You’ll just have to start from the back and work your way forward cracking every join until you get fluid. Then you can figure out what is going on. BA did have a recall on the flexible hoses failing, maybe you have an inner lining failure. Either that or debris has flung up and flattened a metal line.
The problem seems to be at the ABS unit though. If I disconnect the rear line going out of the ABS unit there is no fluid coming out at all. It doesn't matter how hard the brake pedal is pushed. Nothing comes out. On faults on the scan tool either.
