Crazy2287 1,886 Posted February 16, 2016 Those messages man... 3 SLO247, XPT and Thom reacted to this Share this post Link to post Share on other sites
SLO247 1,713 Posted February 16, 2016 Yeah Crazy summed it up. Share this post Link to post Share on other sites
XPT 673 Posted February 17, 2016 50 grand and can't find room for programmable management or an intercooler? Has a "factory" dry ice setup because it's a rare S Pack, WTF is that horseshit? 255rwkw is nothing to sneeze at but clearly it wasn't engineered/tuned well enough to sustain that power level safely. This stage 1-2-3 talk doesn't mean anything. All of that info is fairly useless other than for some history and what mistakes/abominations never to repeat. Still I agree with the other guys, it's a good starting point for a quick car. 3 wagoon, XF001 and gerg reacted to this Share this post Link to post Share on other sites
XF001 93 Posted February 17, 2016 I don't believe half the rubbish I've been told about this car. It is satans bastard child and shall be treated as such when I get around to pulling it down. Sent from my SM-G900I using Tapatalk 5 MNTL.XD, XPT, wagoon and 2 others reacted to this Share this post Link to post Share on other sites
gerg 10,871 Posted February 17, 2016 Sounds like some stage 3 wanking going on 5 XPT, dougie77, XF001 and 2 others reacted to this Share this post Link to post Share on other sites
LJDB 103 Posted February 17, 2016 I recently found an old cataloge on old mike vine turbo kits from back in the day and they all seemed to be blow through and none made anywhere near 255kw. I'd be stripping it down and starting from scratch. Looks like an old set up and turbocharging has come alone way since it was probably built. Share this post Link to post Share on other sites
LJDB 103 Posted February 17, 2016 http://www.mikevineturbochargers.com.au/pdf/Turbo%20Falcon%20Article.pdf 1 XF001 reacted to this Share this post Link to post Share on other sites
wagoon 2,429 Posted February 17, 2016 I don't believe half the rubbish I've been told about this car. It is satans bastard child and shall be treated as such when I get around to pulling it down. Sent from my SM-G900I using Tapatalk That's the right attitude and mind set to have. Expect the worst until proven otherwise. As far as the 255rwkw I'm thinking the car would have needed to be just about running on meth not just a spray. The mix of meth to fuel would have had to be pretty high so as to keep the intake temps down at 14psi (or you could use the little magical black switch BHAHAHAHAHA) . When she said she ran out of fuel it was more likely ran out of meth which would have caused all sorts of problems literally. Best thing to do is sit down and make a plan of what you want from the car so you know how far your going to go with it. This sort of project could get out of hand pretty damn quick as everything would be better if it was done again. But if you don't need it done again and it's ok to use then that will save time and money, no point in wasting cash just to redo something. Once I get my car on the road I would be happy to lend a hand if you need/want it. 2 Outback Jack and XF001 reacted to this Share this post Link to post Share on other sites
Xelisty 366 Posted February 17, 2016 Good luck with the build. Sound like some work ahead. FYI Having owed an old mike vine stage two xe, I know he had three stages to choose from. I got a stage 2 which was the below above the stage 1 twin strongberg carbies, extra heavy duty clutch and 1.1 bar boost so about 16psi. No meth but same water injection system as stage 1. Yes it had a green light that light up when water injection was running. Had a 5 litre water tank that you had to check and top up if you were on it too much. Pretty hard to remember what rwkw but at was around the 190rwkw. Brutal turbo lag but fun as hell. Sent from my iPhone using Tapatalk 3 Outback Jack, Stumps and wagoon reacted to this Share this post Link to post Share on other sites
ando76 4,354 Posted February 17, 2016 As everyone has said, at least she had the decency to reply. Now it's just a matter of disregarding all that crap. Strip it out. Work ou what you can salvage and re-build with a firm plan. Wagoon has offered his time and I'm happy to come and have a look as well. I'll be down in Brissy shortly to do the start up and tune on wagoon's roller cam donk and I am more than happy to lend a hand (no cost) if you need/ want it. 5 XF001, xhadyboy, TUFE and 2 others reacted to this Share this post Link to post Share on other sites
XF0747 69 Posted February 18, 2016 gees 255kw with no cooler and standard ecu i want that tune in mine plz 3 wagoon, Panko and XF001 reacted to this Share this post Link to post Share on other sites
XF001 93 Posted February 25, 2016 Would a 600 x 300 x 76 intercooler be adequate?<br /><br />Sent from my SM-G900I using Tapatalk<br /><br /> Share this post Link to post Share on other sites
XPT 673 Posted February 25, 2016 Would a 600 x 300 x 76 intercooler be adequate?<br /><br />Sent from my SM-G900I using Tapatalk<br /><br />It will do the job nicely 1 XF001 reacted to this Share this post Link to post Share on other sites
XF001 93 Posted February 29, 2016 Picked up the intercooler yesterday.<br /><br /><br /><br />Any advice on where to get the piping from? After the motor is sorted, would it be easier to mock up the plumbing in pvc pipe before buying the pipework?<br /><br />Sent from my SM-G900I using Tapatalk<br /><br /> 1 XPT reacted to this Share this post Link to post Share on other sites
XPT 673 Posted February 29, 2016 Unless you can ally tig weld, I'd just make it from Mild Steel 90 and 45 deg mandrel exhaust tube bends 2.5" would be fine. You can even Mig it and just paint it. Put some weld tacks on the end of each tube to stop the silicone joiners from popping off. I got mine from Western filters here in Sydney when I did my old car. I'm sure there's someone closer to you that sells them. Basically with pipe work you have a start point and finishing point. So you start by mounting your intercooler securely. You would put you silicone joiner on your turbo outlet and work your way to the intercooler, then from the intercooler to the throttle body. Just try to keep the bends as smooth and gradual as you can.Try to minimise the amount of joints as these are potential leaking points. Try to only use them where it is impossible use a whole section of tube,or where one section is fixed to the body and the other on the engine. 3 XF001, MNTL.XD and gerg reacted to this Share this post Link to post Share on other sites
XF001 93 Posted February 29, 2016 Thanks for the advice XPT. Will do as you suggest<br /><br />Sent from my SM-G900I using Tapatalk<br /><br /> Share this post Link to post Share on other sites
blu xe 825 Posted March 5, 2016 Holy crap just looked through this thread and the chicks dad should never be allowed to work on a car ever again! Dash has more lights and switches than a nasa space mission! Good starting point for a project none the less. I'd start with wiring and dash. Rip everything out and start again. It'll be easier than sorting that abomination. Probably easier to go an aftermarket ecu to get it running right. 1 XF001 reacted to this Share this post Link to post Share on other sites
Panko 2,480 Posted April 13, 2016 wow. Finally found your thread to take a look at. I have spoken with you on Facebook about this car a few times. Good luck with it. I honestly thought i was diving into the unknown buying the turbo xe wagon, but i think our XE is a little better off than this. Ill be watching your progress mate. Share this post Link to post Share on other sites
XF001 93 Posted July 10, 2016 Have started to do a few things on the old girl - finally. Rear brakes were locked on so removed the rear calipers ready for a refurbed set to go on so I can move the bitch around. Checked out the exhaust system while under there and looks like a new 3" system will be required as the existing one is full of holes. This could take a while longer than I expected. 1 NZXD reacted to this Share this post Link to post Share on other sites
XF001 93 Posted July 23, 2016 Almost ready to bolt the rear brakes back together. Gave them a coat of paint after I put a kit through them. Looking a lot better Next on the agenda will be having a look at the spaghetti called wiring under the dash. Front seats will be out as will half the dash. Not looking forward to doing it. Sent from my SM-G900I using Tapatalk Share this post Link to post Share on other sites
XF001 93 Posted July 19, 2017 Been a while since I posted so I thought an update was in order. Had a guy who builds turbo motors come and have a look at the bitch and he was straight up with me about what was required.He estimate of what it would cost to rebuild the motor, set up a decent engine management system and all the other crap necessary to make a reliable street car has forced me to look at other options.My thoughts now are leaning towards a turbo barra transplant, most likely from an fg falcon.The search has now begun for an fg turbo motor with all the bolt ons, computer and loom.Sent from my SM-G900I using Tapatalk 6 dex, judgetread, blackxt and 3 others reacted to this Share this post Link to post Share on other sites
XF001 93 Posted July 21, 2017 Success. Have got a bf turbo barra motor with all the bolt ons as well as all the bits like loom, ecu etr to make it run. Motor should be delivered to my place by the end of next week.Now let the fun begin.Sent from my SM-G900I using Tapatalk 4 Valvebouncer, deankxf, dex and 1 other reacted to this Share this post Link to post Share on other sites
blackxt 699 Posted July 22, 2017 If you decide to off load any xflow turbo stuff let me no . I might be keen on the hot side stuff Sent from my iPhone using Tapatalk Share this post Link to post Share on other sites
matt_lamb_160 252 Posted July 23, 2017 Did you end up pulling the engine down? Share this post Link to post Share on other sites
XF001 93 Posted July 28, 2017 Not yet matt_lamb_160. It will get pulled down and most likely rebuilt after I get the barra in and running. Sent from my SM-G900I using Tapatalk Share this post Link to post Share on other sites
