uterus 80 Posted March 22, 2016 Ok this has been asked many times i know burlt i recently bought an xg ute the temp would over heat so i bought a new one now which ine of those 2 senders that come out of the thermostat block part which one makes the temp gauge in the instrument cluster work as now nothing works. I went to the wreckers and all they had was an el one it fits but it does not have the spot for the smaller one to go into it just the big one got second hand one as i cracked the old one and was wondering do you need the smaller one connected even when i put the old one back on with both the gauge does not work. Im thinking of getting rid of it and putting in an external temp gauge? Any help would be appreciated thanks guys.and why would the gauge now not work even with the original set up back on it? A fuse maybe and if so what ir where is it?. Share this post Link to post Share on other sites
deankxf 20,266 Posted March 22, 2016 post 7 on this page.. http://www.xfalcon.com/forums/index.php?/topic/41324-xg-outback-ute-troubleshooting/ i would say the larger one is for the ecu.. the smaller one for the gauge. 2 Outback Jack and steve mcqueen reacted to this Share this post Link to post Share on other sites
SPArKy_Dave 8,863 Posted March 24, 2016 If I remember rightly, in XG's, the ECU temp sensor, is the two wire sensor on the side of thermostat housing with the plug like an injector on the later e-series/XH, and a round USA style sensor plug on the earlier ones/XG. Usually around $15.00 to buy new from Bursons, Repco or similar (for the later ones at least). The gauge sender, is a single wire sensor with a spade terminal. 2 Outback Jack and uterus reacted to this Share this post Link to post Share on other sites
Mr Polson 10,214 Posted March 24, 2016 a round USA style sensor plug on the earlier ones/XG. Usually around $15.00 to buy new from Bursons, Repco or similar (for the later ones at least). Funny, I sold a XG coolant temp sensor to a customer yesterday. The XG one, is the same as XF EFI. But the older style is more than $15, cant recall the exact amount. 1 uterus reacted to this Share this post Link to post Share on other sites
uterus 80 Posted March 25, 2016 Ok cool i put in an auxillary temp gauge it went up to 120degrees Celsius in a matter of 20 mins so yep its def not those temp senders lol Share this post Link to post Share on other sites
tpak addict 1,909 Posted March 25, 2016 I would change the thermostat personally before anything else..... 1 uterus reacted to this Share this post Link to post Share on other sites
uterus 80 Posted March 27, 2016 Im thinking i will although its got a new one in it. It has a 91AB head on it , i just got an ef falcon which has a 91AA head on it and apparently the guy i got it of said they changed iut the 91AA head and put in the 91AB head now i dont know if it will make any difference but im goingcto change it back anyway and see what happens. The ef has a full serpintine belt set up with thermo fans now that should be easy enough to change into the xg yeah looks just a matter of changing out alternator and power steering and putting on belt tenisonet and getting rid of fan clutch or is that set up enough for tge xgs? Share this post Link to post Share on other sites
tpak addict 1,909 Posted March 27, 2016 I believe XG tensioner is different to EF+ Share this post Link to post Share on other sites
Thom 6,650 Posted March 27, 2016 Changing to serpentine belt involves swapping the timing cover, balancer, alternator, ps pump, ac pump, tensioner and a ef/el waterpump as they spin backwards, unless you have a xh ac pump bracket and bf the ac pump may foul the intake (some engines do some don't ) Share this post Link to post Share on other sites
deankxf 20,266 Posted March 28, 2016 Changing to serpentine belt involves swapping the timing cover, balancer, alternator, ps pump, ac pump, tensioner and a ef/el waterpump as they spin backwards, unless you have a xh ac pump bracket and bf the ac pump may foul the intake (some engines do some don't ) the EF water pump hose outlet is smaller too, so need to adapt the radiator hose too.. a mate of mine has an EL engine in XG with serp belt.. chopped up thermo fans(they dont fit the XG radiator as its narrower.) when i saw it.. i thought.. leave it stock lol.. 1 Outback Jack reacted to this Share this post Link to post Share on other sites
uterus 80 Posted March 28, 2016 Oh so not a 5 minute job lol i may put the thermos into my f100 then way more room in there lol Share this post Link to post Share on other sites
