perthstocky 0 Posted March 29, 2016 Hey guys i have an xe fairmont and have just purchased an xg work ute.While thinking of things i can do to the ute i came up with the idea of changing front to xe.Has anyone done this or know if its a fairly easy swap .i have all the xe parts and panels to do the swap.I like the idea of having xe fairmont and xe (looking) ute. Cheers....Blair Share this post Link to post Share on other sites
xm-221 1,803 Posted March 29, 2016 From memory you'll have to relocate the lower tab sideways a little bit. Then fill the gap where the headlight mounts on the radiator support and drill appropriate holes for them. You can see the cut out next to the inside edge of the headlight bucket in the pic below. Then you have to play with plug ends to fit, indicators for the guards to be terminated, panel wise everything else should just bolt on no problemo. 4 SLO247, gerg, Ants and 1 other reacted to this Share this post Link to post Share on other sites
SLO247 1,713 Posted March 29, 2016 That's right. Easily doable. Share this post Link to post Share on other sites
perthstocky 0 Posted March 29, 2016 Ok thanks for that guys.might need a little bit of help with it but looks like it will be doable. Share this post Link to post Share on other sites
