Jestr75 41 Posted March 29, 2016 Hey guys, I just put a different borg warner diff under my XD. I pulled the cover off and everything inside looked ok, Cleaned it out and added fresh oil. It spun freely and no noise. Put it in the XD and drove out the shed and has a god awful clicking/clunking sound as though its not meshing on the teeth properly. Only makes noise going forward not reverse. Jacked the car up and turning the tailshaft by hand there is NO noise. If i turn either of the wheels by hand the clunking sound can be heard. Its an LSD and all the teeth on crown and pinion wheel looked good, wear pattern looked ok. I don't know a much about diffs so anyone got a few suggestions as to what i should be checking first?? Share this post Link to post Share on other sites
steve mcqueen 1,796 Posted March 29, 2016 Spider gears in the LSD, I had one age's ago do the same thing, it wont last long, well mine didn't. Same clunking noise you have described in the only forward gears. Find another diff Get one from a EA-EB-ED station wagon. 2 XTREME KARTS XF and gerg reacted to this Share this post Link to post Share on other sites
Jestr75 41 Posted March 29, 2016 Thanks mate, Looks like its time to start learning about diffs . Will have to put the 2.92 back in to keep it on the road. Share this post Link to post Share on other sites
CHESTNUTXE 7,300 Posted March 30, 2016 Let the games begin. Share this post Link to post Share on other sites
MNTL.XD 3,831 Posted March 31, 2016 Banana peels should see another 10,000ks out of it yet! Hehe Share this post Link to post Share on other sites
Jestr75 41 Posted March 31, 2016 Already marked out a bit of my wall to bang my head against. 1 MNTL.XD reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,300 Posted March 31, 2016 just take the whole thing to the diff shop and pick it up fully fixed,they will check the LSD and have it done in no time. 2 MNTL.XD and hendrixhc reacted to this Share this post Link to post Share on other sites
Jestr75 41 Posted April 2, 2016 Pulled the axles out and the diff centre today. Pretty ugly in the axle tubes with metal everywhere. Almost looks like it has had water in it at some stage. The axle splines were covered in it as well. Took the LSD centre apart and the spider gears looked ok to me. No bits missing or obvious signs of wear (well to my untrained eye anyway), the cones look pretty worn out and the axle gears had a bit of wear on the bottom side of them. Share this post Link to post Share on other sites
gerg 10,871 Posted April 2, 2016 You can clean up the axles and housing yourself but basically throw everything else in the bin and start again. The cones have obviously copped some shavings between the spiral and the diff centre, which is not a good look. You say the spiders look ok but had clunking back and forth, it's because the cone wear has allowed the gears to come further out of mesh from each other, giving excess backlash. In any case, once you're through the hardening on any component, it's toast. That goes for the pinion and crown gears too, any metal in the oil will wear away the hardening leaving the soft metal underneath to wear in no time. The hardening is generally only a couple of thou deep so doesn't take much. Second hand centres can be had on ebay, etc for around the $250 mark and a full set of carrier, pinion and axle bearings and seals will be about $150. A set of gears if needed are pretty cheap, wouldn't pay more than $80 for a set, for regular ratios anyway. Start getting into drag type ones (ie 3.50 and up) and start saving. If you really want to learn then go for it but finding a good second hand assembly will be cheaper and easier. 1 steve mcqueen reacted to this Share this post Link to post Share on other sites
Jestr75 41 Posted April 2, 2016 Thanks gerg. I am still deciding what i will do with it. I took an axle out my existing diff and its only a 25 spline. The 3.89 gear set looks a lot thicker than the 2.92 in there at the moment as well. Thought about swapping gear sets in it but not sure the gears will fit and i am still left with a 25 spline rear end. Share this post Link to post Share on other sites
Jestr75 41 Posted April 3, 2016 Had another bit of a look at things today. The gear sets I have are the same width (must of been the beers lol) so the 3.89's will fit into my 2.92 diff. It is only 25 spline though and has a different lsd set up. Not sure how it will handle the torque but i have been running this diff with the 2.92 ratio and the T5 behind my clevo for six months with out issue. Hey Gerg, I thought i read in another thread you had a 25 spline axle diff behind your clevo? How is that holding up?? 1 gerg reacted to this Share this post Link to post Share on other sites
gerg 10,871 Posted April 3, 2016 Hey Gerg, I thought i read in another thread you had a 25 spline axle diff behind your clevo? How is that holding up?? Yeah mate your memory is very good! Mine's a one-legger for now, chucked it in after the LSD broke all the hemisphere bolts. It's a 3.27 but I want to go back to 2.92 or taller and when I do, I'll throw in a 28-spline lsd. 3.27s are too short, especially with the short 1st in the EA T5 I'm running. Pretty annoying when just cruising around, you're forever changing gears. I figured an open diff will let the 25-spline axles live longer as you just spin a wheel when it lets go instead of making the axles fight each other. Share this post Link to post Share on other sites
Jestr75 41 Posted April 3, 2016 I think i will put the 3.89 gears in the 25 spline and get it on the road. Will see how i like it with that ratio. Share this post Link to post Share on other sites
gerg 10,871 Posted April 3, 2016 Lol I wanna see the carnage after that one pops Share this post Link to post Share on other sites
Jestr75 41 Posted April 4, 2016 I will strap a Go-Pro under the car and get footage as well if you like! 2 gerg and tpak addict reacted to this Share this post Link to post Share on other sites
Jestr75 41 Posted April 5, 2016 Can't decide which way to go? Might just put the 2:92 diff i took out back under it and find a cheap 28 spline ine one to put the 3:89 gears into even if its just a single spinner. Share this post Link to post Share on other sites
