Dyllan187 324 Posted November 8, 2015 Lol can't stand her voice Sent from my iPhone using Tapatalk Share this post Link to post Share on other sites
Dyllan187 324 Posted November 16, 2015 Oil pressure gauge fitted after finding an old oil line leaking under the dash Throttle bracket I made out of a crossflow one Fitted I bought my power steering back too Sent from my iPhone using Tapatalk 2 Thom and Ants reacted to this Share this post Link to post Share on other sites
Ants 6,370 Posted November 16, 2015 Mad not too bloke,smart move. 1 Thom reacted to this Share this post Link to post Share on other sites
Dyllan187 324 Posted November 16, 2015 Yeah the box alone on eBay is 2,450 I got my whole setup back for $1,000 Sent from my iPhone using Tapatalk Share this post Link to post Share on other sites
Dyllan187 324 Posted November 17, 2015 Temp guage sorted today along with original pulleys to suit power steer. Have to finish fitting the steering box tomorrow and weld a bracket it up. It MIGHT drive tomorrow Sent from my iPhone using Tapatalk 1 SPArKy_Dave reacted to this Share this post Link to post Share on other sites
Dyllan187 324 Posted November 18, 2015 Ok so after a hard and stressful days work yesterday the truck now has Pulleys Belts Thermo's back on Power steering pump Power steering box in - 1 bracket needs repair but that can wait Lines hooked up and steering system topped up Brake line bracket refitted Column coupling done Pitman arm done and front tyre back on So the truck now steers! I'll be fitting the rent-a-tailshaft this arvo and I (should) be able to go for a drive Sent from my iPhone using Tapatalk 1 Thom reacted to this Share this post Link to post Share on other sites
Dyllan187 324 Posted November 19, 2015 Drove the old girl for the first time today Rear lights - just for fun! Sent from my iPhone using Tapatalk 2 Thom and gromet88 reacted to this Share this post Link to post Share on other sites
Dyllan187 324 Posted November 23, 2015 My custom fan switch board - a right angle bracket some black paint and a tek screw Sent from my iPhone using Tapatalk Share this post Link to post Share on other sites
Dyllan187 324 Posted November 23, 2015 Cup on the dash for the temp gauge Sent from my iPhone using Tapatalk Share this post Link to post Share on other sites
Jonathan Mark Davidson 169 Posted November 24, 2015 got an auto yet if not lets just fit an eletric clutch setup it only $100 and 0 point fine for driving out of class Share this post Link to post Share on other sites
Dyllan187 324 Posted November 24, 2015 Getting my AOD this week Sent from my iPhone using Tapatalk 3 Jonathan Mark Davidson, deankxf and Thom reacted to this Share this post Link to post Share on other sites
gerg 10,871 Posted November 24, 2015 Will be interested to see how the AOD goes, not very common in Aus but a good, easy upgrade for an old-school machine. 1 Dyllan187 reacted to this Share this post Link to post Share on other sites
Thom 6,650 Posted November 25, 2015 Getting my AOD this week Sent from my iPhone using Tapatalk Be good to see how it goes, I've got one for the customline Share this post Link to post Share on other sites
Dyllan187 324 Posted November 25, 2015 I'm glad I went with the AOD after seeing how it goes as a manual it'll need the extra gear over a regular 3 speed C6 Sent from my iPhone using Tapatalk 1 gerg reacted to this Share this post Link to post Share on other sites
Jonathan Mark Davidson 169 Posted November 26, 2015 over drive will be good for you and where you live 1 Dyllan187 reacted to this Share this post Link to post Share on other sites
vanJack 43 Posted December 4, 2015 How'd your AOD go...? Share this post Link to post Share on other sites
Dyllan187 324 Posted December 25, 2015 Ok so huge advances have been made - let's hope my app will allow me to upload Sent from my iPhone using Tapatalk Share this post Link to post Share on other sites
Dyllan187 324 Posted December 25, 2015 Thermo bypass switches Sent from my iPhone using Tapatalk Share this post Link to post Share on other sites
Dyllan187 324 Posted December 25, 2015 The AOD Toploader out AOD in - had to get my tailshaft shortened by approx 200mm I can't remember now Shifter in and 'air con' sitting in place Trans cooler squashed in behind the grille Old vs new pitman arm. Old one was a falcon one that'd been resplined and sleeved to fit the 260c steering box and f truck drag link The new (larger) one is what my truck should have had when power steering was fitted It's marginally longer and built specifically for this era of effy downside is, $350 !!! Sent from my iPhone using Tapatalk 1 Outback Jack reacted to this Share this post Link to post Share on other sites
deankxf 20,266 Posted December 25, 2015 whats the go with the steering box, is the 260c one going to accept the 100 pitman arm....sounds like a custom mod Share this post Link to post Share on other sites
Dyllan187 324 Posted December 25, 2015 No. The steering box is out of ye ol Datsun 260c - only one tab needs to be added to fit it to an f truck The pitman arm is a mutant with Datsun spline on one end and a taper on the other to fit the f truck drag link It's the only way to make pre 80's effies power steering 2 Demmo and deankxf reacted to this Share this post Link to post Share on other sites
deankxf 20,266 Posted December 25, 2015 have you set up the TV rod(or with a cable) on the AOD yet, it needs it for the shift points, otherwise goes straight to top gear.(the kickdown looking lever\rod)i had a prick of a time setting one up on My XE about 15years ago, didnt get the correct rod or have a clue on where to get the carby side from Share this post Link to post Share on other sites
Dyllan187 324 Posted December 25, 2015 Throttle Valve cable? If it's not set right it won't shift out of first Mines roughly set til I can afford the kit from lokar Share this post Link to post Share on other sites
deankxf 20,266 Posted December 25, 2015 Throttle Valve cable? If it's not set right it won't shift out of first Mines roughly set til I can afford the kit from lokar maybe with it removed it goes straight to top, cant remember but yeah, at least you know about it. Share this post Link to post Share on other sites
Dyllan187 324 Posted December 25, 2015 Well aware. Asshole thing and quickest way to kill an AOD if not right 1 gerg reacted to this Share this post Link to post Share on other sites
