ashXFute 498 Posted August 22, 2015 I picked up a mixed box of parts from someone's failed rebuild the other day. Cost me $500 and included crow double valve springs, oversize vavles, new lifters, bearings, water pump and stock pistons. Using a few more of the parts I have laying about in my shed or already on cars what can I make up? I've got a 2 barrel and 4 barrel manifolds with 350 and 600 holley. 2 different diffs 3.45 or 3.55 2 T5 gearboxes Msd 6al2 set up and running No set idea on cam or anything I just want a good tough cruiser/weekender motor to go in my xf now it's no longer needed for daily duties. Any other parts or work to the motor that would be a good idea at the same time? I also need to pull down the current motor to see what internals I can reuse from it. Any help or advise appreciated Ash Share this post Link to post Share on other sites
wagoon 2,429 Posted August 22, 2015 I took the following that was posted by Sly from crossflow build thread Nath started (http://www.ozfalcon.com.au/index.php?/topic/4606-crossflow-build-advice/ page 3 is where this combo is), it is a very good combo that has worked, will give you the best idea on a great combo and what is needed: Jase Stoodley ran this combo for a while before moving on. Take note those who want realistic reliable pump fuel power all for sensible money. Block: 80da bored & honed .030Crank: 250 ground & balancedRods: 250 machined balanced and 302w ARP bolts fittedPistons: ACL 21cc dish - combined with a 50 odd cc head was about 9.5:1 comp.Cam: 230@50 530lift hydro - great cam for these motors!Head: open chamber carby unmarked ported, 1.85" in, 1.55" exh valves, turned out it flowed 320hpSprings: crow 7333 doubles - head needs machining for these.Other parts included rollmaster chain, yella terra street terra bolt ons, crow pushrods, romac balancer.Used to run a ultraflow manifold with a 500 holley went well but changed over to a cain and 600 vacuum secondaries and what a difference.Was running a Hall dizzy with a MSD 6AL and MSD digital timing computer- the equivalent now would be a 6AL-2programmable running 36deg total timing.Used a 2200stall in a c4 with 3.7 rear gears.the car was a full street car cortina ran 13.6 @ 100mph then 13.3@103 when i changed to the 600vac and made 200rwhp 3 ashXFute, SirkWhyXF and slydog reacted to this Share this post Link to post Share on other sites
