xander57 2 Posted October 18, 2015 Sorry for the stupid question but is there any difference between standard manifold bolts and extractor bolts i know there supposed to be shorter but anything else? Share this post Link to post Share on other sites
Guest Free.51 Posted October 18, 2015 The standard manifold bolts are a bit longer. Share this post Link to post Share on other sites
bear351c 10,270 Posted October 18, 2015 Standard Clevo's had studs mounted in the heads, with nuts and washers. Share this post Link to post Share on other sites
Nath 1,975 Posted October 19, 2015 On a crossy the standard bolts are longer... I got around it by just using a couple of crush washers to space it out. Share this post Link to post Share on other sites
adrianphu123 73 Posted October 19, 2015 Go with studs, makes it a whole lot easier to fit your headers. 1 XTREME KARTS XF reacted to this Share this post Link to post Share on other sites
gerg 10,871 Posted October 19, 2015 +1 studs, with brass nuts Share this post Link to post Share on other sites
hendrixhc 10,918 Posted October 19, 2015 Whaust studs made it a whole lot easier to line up the headers and gaskets. 3 gerg, slydog and XTREME KARTS XF reacted to this Share this post Link to post Share on other sites
scottly 475 Posted October 19, 2015 My biggest regret is not using studs so +1 for studs Share this post Link to post Share on other sites
scottly 475 Posted October 19, 2015 Try Ron from Kustom Bitz call him give him your measurement thread size and how many you need and he will post any where and he is cheap and a nice dude and likes fords. I had a set made for my barra engine $69 for Allen key wind in studs intake and exhaust nuts and washers that's freekin cheap Share this post Link to post Share on other sites
wagoon 2,429 Posted October 19, 2015 I bought 2 exhaust studs from masters as hendrixhc shows in his pic (it was either $3 or $4 dollars per stud), they are to long for a crossflow when using 3mm thick steel washers (only about 2mm to long but the nut does not touch the manifold let alone secure it). I went to my local bolt store and bought all thread bolts that I cut down to size to make studs which was much cheaper than buying them from masters. I bought 12 bolts and 12 3mm steel washers for under the price of 12 studs from masters which are champion brand studs (I had to buy the studs from masters as the bolt shop gave me 10 not 12, my fault for not checking) Can see the studs I made in this pic, the studs and washers cost me under $35 and when I cut the bolt head off to make the studs I had enough left over to make new engine mount bolts. Share this post Link to post Share on other sites
hendrixhc 10,918 Posted October 19, 2015 I had to cut down the studs as well they were to long. 1 wagoon reacted to this Share this post Link to post Share on other sites
xander57 2 Posted October 19, 2015 Thanks for the replies i'll be going with studs then Share this post Link to post Share on other sites
slydog 7,873 Posted October 20, 2015 ARP Carby studs on mine...ALOT dearer than the above but there black so there cooler than James gold 1's LOL 1 bear351c reacted to this Share this post Link to post Share on other sites
hendrixhc 10,918 Posted October 21, 2015 Arp studs are way cooler then anything i can come up with! Share this post Link to post Share on other sites
wagoon 2,429 Posted October 21, 2015 The bolts I bought were black, and when I trimmed the head off I put the cut bare end into the head so they looked like complete black bolts. Share this post Link to post Share on other sites
ando76 4,354 Posted October 21, 2015 lanolin will keep them black - but maybe not with the heat. just hit them with header paint - done. 1 wagoon reacted to this Share this post Link to post Share on other sites
slydog 7,873 Posted October 21, 2015 See James black not shiney is in bruz 5 hendrixhc, ando76, wagoon and 2 others reacted to this Share this post Link to post Share on other sites
ando76 4,354 Posted October 21, 2015 look at all the complete satin black engines with blowers and all being built atm. its in for sure. 1 Thom reacted to this Share this post Link to post Share on other sites
Stu5766 394 Posted November 2, 2015 ARP sell extractor studs & nuts in a pack. Got mine from rocket. Share this post Link to post Share on other sites
