jamie247 542 Posted April 4, 2013 Ok guys i was gonna put a toplaoder in my xe but now have decided to go a t5 for a smoother ride etc what model fords in t5 can i put in the xe and can i use the same crossmember that is auto is there a difference and what nneds to be done with bellhousing etc, can i use the 6cyl tailshaft or better to buy a new one to suit,m i'd love a 9inch diff what eould be involved to puit this in sorry if this is question after question i'm new school Share this post Link to post Share on other sites
'Nova 997 Posted April 4, 2013 Basically any T5 from before series 2 EB will fit from memory! Share this post Link to post Share on other sites
Ants 6,370 Posted April 4, 2013 That's a few questions. V8 I assume? 1 Grimmy reacted to this Share this post Link to post Share on other sites
jamie247 542 Posted April 4, 2013 HAHA yeah mate it's a 6cyl auto at the moment but going 351 cleveland manual with 9'' Share this post Link to post Share on other sites
jamie247 542 Posted April 4, 2013 yeah ants it's a sedan Share this post Link to post Share on other sites
Ants 6,370 Posted April 4, 2013 So t5 anything from an xf on will work although eb on ate the better ones. Use a single rail bell housing (top loader is the same) you need to drill a couple of holes and machine a few mm off the nose of the gearbox and your away. Honestly I wouldn't bother with a 9 inch these days, they are worth a fortune to have one made to fit a watts link arse end. Loads of guys use borg warners nowadays in some tuff cars too, and you'll break loads of t5's before you break a 28spline borgy. Go a 3.45lsd out of an ed xr8 and it will basically bolt straight in and will stand up to the toughest clevo. 2 Lord_fahrquhar and mcfly94 reacted to this Share this post Link to post Share on other sites
Dale82 351 0 Posted April 4, 2013 Hi Jamie you can buy the bell housing from dellow (google them) they make custom bell housings for all applications. best choise in box would be from an el as the tailshaft will also fit if you use an e series diff ( best choice is an eb ed xr6-8 diff with 28 spline axles and 4 pin lsd because there strong and the hand brake setup is the same as xe) you also need a 5speed cross member from an xf and a hydrolic pedal box set up. good luck man im doing the same conversion to my car. Share this post Link to post Share on other sites
jamie247 542 Posted April 4, 2013 thanks heaps guys now on the hunt for parts Share this post Link to post Share on other sites
jamie247 542 Posted April 4, 2013 Hi Jamie you can buy the bell housing from dellow (google them) they make custom bell housings for all applications. best choise in box would be from an el as the tailshaft will also fit if you use an e series diff ( best choice is an eb ed xr6-8 diff with 28 spline axles and 4 pin lsd because there strong and the hand brake setup is the same as xe) you also need a 5speed cross member from an xf and a hydrolic pedal box set up. good luck man im doing the same conversion to my car. Yep i'm buying the rare spares clutch kit for the xuto box with longer pin alot easier and quick fix then a whole new box etc Share this post Link to post Share on other sites
SatansReverence 264 Posted April 28, 2013 Sorry to kinda of steal the thread but I need to replace the T5 in my car (XF T5) and I'm wondering what later model gear boxes I can use with the current bellhousing and cross member. Share this post Link to post Share on other sites
Mr Polson 10,214 Posted April 28, 2013 Sorry to kinda of steal the thread but I need to replace the T5 in my car (XF T5) and I'm wondering what later model gear boxes I can use with the current bellhousing and cross member. Any T5 between XF and EL will bolt straight up from what I've been told. As said earlier in this thread, EB onwards are better if you can get one. Share this post Link to post Share on other sites
jamie247 542 Posted April 28, 2013 hey get your own thread LOL i got my diff guys but still chasing a good t5 Share this post Link to post Share on other sites
jamie247 542 Posted April 28, 2013 whatever satan don't buy shit cheap crap the stuff i seen at afew wreckers only good for scrap mechants Share this post Link to post Share on other sites
SatansReverence 264 Posted April 28, 2013 Any T5 between XF and EL will bolt straight up from what I've been told. As said earlier in this thread, EB onwards are better if you can get one. Thanks for that, will look into something like an XR6 box or something. hey get your own thread LOL i got my diff guys but still chasing a good t5 Stealing yours is easier than making one whatever satan don't buy shit cheap crap the stuff i seen at afew wreckers only good for scrap mechants Yeah, thought as much. Kind of hard to know if a box is good until it's in your car though. Share this post Link to post Share on other sites
jamie247 542 Posted April 28, 2013 HAHAHAH so true yeah it is hard i nearly thought of buying a new t5 tko but i don't know how the diff would go setting it all up etc Share this post Link to post Share on other sites
Thom 6,642 Posted April 28, 2013 Tko with a 26mm spacer on a top loader bellhousing will use a standard length auto tailshaft, slight modification to the gearbox mount shifter comes out the stock hole Share this post Link to post Share on other sites
Lord_fahrquhar 2,580 Posted April 29, 2013 Borgy's are cockroaches. You wont kill em. They'll survive a nuclear blast and several dozen banana skins. 1 Jeff reacted to this Share this post Link to post Share on other sites
jamie247 542 Posted July 8, 2013 ok I got this box the other day 91da 7003 ga seems to be a eb t5 but how do I determine if it's a 6 or out of an 8 Share this post Link to post Share on other sites
gerg 10,871 Posted July 8, 2013 V8s have longer input shafts Share this post Link to post Share on other sites
jamie247 542 Posted July 8, 2013 do you know the lengths between the 6 to 8 Share this post Link to post Share on other sites
gerg 10,871 Posted July 8, 2013 From Dellow website: FORD V8 T5 187 mm INPUT SHAFT FORD 6CYL T5 167mm INPUT SHAFT Share this post Link to post Share on other sites
jamie247 542 Posted July 8, 2013 cheers i'll check now I pulled it down enough looks like it's been recently rebuilt if so for $300 is a bargain gear changes are smooth Share this post Link to post Share on other sites
jamie247 542 Posted July 8, 2013 def t5 6cyl 167mm exact Share this post Link to post Share on other sites
dusty_ben 143 Posted October 24, 2013 Where did u find a chart to decifer what it came out of? Share this post Link to post Share on other sites
