoff gas supply from the tank. Tanks do not need to be decanted to change a converter, just cut off the gas supply as described above. Share this post Link to post Share on other sites
351XD_Fairmont 604 Posted April 10, 2016 Yeah mate as said there'll be a shut-off at the tank but just keep in mind that line to the converter will have gas in it under pressure, you might want to cover the fitting with a rag when undoing it so you don't get sprayed in the face Share this post Link to post Share on other sites
steveheffo 1 Posted April 10, 2016 Hi everyone, Thanks so much for your replies . Bit of backround on what i am doing I had a au 1 trayback it was white anyway I have completely dismantled it and painted it metallic gunmetal grey I put in a mew dedicated gas motor and gearbox, then I bought a series 2 ghia and put the front end in then I installed the climate control and all the woodgrain dash etc( basically the complete ghia interior) had it all finished but then discovered I had to change the wiring looms to the series 2 apparantly the pinouts are not exactly the same so I had to dismantle it and start again (((((( Does anybody know what I do about the abs brakes my car didn't have them orginally but will i need to put them in so the computer sees them (not sure here I am a builder not a mechanic lol) anyway it will be worth it it looks like a show car Thanks again everyone ........ Steve Share this post Link to post Share on other sites
SLO247 1,713 Posted April 11, 2016 Worst I can see happening is a warning light in the dash cluster. If so just take the globe out. Share this post Link to post Share on other sites
steveheffo 1 Posted April 11, 2016 great sounds good to me I wont worry about it good on you and thanks for that regards Steve Share this post Link to post Share on other sites
tpak addict 1,909 Posted April 11, 2016 Make sure when you reconnect the LPG lines they are leak free.... Put some dish washing detergent in a spray bottle with some water and spray on the connections you have done... if it leaks it will bubble. Share this post Link to post Share on other sites
steveheffo 1 Posted April 11, 2016 No worries mate I have a gas fitters lpg licence we are builders and plumbers lol but iI really appreciate your concern. BTW did you read my earlier question about the abs system do you have any thoughts ? Thanks again Regards Steve Share this post Link to post Share on other sites
tpak addict 1,909 Posted April 11, 2016 If you did the whole loom into the car, then the plugs should be there to put the sensors in... just need to change the front hubs. Not sure on the rear wether the tone wheels are on the axle or not.... Share this post Link to post Share on other sites
steveheffo 1 Posted April 11, 2016 yes i do have the correct hubs i put them in from the ghia so i guess i just need to get the brake lines etc and the module or do i just plug in the sensors and forget the rest this is difficiult as I am a builder not a mechanic lol thanks mate regards steve Share this post Link to post Share on other sites
tpak addict 1,909 Posted April 11, 2016 You will need all the ABS system for it to work... Its an all or nothing affair Share this post Link to post Share on other sites
