gerg 10,871 Posted February 5, 2016 Yes. It's called "MSD 6AL-2 Programmable" Share this post Link to post Share on other sites
eattsie9 350 Posted February 5, 2016 Hahah thanks Sent from my HTC_0P6B using Tapatalk Share this post Link to post Share on other sites
wagoon 2,429 Posted February 5, 2016 This is the non programmable 6al2 part number 6421 This is the programmable 6al2 part number 6530 This is a 6al part number 6425 I almost bought a non programmable 6al2 when I was looking for one. Make sure you ask who ever is selling it the part number on the front of the unit, as you can see they all have the part number on the front. Yes the programmable 6al2 with part number 6530 is the best and only one to buy if your going to buy any of them. 1 Outback Jack reacted to this Share this post Link to post Share on other sites
slydog 7,873 Posted February 5, 2016 Jegs US... http://www.ebay.com.au/itm/MSD-Ignition-6530-6AL-2-Programmable-Ignition-Control-/111037762637?hash=item19da5dcc4d:g:ONAAAOxyaTxRTN88 Or in Aust... http://www.ebay.com.au/itm/MSD-Digital-Programmable-6AL-2-Ignition-Control-w-RevLimit-MSD6530-/262140024681?hash=item3d08c35769:g:KywAAOSwEgVWQ8sv Share this post Link to post Share on other sites
eattsie9 350 Posted February 6, 2016 Wow about 200 aud difference Sent from my HTC_0P6B using Tapatalk 1 Outback Jack reacted to this Share this post Link to post Share on other sites
slydog 7,873 Posted February 6, 2016 Well I see $523 to $630. Gotta make a profit on there import and there available now in Aust. Or your order and wait and hope its right. Not cheap are they. 1 eattsie9 reacted to this Share this post Link to post Share on other sites
Outback Jack 6,352 Posted February 6, 2016 Ask Ashxf where he got his mate... sure it was cheaper... but maybe was when exchange rate didnt require ky lube for the Aussie side of the transaction.... lol. Sent from my GT-S7583T using Tapatalk Share this post Link to post Share on other sites
gerg 10,871 Posted February 6, 2016 Got mine from an eBay shop in Puerto Rico. Was much cheaper to buy and ship, but sure the AUD was better 2 years ago. Think it was $470 landed. Share this post Link to post Share on other sites
tyko86 4 Posted February 17, 2016 Going to have another go at this with the module and will attempt the below: Pin 6 - white from MSD Pin 3 - red from MSD Pin 1 - to ground Orange from MSD to coil + Black from MSD to coil - Question is in regards to pin 3 some threads I have read state that this should be 12v switched and the MSD manual says that the small red wire should be 12v switched (do they both need to be) I know it's been done to death but I really want it running with the msd. Looking for clarity here if anyone can assist. Share this post Link to post Share on other sites
slydog 7,873 Posted February 17, 2016 Mine runs 12volts switched to dizzy from a supply in the engine bay.And then 12 Volts switched from under the dash to MSD alone. Both only need 12v switched to work and from where don't mean shit but if you take it from the MSD your pulling power from that too hence why I run em from separate sources which also makes fault finding easier too. Share this post Link to post Share on other sites
tyko86 4 Posted February 17, 2016 Thanks sly - think this has cleared it up for me, will advise when I'm up and running! Share this post Link to post Share on other sites
tyko86 4 Posted February 18, 2016 Wired but not running - the saga continues! Have 12v switched going to dizzy pin 3 and to red wire msd. Led flicks on once when I turn ignition to on (is it meant to stay on with key on?) Getting spark from coil lead with tapping White msd wire to ground but led does not flash when turning over (ie no trigger signal from dizzy) Share this post Link to post Share on other sites
slydog 7,873 Posted February 18, 2016 2 things...delete module or the sensor is fooked. Share this post Link to post Share on other sites
tyko86 4 Posted February 18, 2016 Any chance of a pic of your dizzy with deleted module? Did you strip the dizzy down for ease of soldering wires on? What are we talking about when you say sensor may be stuffed? How important would new rotor and dizzy cap be as the ones with the dizzy looked okay? Thank you for all the assistance so far - I'm not giving in till this b@#^% is running with the msd! Share this post Link to post Share on other sites
Mustardxf2 310 Posted February 19, 2016 All I did was pull the module off, and connected 12v, ground and signal with blade connectors to the correct ones under the dizzy, haven't had a problem Sent from my iPhone using Tapatalk 1 gerg reacted to this Share this post Link to post Share on other sites
tyko86 4 Posted February 19, 2016 Success!!!!!!!!!!!!!! Deleted module and it ran!!!!!! Only had dummy wired so have pulled everything apart again to tidy up then will fine tune the timing!! Thank you to everyone for advice! 1 eattsie9 reacted to this Share this post Link to post Share on other sites
Mustardxf2 310 Posted February 20, 2016 I had a problem with mine as well, it wouldn't get a pip signal from the module so I just deleted it as well, makes it easy!! Sent from my iPhone using Tapatalk Share this post Link to post Share on other sites
slydog 7,873 Posted February 20, 2016 Fuckin module...kunts a things. 2 Crazy2287 and Outback Jack reacted to this Share this post Link to post Share on other sites
tyko86 4 Posted February 29, 2016 So did not have a timing light but thought I had timing somewhere in the ballpark - turned out 38 degrees advance once I got a light on it! I did not run it long with this much but it seemed reasonably happy, easy to start etc and very responsive. Have backed it off to 28 degrees and seems much more flat, (when on road it does have a bit of a flat spot when you stand on it down low) Is it safe to try some more timing? Somebody mentioned upto 31 degrees? Any recommendations on carby jetting (600 vac secondary - have already changed pv to 4.5 can't remember exact jet sizes) I had a look at plug colour and redish brown after a brisk drive up the road and back - can you go off plug colour with the unleaded fuel? Share this post Link to post Share on other sites
Crazy2287 1,886 Posted February 29, 2016 Just wind timing in till it knocks bro. This other guy I know with no module just accelerates through the knock! -\(:3)/- 3 slydog, ando76 and Thom reacted to this Share this post Link to post Share on other sites
slydog 7,873 Posted February 29, 2016 Knock smock 2 Thom and Crazy2287 reacted to this Share this post Link to post Share on other sites
Crazy2287 1,886 Posted March 1, 2016 1. Is it safe to try some more timing? Somebody mentioned up to 31 degrees? 2. Any recommendations on carby jetting? 3. can you go off plug colour with the unleaded fuel? 1. Yes. I run about about 36 degrees total. for example. But each car is different. You need to get your AFR right first. Once your hitting target AFR's try to find max timing. You need to LOAD the car up. Find the steepest hill you can and do a couple of WOT pulls up in a high gear, so you can load the engine in the 1500-3000 rpm range. Listen carefully for any knock, if you hear any, reduce throttle IMMEDIATELY, and back your timing 3º and try again. If you DON'T hear any knock, advance the timing 2º and try again, till you hear knock. When you do back it off 3º and you're good to go. 2. Nope, get a vac gauge to adjust idle and choose power valve, and a wideband to set WOT AFR's 3. Yes. Plug condition can be used to diagnose many different engine problems. Share this post Link to post Share on other sites
